(#901)
SlicktopTTZ's Avatar
Turbo Lover
Car: 300zx TT, 1M
Default 01-21-2011, 09:40 AM
If you push the volume button in once it should be muted and not change around when you use the command center. At least that is how mine is. (2010)
DCTepper DCTepper is offline
Car: '07 SGM 335i
Default 01-21-2011, 09:41 AM
Just thought of an idea... If you changed the audio input to something without audio (i.e. CD player without a CD or AUX without an iPod plugged in) before entering the menu, you could avoid the radio shenanigans.
clifton23's Avatar
clifton23 clifton23 is offline
Default 01-21-2011, 09:43 AM
tried that. I use an ipod 99% of the time. switched to CD and it just says "no cd blah blah blah" and continues to play my ipod.
clifton23's Avatar
Default 01-21-2011, 09:45 AM
2008 here and it does. it seems to be more of a mute then an on/off switch
iv55 iv55 is offline
Car: 2007 335i coupe
Default 01-21-2011, 09:46 AM
Originally Posted by clifton23
am I dumb or what? I turn of my radio by pushing the volume button in. As soon as I enter command mode it turns back on. If I turn it off by pushing the volume button again, a touch of the volume up or down or channel select and it comes back on.
If you have iDrive like me then there isn't much you can do
I put my radio in Aux mode first, then you don't have to deal with the channel changing
2007 E92 N54, JB4 G5 ISO W/ BMS Flash, RB Turbos, Meth W/ FSB & CM10, BMS DCI, BMS OCC, CPE FMIC, AR Design CLDP's, DP Fix, Quaife LSD
vrod's Avatar
vrod vrod is offline
m power
Default 01-21-2011, 10:48 AM
Terry can you give us a quick rundown on how autotune is going to work on JB4? Thanks
Default 01-21-2011, 10:57 AM
It isn't finalized enough yet to do that.
Default 01-21-2011, 10:58 AM
yep. kind of sucks because it changes the song and sh!t.
Yeah we don't have the command to turn on/off the iDrive radios automatically yet. It's on the list of things to do though.
clifton23's Avatar
Default 01-21-2011, 11:09 AM
Default 01-21-2011, 11:12 AM
For those of you with iDrive, if you use the "auto turn off option", the radio turns off but doesn't turn back on until you restart the car right? Maybe as a short term solution we could have it send the corresponding turn on option when exiting the menu.
clifton23's Avatar
Default 01-21-2011, 12:22 PM
sounds like a permanent solution to me!
Default 01-21-2011, 01:30 PM
Does the auto turn off work to keep the radio off when in command mode? If the only problem is not being able to turn it back on I'll work on something for you to test.
clifton23's Avatar
Default 01-21-2011, 01:53 PM
I will check this afternoon and report back.
MusclezMarinara's Avatar
MusclezMarinara MusclezMarinara is offline
Ma need more protein !
Car: 2009 335i x drive
Default 01-21-2011, 02:11 PM
this was buggin me out i was like faackkk its broken lol
21 X5M Comp Donnington Gray
DeadEye's Avatar
DeadEye DeadEye is offline
Default 01-21-2011, 02:49 PM
Select the phone menu. When you press channel up/down it just selects the next/previous contact in your phone.
The volume still changes a bit but at least it stops your track being changed etc.
clifton23's Avatar
Default 01-21-2011, 02:58 PM
clifton23's Avatar
Default 01-21-2011, 05:02 PM
I cannot get the Auto Radio Turn Off/On feature to work on my car...
doesnt turn it off
Default 01-21-2011, 05:33 PM
Then that won't work for you then. Some iDrive customers complained the radio off feature worked... But the radio would not turn back on until they restarted the car.
clifton23's Avatar
Default 01-21-2011, 05:43 PM
interesting.. well its no biggie.. i can live with the volume changing.. Ill just go into phone mode.
Default 01-21-2011, 05:44 PM
doesnt turn it off
+1
Default 01-21-2011, 06:16 PM
We have iDrive on our development X5 and 328i so I'll spend some time with one when time permits and find some better radio on/off commands.
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 01-21-2011, 06:27 PM
After reading the iDrive problems, I never tried it. I'll try on my 09 135i and let you know which camp I fall in, the "turns off semi-permanently" or the "doesn't do anything" camp.
Default 01-21-2011, 06:28 PM
Nah we have more important things for you to test!
Jayock's Avatar
Enginerd
Car: 2009 135i
Default 01-21-2011, 06:31 PM
LOL..
After getting back from my awesome vegas trip, where food poisoning left me in the room for half the trip, it has been bad weather here (snowy). Tomorrow would be good, but I am scheduled to renew my CCW certification from 9-5. Maybe Sunday... supposed to be cold, but dry. Will send an email with test results and more discussion re: project black box (name made up after a glass or two of wine).
Default 01-21-2011, 06:33 PM
lol
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
