sleeperz sleeperz is offline
Car: E36/7 and E93
Default Oil Thermostat Cover Leak - What Seal/Gasket to Use? - 02-04-2019, 08:07 AM
I am installing a replacement engine in my E93 and I noticed the thermostat cover on the oil filter housing is leaking. I already bought the 2 profile gaskets for it, but I can't find the seal for the oil thermostat cap. I think BMW wants to sell the whole assembly only. I have the 11427573212 housing.
I know Burger Tuning sells replacement billet caps. But I didn't see any gaskets.
I did find a cover kit from FTP Motorsports that includes a seal.
Use a big O ring?
Help
Default 02-04-2019, 09:54 AM
For the billet caps we supply O rings. For the thermostat lid we don't, you can use bit of RTV.
Car: E36/7 and E93
Default 02-04-2019, 11:04 AM
Thanks. I was hoping for different answer.
FWIW... In case this comes up again...
I use this stuff for that purpose. Unlike normal RTV, it never breaks down.
Ford Motorcraft RTV Silicone Sealant TA-31
It is specially formulated for use with diesel contaminated oil and survives under extreme conditions. I use it on bed plates for example.
Cheers!
rcpro88 rcpro88 is offline
Car: 535i
Default 02-04-2019, 02:18 PM
If youre taking off the OFH, then I would take take the part to the hardware store and try various sizes of o-rings. Push/stretch them into place and make sure some rubber is protruding from the channel so when you put the cap on, it will compress the o-ring thus making a seal. Use nitrile or even better: viton ones. You can go to harbor freight and get an assortment of viton o-rings for $10. Fastenal also sells an o-ring assortment but it was like $100...
DON'T buy VRSF D.Ps or inlets! I have them and their fitment sucks! Running their FMIC with no issues.
HKS BOV, BMS DCI, BMS Meth Kit
JB4 w/MHD-BMS E85 Backend Flash
Custom Map 6 21.5 psi (E70 mix)
Walbro 450 LPFP - 4 Bar TMAP Sensor - Muff Delete
SAT Transmission Flash/retrofit (Thanks to Wedge!)
AD Engineering Oil thermostat - Rob Beck PCV Valve
Installed all the parts myself.
Car: E36/7 and E93
Default 02-04-2019, 02:41 PM
Thanks. I am thinking I will try the O ring idea before gluing with sealant.
Default 02-04-2019, 03:17 PM
O ring will work if you find the size, the will form to that shape.
Car: 535i
Default 02-05-2019, 04:19 PM
If the kit BMS sells has an o-ring in it, then would you might sharing the o-ring size?
Default 02-05-2019, 04:40 PM
We don't or else I would lol.
Car: E36/7 and E93
Default 02-06-2019, 08:33 PM
BTW an O ring works great. I purchased a large Metric Buna (Nitrile) assortment from Harbor Freight (Viton set is too small) for about $8. There is a number 220 in the kit that works fine. It is a little tricky to get it to seat while the cover is attached, but once in place, it works great.
Hope this helps someone.
Cheers!
