iarthur's Avatar
iarthur iarthur is offline
Car: Mini Cooper S F56
Exclamation 320i switching to map 4 - 10-05-2020, 05:04 AM
Hello, I have a 320i 2015, I recently purchased a JB4 without the ewg connector and I upgraded to firmware 7, I went to test it on map5, the problem is that when I change gears from third to fourth it changes the map to 4, I did the test on other maps and the problem is repeated, I noticed that the boost is not over 11 psi and the last safety stored 1 below my settings and logs:
DP
DV +
Inbox filter
Gas 102 ron Podium Brazil
Default 10-05-2020, 08:19 AM
Photo of JB4 connections installed in engine bay?
iarthur's Avatar
Default 10-05-2020, 11:32 AM
Ok
Default 10-05-2020, 01:09 PM
Photo looks OK, but PSI2 manifold boost in the log is higher than throttle body boost, which should be impossible.
Map0 log?
iarthur's Avatar
Default 10-05-2020, 01:18 PM
Map 0
Default 10-05-2020, 01:37 PM
Not lining up on map0 also. Photo of both sides of the JB4 board?
iarthur's Avatar
Default 10-05-2020, 03:04 PM
iarthur's Avatar
Default 10-06-2020, 07:10 PM
New logs on map 5 there were wmi configurations set to zero and did not change to map 4 anymore.
iarthur's Avatar
Default 10-08-2020, 04:33 AM
This log was with the firmware in version 6, version 7 still skips to map 4.
Default 10-08-2020, 03:21 PM
If it's working then stick with it. But something is definitely odd, perhaps the JB4 board itself is faulty.
iarthur's Avatar
Default 10-09-2020, 05:24 AM
How could I be sure the card is defective?
Default 10-10-2020, 08:18 AM
You could try swapping JB4 boards with a friend and recording a log to compare. If you were in the USA we'd send you another board but being in BR is more difficult with the shipping.
iarthur's Avatar
Default 10-10-2020, 08:51 AM
I can pay the freight is all costs
hellspeed180 hellspeed180 is offline
Car: BMW 320i
Default 02-14-2021, 05:46 PM
I'm having exactly the same trouble with 320i using 103 octane fuel. I'll change the firmware to 13/6//5 and test
datalog https://***********/u/hellspeed69/bm...=1&data=1-4-23
https://datazap. me/u/hellspeed69/bmw-podium-e-octapro-90?log=1&data=1-4-23 (remove SPACE "...datazap[SPACE].me....")
Car: BMW 320i
Smile 02-15-2021, 07:19 AM
datalog https://***********/u/hellspeed69/bm...6&mark=473-497
Problem solved. I've switched back to firmware 13/6/5 and all problems gone
Default 02-16-2021, 11:15 AM
Would need to see CSV for any tuning advice.
