Arrtus Arrtus is offline
Car: 2009 135i 6MT
Default Do injectors need coding if complete engine was swapped? - 08-01-2020, 11:20 AM
Some time ago, I swapped out my E70's N63 engine with a used one that came from a totaled car. The engine came with everything on it except for turbos.
My question is: do I need to re-code the DME to be able to properly interface with the new engine's injectors or is that something that will automatically sync up to my vehicle like the mileage did?
I did not know about injectors having to be coded until I picked up my 1 series and now I want to make sure that the X5 is installed correctly. It's quite a pain to get to the injectors to have to re-code them so if I don't have to do it then I would prefer not to.
Mike_L's Avatar
Mike_L Mike_L is online now
Anti-Social
Car: 2017 X3 xDrive35i
Default 08-01-2020, 11:57 AM
If you're using the original DME, yes, they need to be coded. If you're using the DME matched with the engine, then No.
Mike Levy
2021 Tanzanite Blue II M550i - 8/20/20 build date.
2017 Carbon Black X3 xDrive35i
2018 Silver Equinox LT 2.0T
Car: 2009 135i 6MT
Default 08-01-2020, 12:08 PM
Thank you, Mike!
