Bimmerlife35 Bimmerlife35 is offline
Car: 2007 BMW 335i
Angry DME failure! 30BB - 12-07-2017, 11:58 PM
So my DME failed yesterday, I got a code 30BB and misfire codes on cylinders 4,5, and 6. Iíve been looking at options and came across a company called RPM motorsports, and if I send mine in they can record all the data from MSD80 board to the newer MSD81 board for $1000. I was just wondering if anyone has heard or gone through them, want to know if they are reputable.
2007 BMW 335i
DCI
Custom exhaust (Full Straight!)
Charge pipe w/ Tial BOV
JB4 Tune
Backend MHD
E30-E40 Mix when itís not raining
murdo81 murdo81 is offline
Car: bmw 335i e92
Default 12-08-2017, 12:16 AM
$500 for vader solutions to do the same job champ
Aussie e92 335i. Pure Stage 2 Twin Turbos, Pure Performance Motorsports Forge Rods and Pistons, Fuel-it Port Injection, 7.5" Race intercooler, Fuel-it Stage 3 LPFP, Ugraded Fuel lines , Tial 50mm BOV, TFT RHD Inlets, JB4 g5, MHD 98Ron Wedge Hybrid Custom Backend flash, BMS OCC, T20MAP, AR Design 3" Cattless **, Remus Dual 2.5" system with 84mm quad tips, RB PCV valve, AFE intake scoops, Bimmer Coils, CSF Radiator
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 12-08-2017, 12:51 AM
i had the same problem amd got mosfet from china for 10bucks took the ecu to a computer store to solder them and boom its been 2 years no problems. if your in nyc i got extra mosfets.
2008 BMW 135i MT: Stock turbo FBO
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
aus135i aus135i is offline
Default 12-08-2017, 02:47 AM
Yep mosfet driver failure is an easy fix if you know how to remove components and solder in new ones.
mj6234 mj6234 is offline
Car: 2008 335i
Default 12-09-2017, 07:55 AM
If you are going MSD81, which I did, buy eBay DME and ship current DME, CAS, and donor DME to this guy. Best price I found and respected in the community.
Do NOT pay $500 to do the mosfets. You can swap to MSD81 for that and be done with it.
https://www.facebook.com/Bimecu/
imad777 imad777 is offline
Car: BMW 335i
Default 12-09-2017, 08:05 AM
I second for the guy. Here's the web: https://www.bimecu.com/
2007 335i MT N54
MHD+JB4 Garret GTW3684 ST
FMIC, **, 3" *****, Fuel-It Stage 1, MF LSD.
Default 12-09-2017, 10:13 AM
Common problem but easy fix these days, on the crappy MSD80.
Default 12-10-2017, 03:41 PM
Any local small electroncis repair shop can fix this for you in a few minutes
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Brett77 Brett77 is offline
Car: 2007 335i coupe
Default Replacement FETs - 04-26-2018, 03:50 PM
Originally Posted by Bimmerlife35
So my DME failed yesterday, I got a code 30BB and misfire codes on cylinders 4,5, and 6.:
I just had the same thing happen to my car, first run after a long winter. Also got a few other codes.
I'm very, very glad to read this is likely just failed driver FETs, as I am pretty handy with air/iron solder work.
What replacement FET's should I order? Mouser? Digikey?
Brett
2007 335i E92
Default 04-26-2018, 06:04 PM
looks like IRF644SPBF or FDB1430TMCT is the way to go.
