(#11651)
Arch30n's Avatar
Arch30n Arch30n is offline
Car: E93 M 335i N54 PPK DCT
Default 08-20-2021, 02:49 PM
Hi, I have installed latest G5_ISO_32_16_T9 but i can't find where to adjust map7 and map8 customs values like we do for map6 ? Can somebody explain how to do that ? Thanks
Default 08-23-2021, 10:25 AM
The user adjustment values are for all maps but with map 6 you can also set the boost targets, that is the only map you can manually set the boost targets by RPM.
Arch30n's Avatar
Default 08-23-2021, 10:44 AM
Sorry but if i read the changelog, it seems that we can now have customs values for map 7 and 8 :
*** Note lots of changes so don't update before reading ***
T6) Fixed bug with zero boost target going 0% WGDC
T5) Fixed bug with settings moving between maps on startups.
1) Made map6, map7, and map8 all user adjustable maps. FF is now unique to each map (0-8) and may need to be defaulted. Map6 fuel and duty bias still apply to maps 0-6. Map7 and map8 have their own unique boost, fuel, and duty bias profiles.
Note after updating some JB4 settings will be wiped out including mode 4/2 or 4/3 and menu12 base dutycycle, for those with a BEF be sure to select 4/2. Menu12 default is usually 2800rpm. Also warmup flash and a few other in dash settings may need to be selected again. FF may need to be manually set per map, or may default itself to 100 in some cases.
You'll have to enter and save boost, fuel, and duty bias settings individually for map6, map7, and map8. Previous map6, fuel bias, and duty bias settings may be wiped out. We will post templates on n54tech.
1) If options bit6 enabled for hybrid turbos map1 becomes 18psi, map2 22psi, map3 up to 25psi, map5 18-23psi autolearning.
2) Test changes to map5 operation.
3) Test changes to E85 flex fuel auto tuning.
4) Test fix for reported battery fault
5) Added FUA = 66 option to temporarily disable all JB4 safety systems
6) Revisions to port injection mapping scaling. You may need to adjust fuel bias up or down depending on the situation.
T2) Fixed issue with base dutycycle and some other settings not saving properly
T9) Made adjustment to spool up logic such that DWP will set not only the WGDC during low boost operation but also % of target to enable spool mode. For example a setting of 60 will hold WGDC at 100% until boost is 60% of target under heavy throttle.
T9) Possible fix for map5/map6 boost and duty bias settings not saving properly after reboot.
So did I read it wrong, or is this something new in development?
E93 2009 N54 DCT M PPK / FBO + Inlets + OCC + PCV / JB4 BEF with Custom Map
Car: 2008 E93
Default 08-23-2021, 11:24 AM
Yes, its all adjustable map 6,7,8 on that firmware.
Are you on JB4 mobile app ?
If so, go to map, it will show the map you are currently in. Click and it will show you all maps. Select the map you want(you may have to click twice), then when selected, go to user settings and set the profile to your liking.
Arch30n's Avatar
Default 08-23-2021, 01:20 PM
Yes, I use the mobile app on Android (no Bluetooth). I will give it a try, thanks !
Chatchie Chatchie is offline
Car: 08 535xi
Default 08-30-2021, 08:41 PM
Hey guys. New to the forum.
08 535xi Stock
Jb4 Bef everything updated.
My car is erratic. Sometimes it hauls sometimes it can barely hit 6k. I have logs but not sure how to upload them. Boost is not hitting target sometimes.
Ke93 Ke93 is offline
Default 10-01-2021, 07:13 PM
[QUOTE=Terry @ BMS;157920]N54 JB4 Default Settings:
@ Terry
Hey Thanks for the post man!
is this current input info as far as the newer firmware ad speced for a fbo jb4 n54 e93?
08 E90 335XI AWD
FBO Arm Motorsports KIT
ARM 5' FMIC
ARM 2' D.P
ARM CHARGE PIPE
ARM B.O.V
ARM DCI
JB4G5
MHD STAGE2+ BEF
NGK95770 GAPED@.022
ELDOR COILS
BMS CABIN AIR FILTER DELETE
