Default 03-16-2017, 04:22 PM
Awesome!!
Limpmode's Avatar
Limpmode Limpmode is offline
Car: 2007 E90 335i
Default 03-16-2017, 06:09 PM
That thing winds out like American muscle! Definitaly higher stall than the ZF.
2007 335i; JB4 G5, MHD BEF, BMS DCI, Phoenix CP, Tial BOV, MAP OC, BMS OCC, 1320 Down *****, MMP Inlets, RB Ext PCV, Mishimoto OCC, BMS Meth, N20 TMAP, VTT stock CHRA=billet comp wheels, Blk powdercoat style 124 Wheels (5series staggered), 275/35/18 Firestone rears.
Default 03-16-2017, 07:10 PM
Crank it up!!!!
Chris@VargasTurboTech's Avatar
Chris@VargasTurboTech Chris@VargasTurboTech is offline
VTT ***** *****
Car: All Things Booost
Default 03-16-2017, 11:03 PM
Awesome! That'll change a few things.
Chris - VTT Forum Representative
For fastest response: Chris@Vargasturbo.com
www.Vargasturbo.com
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 03-17-2017, 07:18 AM
Looks like I'll be going to the track on Sunday assuming the weather stays the way the forecast says.
Default 03-17-2017, 10:10 AM
Yesssssss!!!!
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 03-19-2017, 05:00 PM
How was the track today???
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
2014 E84 X1 35i 12.85 @ 107MPH / 0-60 4.72 / 293 AWHP 305 AWTQ When stock
VRSF Chargepipe | BMS Intake | JB4 ISO | N20 TMAP | VRSF 7" Intercooler | ER Turbo Outlet |
Car: 2008 135i
Default 03-20-2017, 06:53 AM
Unfortunately I got word on the way up there that track conditions weren't good with 1 car sliding into the wall at the start of the track already so I decided to reschedule. Hopefully next weekend.
Car: 2011 e92 335i
Default 03-20-2017, 07:58 AM
Good call. I hit the strip yesterday and they were only running one lane due to poor track conditions. My best 60 foot was 2.4, should have stayed home.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
klipseracer klipseracer is offline
Default 03-20-2017, 11:55 AM
Looks sick!
omarmarji's Avatar
Car: n54 335
Default 03-20-2017, 12:23 PM
Originally Posted by Tony@VargasTurboTech
Awesome! So this does this mean you will actually make it to races you called me out to race, or you are going to go 0-3 on us showing up to race, you texting Chris with excuses on why you, nor the car is present?
I want to say mean things to you right now but I'm going to refrain myself from getting down to your level
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
N54QC N54QC is offline
Car: 07 BMW 335i
Default 04-06-2017, 02:53 PM
So were you able to hit the track for some results?
Car: 2008 135i
Default 04-06-2017, 03:05 PM
Current goal is Saturday if the weather permits.
Car: 07 BMW 335i
Default 04-06-2017, 03:07 PM
Awesome, hope you get some good results!
ChrisCote ChrisCote is offline
Default 04-06-2017, 04:34 PM
runs great man
possibility of a trans brake in the future?
Jnelly335i Jnelly335i is offline
Car: 07 BMW 335i
Default 04-06-2017, 07:21 PM
Where did you get the custom bell housing?
dyezak dyezak is offline
Default 04-06-2017, 07:52 PM
It's in the subject of the thread....
Car: 07 BMW 335i
Default 04-06-2017, 09:24 PM
Doesn't say where the custom bell housing is from
Default 04-06-2017, 09:43 PM
AD Engineering 4L80E Trans Kit Review
I'm trying to figure out the confusion.
Default 04-07-2017, 06:32 AM
2 housings welded together.
Car: 2008 135i
Default 04-09-2017, 10:46 PM
So I finally got a chance to get the car to the track, but it is definitely going to take some tweaking to get this working better. Overall best run today was 10.91 @ 128 with extreme throttle closures throughout the entire run (log attached).
First thing is the stall. The current stall in the torque converter is really high and feels loose pretty much all the way to redline and barely drops when shifting. I've spoken with Andy about this and I'll be pulling the torque converter this week to send to him to adjust.
Second thing is the TCM. The EZ TCU was pretty simple to setup/install, but lacks more advanced customization directly through the TCM itself. Basically the torque converter clutch never "locks" when at 100% throttle (no option to set that up through the unit either). There is an extra wire which can be driven to ground to manually override the lockup so I'll be talking to Terry to see if I can control this via the JB4 somehow, but it would be nice to have some options directly through the handheld interface. The other problem this amplifies is overheating. Since the TC never locks up, it generates A LOT of heat throughout the run. I have a more than sufficient trans cooler and still was getting overheating warnings after basically every run. This TCU also lacks any form of true logging so I may end up looking for other options.
Third thing is gear readout. Since the car has to stay coded as a manual and use the "manual" way of calculating gear (basically a formula using road speed, rpm, final ratio, etc), the DME and JB4 have no clue what gear the car is actually in (since all the slip in the torque converter can have the car at the same speed and the same rpm in virtually every gear). This creates issues for things like boost by gear. I've worked out the serial protocol for the EZ TCU and can read the gear parameter so I may end up making a little chip to feed that into the JB4.
As far as the throttle closures, I really need to get my rpm limiter out of the way and just shift it a tad earlier to see if that will clean it up.
Anyway, I feel like once I get these 3 things worked out the car will be incredible. I'll keep this updated as things progress.
File Type: csv 2017-04-09 16_06_42 (D_75) 10.91-128mph.csv (11.1 KB, 60 views)
Peter @ Pure's Avatar
Car: F20 M135i
Default 04-10-2017, 04:33 AM
Not bad for a first live test run!
F21 M140i - 100-200: 8.1
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 04-10-2017, 08:10 AM
Should be easy 9s@140 once sorted. IMHO the biggest problem for performance was the converter slippage causing you to do half the run over your rev limiter with 80% throttle closure. On the DME not reading road-speed properly we'll have to figure out what changed there as it read fine with the MT. I think that speed sensor is in the right rear hub? It feeds a frequency signal in to the DME on spot #17 on the gray subconnector IIRC and then the JB4 reads that from the DME via CANbus.
Car: 07 BMW 335i
Default 04-10-2017, 04:25 PM
what stall do you have?
Bowser330 Bowser330 is offline
N54TECH FTMFW
Default 08-03-2017, 03:02 PM
update bump!
