(#226)
psixtc's Avatar
psixtc psixtc is offline
Default 07-16-2018, 01:18 PM
Pictures don't work, but I'm glad that it's working as advertised!!
How's the foot though? LOL
Okay, I'll try to fix those pictures tonight! I'll also try to get a clean datalog with the PR.
The foot is horrible (swollen, bruised, and bleeding). I ended up dropping a 3 ton jack on the other foot and stepping on a fire ant hill washing my car later that day too. All happened with bare feet.
My FMIC wasn't angled at all. I noticed it was hitting the bumper beam at first causing it to angle, but it straightened out once I moved it back. I was along, so grabbed the floor jack noted above to raise it into position. I also used the old hairspray trick to help lube the couplers during install which helped me a ton.
The only real issue I had was fitting the 90deg elbow coupler onto my lower charge pipe. I had to remove my lower chargepipe, heat up the coupler, then force it on to the piping.
I saved the pieces of the coupler I cut off just in case someone asked how much I had to cut, so I'll measure that tonight.
Evil1 '08 135i 6AT with a few go fast bits...
Snowman Snowman is offline
Car: BMW M135I
Default 07-16-2018, 01:24 PM
Send me some photos when you can. I believe I answered you on facebook as well. Something else has to be off because they are cast pieces that come out of a mold.
Yepp im the same guy.
Are you talking about the ic or the couplers?
The ic is clearly not a cast one, see attached image regarding that they forgot to flush/clean it...
Tbh im fairly certain that the reason mine is sitting in an angle is due to the Turbo outlet coupler is messed up. But I don't want to pull the whole ic down and try and source a new coupler just yet..
Default 07-16-2018, 03:46 PM
The intercooler end tanks are cast, the intercooler core is not.
No problem, send me the pictures in email and I can take a look. I've installed so many of them I should be able to see an issue.
seroga1986's Avatar
seroga1986 seroga1986 is offline
Default 07-17-2018, 08:01 AM
I had a track day with the new 7.5" Race intercooler. And what a difference!!!! Pushing 20psi on stock turbos for 20min on track and my IATs were only 15-20 above ambient. What a beast this thing is. Worth an upgrade from 7" intercooler. No timing drops at all. On steet IATs seem to drop going into a pull. Very nice!
2008 135i Sport 6at
JB4 G5 ISO, MHD E85 KR, Fuel-it S1, E55 Mix, Alpina Trans Flash, afe Scoops, My own custom 2.5" inlets, ER CP, Synapse BOV, 3.5 Tmap, 7.5" Phoenix FMIC, NGK 5992, 3" BMS downtubes, N55 Mids, Berk Race, BMS OCC, 48 plate oil cooler, 36 plate trans fluid cooler, PSS, R888, Hoosier DRs.
11.92@123.6 (JB4 ISO, DCI, IC, **, DR, on e45 & 17psi)(2013)
444whp/481wtq @19psi and e60 (2013)
2013 X3 xDrive28i M-package
JB4, K&N drop-in, ER downtube, Map 2 @ 22psi on 93
Default 07-18-2018, 07:38 AM
I swear by it every time as well. It's such a big improvement it's very underrated IMO.
Car: 2008 E93
Default 09-25-2018, 10:26 AM
Very underrated. This FMIC works !
Default 09-25-2018, 10:43 AM
Also the only IC you can get a matching 3" cold pipe for to keep it 3" all the way to the throttle body.
Torgus Torgus is offline
Default 09-28-2018, 05:23 PM
does the VRSF race taper down?
Got Boost?
Default 09-28-2018, 07:53 PM
Yes their J pipe is only offered in 2.5".
Just got a shipment of 90 RACE intercooler in today so get while the getting is good.
luchocamp's Avatar
Default 09-29-2018, 03:12 AM
great product , using in one customer 335i ps2 hf iat only increase 10F up to 5th 164mph
W.R. 11.01 @127.6mph, LUCHOJB4, BMS BEF MHD, E85/Reg + meth 24.8psi ~ Set-up on Drag Track online instagram @luchocampusano ➡
Default 09-29-2018, 08:20 AM
Hmm, it is advertised as "includes 3" lower charge pipe" maybe it tapers to 2.5''? I don't recall mine tapering at all when I installed it. It's not a major issue either way.
Either IC seems to be the way to go. I do like your diverter plate on the inlet.
Got Boost?
Default 09-30-2018, 03:24 PM
You'd have to check with them. Last I heard they include a 2.5" J pipe. We offer both, the 3" lets you stay 3" all the way to the throttle body.
Default 10-01-2018, 07:06 AM
Phoenix Race back in stock and shipping.
Stephtech's Avatar
Stephtech Stephtech is offline
Car: 335xi 2010 E90
Default 02-12-2019, 04:03 PM
I already knows that to fit the race intercooler some portions of the bumper needs to be trimmed. I have a OEM M-tech bumper, does it also fits on mine?
2010 E90 335XI 6AT with XPH stage 3 | JB4 G5 W/Trebila Tune | RB Next Gen | RB hot side INLETs | Fuel-IT stage 1 LPFP | ETS FMIC | MODDED VRSF CP | FORGE DV | BMS METH KIT CM10+CM5 & HYBRID PORT INJECTION | AR DESIGN cer. downP | BMS OCC | RB external PCV w/plugged HEAD | Best 1/4: 11.47@123mph
chadillac2000's Avatar
Car: 2008 535i
Default 02-12-2019, 04:06 PM
None of the actual bumper needs to be trimmed, just a lot of the plastic lying underneath.
Stephtech's Avatar
Car: 335xi 2010 E90
Default 02-12-2019, 04:16 PM
ah ok nice, that means it should fit on mine.
thanks
Default 02-12-2019, 07:05 PM
thanks
Yup, I have the Mtech bumper too it fits perfect
Stephtech's Avatar
Car: 335xi 2010 E90
Default 02-12-2019, 07:14 PM
can't wait to install this IC, I would also like to order the 3" J pipe. Does the 3" fit for an AT car with the transmission heat exchanger ? (just below the radiator)
psixtc's Avatar
Default 02-13-2019, 11:47 AM
Yes it does, as I have the AT and this FMIC with 3" J pipe.
I would HIGHLY suggest unscrewing the trans heat exchange from the radiator shroud to give you some more wiggle room, then reinstall it once the piping is all connected.
Stephtech's Avatar
Car: 335xi 2010 E90
Default 02-13-2019, 11:53 AM
I see from your signature that you have a 135...may not be exactly same room as mine, even tough you might have less room than a 335.
anyone with a 335 AT with the 3" J pipe?
