cebrailbakan's Avatar
Car: BMW E90 335XI
Exclamation Question on false knock - 07-14-2018, 02:01 PM
Hi guys , I’ve been logging a false knock randomly for the past few weeks with forged internals. I am running fuel it PI with methanol. Meth flow starts to spray at 6 psi. I changed coil (PR upgraded coils), spark , and injector but false knock is still in its place. I am running a single cm10 nozzle for IAT suppression but on the contrary it goes really high and fast.
What is strange point is that I’ve been running the car with Vp ms 109 and Vp m1 methanol , I meant tons of octane here. But I wonder if my spark gap on which is 0.018 proper for race fuel or not , is it too closed for race gas ? Can it induce false knock ?? I also desensitized knock tables via MHD.
I also think that ,since meth pressure is not high enough to provide the PI kit and the nozzle in the charge pipe, so meth is not correctly atomized into the charge pipe, inducing abnormal combustion
So when it comes to buy the new product called CPI (charge pipe injection) which needs only 40 psi to be able to be feed from the meth pump while nozzle needs 150 psi to spray , do you guys agree ?
I am really stuck , any help would be greatly appareciated.
Do more with less !
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 07-14-2018, 03:33 PM
Did u change the sensor. i had false knock twice and the culprit was the sensor once and fuse for o2 sensors once. Does it come on rite away or here and there
2008 BMW 135i MT: Stock turbo FBO
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
Car: BMW E90 335XI
Default 07-14-2018, 03:43 PM
Thanks for the input. But as I know Jb4 detects every faulty things , it never popped up regarding o2 sensors. Happened the same thing to you ?
Do more with less !
goldfz8's Avatar
Default 07-14-2018, 03:49 PM
i dont use jb4. stock ecu with mhd. the knock would come up here and there. Changed the knock sensor and boom no problems.
502whp 593wtq
3180lbs w/o driver
Car: BMW E90 335XI
Default 07-14-2018, 03:53 PM
That being said , should I both change all four o2 sensors and knock sensors to get rid of false knock ?
Do more with less !
goldfz8's Avatar
Default 07-14-2018, 04:02 PM
my o2 sensors were fine as i expect yours are to. I would try changing the knock sensor.
502whp 593wtq
3180lbs w/o driver
Car: BMW E90 335XI
Default 07-16-2018, 03:44 PM
Anyone ?
Do more with less !
Default 07-16-2018, 10:59 PM
False knock... what cylinders?
Car: BMW E90 335XI
Default 07-16-2018, 11:03 PM
Dave , Please check the log above you know determine better
Do more with less !
THE BEAST's Avatar
Car: 2008 E93
Default 07-17-2018, 12:27 AM
Looks like timing corrections ?
Car: BMW E90 335XI
Default 07-17-2018, 02:05 AM
Please check attached log at the top of this page
Do more with less !
Default 07-18-2018, 09:20 AM
I just see a lot of overboosting in the beginning.
Car: BMW E90 335XI
Default 07-18-2018, 09:32 AM
Thanks payam , I’m running with PR coils with ngk sparks gapped at 0.018’’, is it too closed for race gas ? I also didn’t choose one the options of MHD for PR coils.
Do more with less !
Car: BMW E90 335XI
Default 07-18-2018, 09:33 AM
Thanks in advance for the helps
Do more with less !
