(#2101)
Synapse12's Avatar
Synapse12 Synapse12 is offline
Car: 2008 335xi
Default 04-25-2011, 12:08 PM
Upgraded to the JB4 the other day. Went right to map 5 and have been loving the results (2008 335xi - JB4, DCI, 93 octane). Kudos Terry!
+1 on the exhaust flap feature. Would be nice to easily change back/forth
mikeyt13 mikeyt13 is offline
Default 04-25-2011, 12:32 PM
I put all my commands in via laptop, what whould i do to leave the flapper always open?
Default 04-25-2011, 12:39 PM
4/5.
Bowser330 Bowser330 is offline
N54TECH FTMFW
Car: E92 335i
Default 04-25-2011, 12:49 PM
cool! home sick today from work, but will definitely try to get this loaded. yessss
Default 04-25-2011, 12:56 PM
THanks Terry, now if i could only remember how i uploaded the firmwar, lol
xbox_fan xbox_fan is offline
Car: BMW 335i E92
Default 04-25-2011, 01:30 PM
Ah new firmware, seems I'll be working from home tomorrow :D
Synapse12's Avatar
Car: 2008 335xi
Default 04-25-2011, 02:28 PM
I needed a refresher too:
http://www.n54tech.com/forums/showthread.php?t=8035
Synapse12's Avatar
Car: 2008 335xi
Default 04-25-2011, 02:54 PM
Upgraded to new firmware during conference call - but can't test for another couple hours. This sucks! lol
Terry - If I'm running Map 5 - will the map need to 're-learn'/autotune again, or will the auto tuned settings carry over (I'm assuming it will reset)? I think I read that it resets even with a map change. Is there any way to make this 'sticky' so that the data it collects will persist a map change?
Just curious to know how those setting changes work.
Default 04-25-2011, 03:01 PM
It will (and should) reset if you change maps. But not if you upload firmware.
Synapse12's Avatar
Car: 2008 335xi
Default 04-25-2011, 03:03 PM
Originally Posted by Synapse12
The quick version:
Uninstall old interface (computer software)
Download 4/20 interface and .hex files
Install new 4/20 interface
Connect to JB4
Go to File | Upload Firmware
Select the new JB4_042011.hex file
Wait for it to finish
Disconnect
Enjoy!
indy99gpgt indy99gpgt is offline
Engineer
Car: 2008 BSM 335i Coupe
Default 04-25-2011, 03:09 PM
Nice job terry. I was just wasting fuel in my garage playing with the exhaust flap. No wot runs for me today. We have lota of rain on the way.
2008 BSM 335i coupe-jb4.BMS intake.meth
1999 Pontiac Grand Prix-10.5PSI.PRJ LL Cam.supporting mods
Synapse12's Avatar
Car: 2008 335xi
Default 04-25-2011, 03:13 PM
What is the CAN_022111.HEX file for? Do I need to upload that as well, or is this for something else? A site search didn't seem to net any results
Engineer
Default 04-25-2011, 03:18 PM
Do not need that. That is the old firmware.
Default 04-25-2011, 04:45 PM
ANyone have lagfix set to 100?
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 04-25-2011, 04:46 PM
Default is 80, tried it on 100. Didnt really notice a difference
Jnic335i's Avatar
Jnic335i Jnic335i is offline
Car: 08 E92 335i
Send a message via AIM to Jnic335i
Default 04-25-2011, 05:12 PM
2008 Idrive here and it doesn't turn off. bummer.
JB4 | BMS DCI | UR DP | H&R | LC Z2s
Default 04-25-2011, 05:20 PM
Not surprised. I think that one is going to be model by model as there are lots of potential commands/modules to interface there. We'll just have to note which models those test commands work for and which ones they don't and go from there.
2Slow's Avatar
2Slow 2Slow is offline
Velocity Challenged
Car: 2007 335i AT
Default 04-25-2011, 05:29 PM
T, glad you have the AFR curves in there. I assume this is the same scale as the other AFR was (0-100)?
Also, I think I have the 1k resistors in there. How does that effect the AFR biasing that is output in the logs? Does it change the values or just allows for a lower AFR to be reached. IIRC, the fueling resistors just limit how low the AFR can go and there is no difference between the a 3K and 1K resistor at say an AFR of 12.
Jnic335i's Avatar
Car: 08 E92 335i
Default 04-25-2011, 05:51 PM
Sounds good. I love the Flap feature though, and i'm sure you will get those pesky I-drive commands working for every car.
Default 04-25-2011, 05:55 PM
Same 0-100 scaling. So now you get to enter your own curve. On nitrous it will probably be 100 all across.
WDBi's Avatar
WDBi WDBi is offline
Car: any
Default 04-25-2011, 06:50 PM
so what is the main summary of this just better nitrous & meth support as well as the flapper?
Default 04-25-2011, 06:51 PM
For many the only useful upgrade is the flapper. It's a lot of back end and higher performance stuff.
WDBi's Avatar
Car: any
Default 04-25-2011, 06:56 PM
ok thanks Great work Terry !!!!!!!
Kevron Kevron is offline
Default 04-25-2011, 08:23 PM
I just uploaded the new firmware, I have an '06 build and my iDrive didn't turn off. The iDrive thing doesn't bother me anyway cuz my stations would always change and then it would unmute so I just turn the volume all the way down when I make in-dash changes... Anyway, I tried out the CANflap option and I noticed that I can close it but then a few seconds later it just opens itself back up again, is that normal? I've never played around with the flap before today so I don't know when it's suppose to open or close but I thought it was suppose to stay closed at idle and low RPM conditions and that's why people were rigging it open...
Default 04-25-2011, 08:49 PM
With CANflap off it will do whatever it does stock. I think they open it at idle and close it during light cruise. It reopens under heavy throttle.
