Stoolz Stoolz is offline
Car: 11 135i
Lightbulb Is there a dct flash? - 05-15-2016, 01:33 AM
My S2 FBO E82 DCT coupe does some weird stuff now and then like changing into third from second early when in manual mode (into it) or misfiring on gear change. I always drive it with traction control totally off because even with the quaife i cant drive it hard with just the dtc activated. It almost feels like engine torque management stopping the show.
Anyone else have these issues or know how to fix them? (other than going back to stock).
Cheers!
Default 05-15-2016, 09:44 PM
There is no DCT specific flash but if you are an N55 E82, you should be able to run a flash via Cobb. This will allow the DME to see actual load and adjust the transmission line pressures accordingly.
Car: 11 135i
Default 05-15-2016, 10:21 PM
Steve pardon my ignorance but is this how Terry's E85 BEF works? (I am running it).
Default 05-16-2016, 06:21 AM
Yes, the load targets are increased in the BEF.
EB89 EB89 is offline
Car: N55 335i 2011 e92
Default 06-19-2016, 06:42 PM
There is the PPK Flash for N55, i helped get rid of a shudder my car had in 1st gear.
Im DCT also, it may or may not help.
m123 m123 is offline
Car: 440i F32
Default 06-20-2016, 11:16 AM
You can also flash the 335is dct software. It increases the clutch pressure. I haf it done with my e92. Maybe it works also for the e82.
F32 440i JB4
F11 550i N63tu JB4
Default 06-20-2016, 03:34 PM
You did it to an e92 335i DCT right, not to a 335is
What differently did it make for you
Car: 440i F32
Default 06-20-2016, 10:48 PM
Yes. 335is dct software on an 335i. It increased the clutch pressure. You could se it with inpa.
F32 440i JB4
F11 550i N63tu JB4
keyap keyap is offline
Car: N55 135i
Default 06-21-2016, 07:57 AM
What is the ZSub for the is DCT flash and which V datens?
This could be great news for any post 2012 DCT cars who want to make the move to say a PS2 but cannot increase DME boost as they are unable to BEF.
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | Berk Race Full Exhaust | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
Car: 440i F32
Default 06-21-2016, 08:20 AM
I had the flash done by someone. So i do not the data version zusub. But someone here might know. I just saw the increased pressure in inpa.
F32 440i JB4
F11 550i N63tu JB4
Car: N55 135i
Default 06-21-2016, 02:37 PM
Anyone out there with a 335is DCT that can check via INPA?
Edit - no longer needed. Just found what I was looking for.
In daten V55, the following DCT (EGS / GS40) zsubs apply.
135i: 8606070
135is (limited production with DCT): 8606072
335is: 8606074.
From what I can see, the only difference between the 135is and the 335is is the launch control. 335is is 5000rpm whereas 135is is 3500.
In theory, the 135is and 335is DCT flash should offer increased clutch pressure over the 135i DCT flash. Possibly good news for those targeting higher boost that can't BEF
Would be great if someone with say a PS1, PS2 or other upgraded turbo who doesn't have a BEF, or even better, has a MEVD 1726 ECU, could try this and report back. As with anything like this though - only do if you're 200% sure of what you're doing an do at you're own risk.
trebila's Avatar
trebila trebila is offline
Default 06-22-2016, 03:18 PM
try 8606090
Car: N55 135i
Default 06-23-2016, 10:02 AM
try 8606090
Thanks trebila
Which flash is this?
trebila's Avatar
Default 06-23-2016, 10:24 AM
I'm not sure, but one of my DCT customer is running it, with great results.
Car: N55 135i
Default 06-23-2016, 12:02 PM
OK - there's rumours of a GTRR flash but it's v rare and from what I can find, there's more to it than just hook up WinKFP.
I bet this is one of the limited M3 GTS flashes in which case it should be capable of holding quite a bit of torque.
Car: 2011 N55 135DCT
Default 06-23-2016, 12:50 PM
Keyap i found this
Both ZB numbers are for the GS40 TCU. But 8606090 is on the n54 DCT.
From the best I can gather ZB numbers 8606074 and 8606090 share the same ECU identifier, project, and program version. Only the data versions differ; 74=0GL00, 90=0FO00. They were even released on the same day. That being said, likely the only difference is calibration (i.e. US vs. ECE)
Car: N55 135i
Default 06-24-2016, 07:12 AM
Keyap i found this
Time to have a look at the .0da's
Default 06-24-2016, 07:17 AM
Yes then if ok i can test it on my car lol
Car: N55 135i
Default 06-24-2016, 07:19 AM
Keyap i found this
I'm going to be away for a couple of weeks but will have a look when back.
Default 06-24-2016, 07:24 AM
No probs. Remember when i do my TBI and stage 2 lpfp i need yre help to do bef fuel scallars
Car: N55 135i
Default 06-24-2016, 07:26 AM
PM me - just hope the things we spoke about with ATR work out OK
I bought Barberider cobb ap. And it was shipped to me last night.
trebila's Avatar
Default 06-25-2016, 01:50 AM
Originally Posted by trebila
try 8606090
8606092 works pretty well too:
https://www.instagram.com/p/BHCfPMzDrKy/
rhylea's Avatar
rhylea rhylea is offline
Car: BMW 335i N55
Default 06-28-2016, 02:41 AM
I have an Australian-delivered (Europe Spec) 2011 E92 335i MSport N55 DCT and was running ZB 8606068 as per how I received the car. I have been noticing some translip and slow tip-in so decided to try out another ZB. Initially I was going to try ZB 8606090 as suggested by trebila but it wasn't in the datens but instead my coder found an updated version of it listed as ZB 8647881. I have only driven the car a couple of days but the translip seems to be gone and no real slow tip-in as yet. So that's good. However the gear changes are definitely slower than the original version, more like an AT than DCT. I'm wondering if anyone else has this version and wants to share their experience? Wondering if maybe I should try find the ZB 8606090 or ZB 8606092.
Default 06-30-2016, 06:32 AM
Guys try the Z4 n54 DCT Tcu Zusub 8606076
