Vivalarevoluciones Vivalarevoluciones is offline
Default Car was running so well before mhd tune . After tune car is bad :( - 07-22-2017, 08:19 AM
So i installed mhd tune before the install i have done all maintenance; installed tune everything worked went for a test drive . First time i gun it lots of power new car feel , second time i punche it went into limpmode half engine sign 3 misfires. Cylinders 1,2&3 and various fault codes. The car is an 07 335i sedan i cleaned valves allfluids chanched wayer pump thermostat , pullies and belt plugs . I got the car this last February, i have put 7000 miles of driving the car hard, it always always performed very well ! Also got turbos replaced and various gasket seals repkaced under warranty. After mhd flash all this happened. I really hope is just all software issues. I would appreciate your thoughts troubleshooting stories and fixes !
https://imgur.com/gallery/oyAwZ
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-22-2017, 08:57 AM
How old is your spark plugs? If you never changed them 1st thing to do changing your spark plugs
Default 07-22-2017, 09:01 AM
I just changed them about month ago bosch oem
Default 07-22-2017, 09:07 AM
Find a tuner or mechanic to help you sort it!
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 07-22-2017, 09:37 AM
Same thing happened to me. The mhd tune is more aggressive so it will show any weakness. When i got mine my clutch gave out instantly lol. Then i fixed it and plugs couldn't hang and 2 coils.
2008 BMW 135i MT: Stock turbo FBO
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
JBacon335 JBacon335 is offline
Car: 2007 BMW E90 335i
Default 07-23-2017, 06:19 AM
just dump the stock coils and get the Bimmerlife Tuning coil kit or the Precision Raceworks kit and some new plugs. ignition misfires will be a thing of the past. now injectors on the other hand, that's another story
mhigham mhigham is offline
Car: 2009 BMW 335i
Default 07-24-2017, 07:09 PM
Welcome to tuning. I bet you need coils and plugs. My car was a stock mint 35,000 car with fresh walnut blast, oil change, etc. First pull past stock boost, I had two coils go.
I got Delphi ones and stock plugs from Amazon, now it holds 17 psi on E30 all day on map 5. Stock with tune and chargepipe. You will need a charge pipe next
Default 07-25-2017, 06:04 AM
I did get a charge pip from amazon for 200.00 with blowoff valve , but i had to return it in order to have some money to fix this dme internal failure 3ba code . Im pretty sure i fried bank 1 mosfets on my dme . Today they will come and i will take the dme to an electronics shop to swap out the bad mosfets with the new ones, i have new coil packs too . Hope this is the problem . Man im sad frustrated with out my baby ill update on what fixed my problem for future refrences or help !
