(#2401)
Default 07-17-2019, 01:30 PM
Originally Posted by hamburger1971
Thanks, Terry. I have the replacement plugs from you guys. You think that could still be it, or can you think of another weak spot in the electrical system worth checking?
Jeff
Only if one was damaged during install or if there was a coil issue. Another test might be to remove OBDII cable all together to see if you can recreate the symptoms on map1.
At any event just email and we'll help you that way, terry@burgertuning.com
spyders03's Avatar
spyders03 spyders03 is offline
Car: 16 SXL
Default 07-17-2019, 03:14 PM
Good evening. I just got the JB4 installed on my 2016 Optima SXL (2.0T), map 1 runs just fine, tried map 2 and it defaulted back to map 0 half way through a 3rd gear pull. Just changed the plugs to the M45XL HKS plugs, running 93 octane. It seemed to hesitate right before (or maybe during) the switch in maps. Any help you can provide would be greatly appreciated. Hopefully the day to log uploads.
spyders03's Avatar
Car: 16 SXL
Default 07-17-2019, 03:16 PM
Upload
Default 07-17-2019, 03:38 PM
Originally Posted by spyders03
Upload
You exceeded your 20psi boost safety. Raise that to 22psi and log map1 next.
spyders03's Avatar
Car: 16 SXL
Default 07-17-2019, 03:57 PM
Here's a log from map 1, I'll adjust and take another log on map 1 in a little bit after the adjustment. Seems like it stayed in map 1 the whole time? Not sure if everything else looks ok.
Default 07-17-2019, 05:42 PM
Log looks OK, next log do something more like a 1/4 mile style run with shifts.
Adamdan Adamdan is offline
Car: Stinger
Default 07-17-2019, 06:39 PM
Any info on the self learning map for the stinger?
spyders03's Avatar
Car: 16 SXL
Default 07-18-2019, 01:33 PM
Let me know if you need a longer log, didn't have a ton of room this morning. Thanks in advance, we all appreciate your expertise!
P.S. the JB4 in map 2 feels AMAZING!
Default 07-18-2019, 03:00 PM
We haven't released one yet, but plan to in the future.
Default 07-18-2019, 03:01 PM
Timing movement is a bit odd but not sure if it's a logging thing or how it's actually running. Try to grab a couple more logs for comparison.
lvthundercat lvthundercat is offline
Car: Kia Stinger GT AWD
Default Yesterday, 12:43 PM
1) Sometimes map1 works on stock plug gap, sometimes it doesn't.
2) Doesn't really matter. No reason not to run the latest firmware, though.
3) There is a DIY video somewhere around, anyone can do it. Takes an hour or two the first time but maybe 30 min the second.
4) You can run map1 or map2 on 91 octane.
5) Not an issue
Hi Terry;
I'm new to this platform and had just received my jb4 w/ BT dongle for a 2019 Stinger GT using stock plugs / stock gap, 91 octane @ 2K ft elevation. Your replies above answered most of my questions. But I got 2 more:
1. Do I need to use/connect the OBD2 plug in order to get the maximum benefit of Map1 & 2? or is the OBD2 plug just for monitoring gauges on the phone?
and
2. If I just got the jb4 (brand new), do I need to worry about any firmware updates at this time? or am I good to go as is - just plug and play?
Thanks.
Chris
spyders03's Avatar
Car: 16 SXL
Default Yesterday, 12:55 PM
Here's a 1/4 mile style log. Roads were slightly wet so there was some wheel spin down low
Default Yesterday, 12:56 PM
Originally Posted by lvthundercat
Hi Terry;
and
Thanks.
Chris
1) Yes tuning is much better with OBDII even on map1.
2) Firmware updates are always optional!
filmnews filmnews is offline
Car: stinger GT2
Default Yesterday, 06:08 PM
Map 5 on 93 with octane boost - Does everything look good? Thanks for your help. 2018 Kia Stinger GT2 AWD
Default Yesterday, 06:42 PM
Yes looks fine to me!
Default Yesterday, 07:09 PM
Hi Terry;
Thank you for the reply. I guess I didn't ask the question right.
Will the jb4 still work in conjunction with the app if I don't attach it to the car using the OBDII cable?
Thanks.
Chris
spyders03's Avatar
Car: 16 SXL
Default Yesterday, 08:07 PM
Default Today, 09:24 AM
Hi Terry;
Thanks.
Chris
No, without OBDII JB4 reads boost only. So tuning is clunkier (like a lap3) and you can only log boost.
Default Today, 09:25 AM
Seems OK to me here.
atr1 atr1 is offline
Car: Stinger GT
Default Today, 09:40 AM
Timings are high. Need to increase the boost!
Default Today, 11:40 AM
More boost is not always better. You want to find a good balance of boost and timing and reasonable power levels for the platform to keep things reliable long term. Even if the logs look good but the motor has a known weak spots (like many of these 4 bangers) best to stay a little conservative IMHO.
Car: Stinger GT
Default Today, 12:06 PM
Dustinís GT2
