(#51)
Mrpink Mrpink is offline
Car: M140i
Default 11-28-2017, 01:25 PM
Originally Posted by Bullitt1841
The only thing that makes me think about this is the fact that my Cyl 1 timing is ALWAYS worse than all other cylinders. I would like to know if other people notice this, too.
I even swapped the plugs and coils between Cyl 1 and 2 and it made absolutely no difference.
Pretty sure mine is the same too. Maybe itís due to the distribution of meth? Not ideals spraying through the TB I guess.
Itís why I always run Boostane in main tank to bring up the overall octane of the main tank fuel
Bullitt1841's Avatar
Default 11-28-2017, 01:38 PM
I'm talking waaaaaaaay before I installed meth. This was right after I installed the JB4 to log with no other mods. This was even happening on Map 4/0.
2018 Audi RS3 | Stage 1 E85 and 91 Flashes | JB4 for Logging
Wickedowesix's Avatar
Wickedowesix Wickedowesix is offline
Car: 540i G30
Default 11-28-2017, 10:33 PM
Well i tried just about everything today, 91 and meth, e30 and meth, e20 and meth, 91 and meth+e85.... i couldn't get or to boost more than 20 psi flat.... went up tp 70 add...... .maybe the turbo is different on the 540i....??
Default 11-28-2017, 11:10 PM
Logs?
Car: M140i
Default 11-28-2017, 11:24 PM
Itís the same with me, I run into the fuel cap.
Going to test bigger cm10 nozzles with a progressive flow
Default 11-28-2017, 11:42 PM
The JB4 should be able to get past the fuel cap by raising boost to whatever the turbo will make, your AFR will just be crap without supplemental injection.
Aren't you guys running EWG wires? If not, then you might not be able to boost much over stock. I'd like to hear Terry's input on this one.
Car: M140i
Default 11-28-2017, 11:47 PM
Yep I’m using the EWG harness.
As soon as I raise over 40 add my AFR spikes above 15AFR and then the car pulls back. I think that’s the fuel cap and a safety thing for going lean.
Default 11-28-2017, 11:57 PM
Yep Iím using the EWG harness.
As soon as I raise over 40 add my AFR spikes above 15AFR and then the car pulls back. I think thatís the fuel cap and a safety thing for going lean.
Yes, AFR goes over 15 during spool but goes down after a half second or so. The car usually does not feel very fast at first when it's that lean, but it picks up pretty quickly after that.
How long are you going lean for and are you aborting the run before you see how much boost you can reach?
Car: M140i
Default 11-29-2017, 12:14 AM
It’s more lean spikes higher up during the run which causes the car to pull back and hesitate, like the car looses 100hp for a moment.
I can send some logs if you PM your email
Car: 540i G30
Default 11-29-2017, 05:03 AM
I have ewg wires too... so i can't g9 pas 20pai boost no matter what the wmi add is set to
Car: 540i G30
Default 11-29-2017, 05:09 AM
Logs?
Here ya go
Car: 540i G30
Default 11-30-2017, 05:38 AM
Any input Terry...? What do you think...?
Default 12-01-2017, 09:20 AM
Looks generally OK to me. If you raised pid gain a bit say to 10 you'd probably make more boost, same goes for FF, but then you may wind up with DME BT moving around causing throttle and tuning issues.
Car: 540i G30
Default 12-01-2017, 09:29 AM
If i raise the PID to 10 i start throwing codes
Default 12-01-2017, 10:01 AM
What code?
Car: 540i G30
Default 12-01-2017, 10:28 AM
1235, 1112, 0408
Car: 540i G30
Default 12-01-2017, 02:44 PM
Is there a way to test out that the EWG wires are working properly? Still puzzled as to why i cant go over 20psi.....
Default 12-01-2017, 02:50 PM
1235, 1112, 0408
Is there a way for you to post a screenshot of those codes with explanations? I'd prefer not to have to Google each one from my phone.
Car: 540i G30
Default 12-01-2017, 03:00 PM
Tbey all say description not found
RMM RMM is offline
Car: 120i
Default 12-02-2017, 08:39 AM
@Wicked
FF = 0 on your log, on my car with EWG there is FF set by duty bias, and I tuned the FF values so they are just above the WGDC (PWM) near target boost
Have you filled in and tuned your "DUTY BIAS" setting? Almost like you put in all zeros for them?
Figure 1) Wicked log, looks like FF = 0, based on my experience this is not correct, or means that duty bias = 0, EWG may not have any effect or is providing no WG bias
@All
Do you guys also notice that the boost after throttle, "avg ign adv" never goes above 21.3 is that senor or just read back issue?
Look at the flat top in black curve at 21.3 in some of my log below.
Figure 2) my log 50add where I have tuned the FF values
Figure 3) another log with 70 add, showing that "avg ign" or the boost after throttle, flat topped at 21.3 psi, over a wide RPM range, is this anything to worry about or just sensor or FW limitation?
Default 12-02-2017, 11:57 AM
Originally Posted by RMM
why is FF = 0 on your log, on my car with EWG there is FF set by duty bias, and I tuned the FF values so they are just above the WGDC (PWM) near target boost
Do you guys also notice that the boost after throttle, "avg ign adv" never goes above 21.3 is tat senor or just read back issue?
You can that the flat top in black curve at 21.3 here and also example of my FF / PWM curve B58 probably different bias values but should have something
Who are you directing your questions to and which logs are you referring to?
Regarding the "flat readings" in logs, that is when the JB4 is only reading a signal at a certain refresh rate and it is only reading a value once per large time interval. This happens occasionally and not for all parameters being logged. So other parameters are being refreshed, but not all. Basically, when you see something flat like that, everything in between the start and end points are not accurate. The JB4 is just not receiving a signal during that time.
Also, please try to proof read your posts because we get really confused when words are missing
Car: 540i G30
Default 12-05-2017, 09:30 AM
Any more e30 or e85 testing bro..?
Default 12-05-2017, 09:38 AM
I've been running E40, boost juice, and up to a 50 add recently without issue. Logs look good.
I'm waiting until I run out of boost juice to put E85 in the meth tank. Almost out, should be this week.
Car: 540i G30
Default 12-05-2017, 09:48 AM
So 91 + e40 with boost juice is 50meth/50water correct?
Car: 540i G30
Default 12-05-2017, 10:04 AM
How much boost are you hitting with 50add and whats your afr?
