goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default Smallest size rear wheels? - 10-30-2014, 01:09 AM
For drag racing it has been proven fast rwd cars usualy use 15" wheels. I know on a stock 135 they wont fit atleast it dosent look like it. Does anyone know what 16" will fit also what if you down grade the rear to 128i brakes there smaller but will it fit a 15" ... I have a mt 135 and im planning on going twin disc so i would love a 15" with a 26" slick...
i know maxpsi just did a 8s with a 16" 26 tall tire but i want 15s
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
BostonBeemah's Avatar
Car: AW 135i
Default 10-30-2014, 01:49 PM
+ 1 looking to do something similar but haven't been able to find much info on the topic
RIP 2008 AW/BL 135i
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
administartor
Car: F80 M3
Default 10-30-2014, 05:35 PM
A 17" wheel is the smallest you can use with the factory 135 Brembos on the back. There is about 1/2" clearance now with 17". The 128i rear brake conversion would be a costly job requiring replacement of the HUB and e-brake assembly and would still probably not give clearance for a 15" wheel.
goldfz8's Avatar
Default 10-30-2014, 07:43 PM
I saw a 128 with factory 16s looked like maybe a 15 could fit. And idc about the price when your spending on all the other stuff its nothing
502whp 593wtq
3180lbs w/o driver
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 02-24-2015, 06:21 PM
No OEM vented or twin disk as you call it that fits under 15" because there isn't one in existence.
that is because 135i and 335i come with the larger 180mm parking brake shoes.
The smallest rotor that fits over this parking brakes is e34 525i solid 300mm
You could use this 300mm solid from e34 525i with caliper/carriers/pads from 128i
128i rotors are also 300m but will not fit over the parking brake shoes.
Same with 328i rotor, they will not fit over the parking brake on 335i
Also, on the 135i the caliper will have to mounted on the inner side of the hub knuckle.
If you have 335i same rotors from e34 525i with calipers/carriers/pads from 328i but mounted normally.
I have discussed the same on E90post. In theory, going of the numbers this should work.
However, nobody has done brake downgrade.
suspenceful's Avatar
Car: 2008 BSM 135i
Default 06-04-2018, 02:59 PM
Can anyone confirm that a 16" wheel will NOT fit on the back of a 135i with stock brakes?
goldfz8's Avatar
Default 06-04-2018, 08:14 PM
haha what a old thread so to update...i don't think a 16 will fit however i have since downgraded brakes. Different hub for 135 and 28xi brakes do the trick to fit 15"
502whp 593wtq
3180lbs w/o driver
Car: 2008 BSM 135i
Default 06-05-2018, 09:11 AM
Nice to see you're still active! I was Googling things and it brought me here. Didn't realize the thread was 4 years old, lol.
goldfz8's Avatar
Default 07-19-2018, 08:44 AM
15x8 drag star 26x8.5x15
502whp 593wtq
3180lbs w/o driver
