Renato B58 Renato B58 is offline
Car: Bmw M140i
Default B58 FF wiring needed - 10-27-2018, 06:01 AM
Hey Guys
I cant seem to find any wiring diagrams or setting for the ff wiring on b58 m140i can you 1 assist please thanks gents
Bullitt1841's Avatar
Default 10-28-2018, 10:32 AM
Yeah, still not added to the instructions or sticky thread
EWG Purple - # 9
EWG Blue - # 16
FF Green - # 21
FF Black - # 4
Car: Bmw M140i
Default 10-29-2018, 12:36 AM
Thank you for that much appreciated
808ron 808ron is offline
Car: 2018 X3 M40i
Default 10-29-2018, 11:19 AM
Did you just buy the B48 FF wires? I didn't see anything for the B58.
kyleralph078 kyleralph078 is offline
Car: bmw m140i
Default 11-02-2018, 05:24 AM
i purchased the small type connector for a 2016 m140i, just curious as well are there any settings to change once ive connected the FF harness?
Default 11-02-2018, 08:46 AM
That is the correct one.
Shouldn't need to change anything, what is your open loop value at?
Car: bmw m140i
Default 11-02-2018, 12:20 PM
Open loop value is currently set to 60
Andrew1810 Andrew1810 is offline
Car: M140i
Default 11-06-2018, 02:55 AM
Sorry to hijack, but being related, is this sensor that I've pictured the one for the FF wiring ? Also is this the bigger style connector ?
Car: Bmw M140i
Default 11-06-2018, 02:58 AM
Yep thats the plug, but not sure on the size
Car: M140i
Default 11-06-2018, 03:11 AM
Thanks,
Actually looking at the shape of the connector itself it might be the small one.. Hoping Terry/Payam can confirm before I order though
Car: Bmw M140i
Default 11-06-2018, 03:15 AM
Looks the same as mine tho, but i have picked up a problem i connected it and my phone was connecting to the jb but once i stopped switched of now wont connect says serail port unavailable ever since i connected the ff wiring and havent had time yet to unplug
Car: M140i
Default 11-06-2018, 03:54 AM
Which size connector did you buy ? And also was your phone on low battery or anything when you got the error ? Think that was an early issue, don't know if it still applies
Car: Bmw M140i
Default 11-06-2018, 03:58 AM
I think its the small connector, my phone is always on charge so dnt think so maybe i made a mistake and used the wrong pin out
Default 11-06-2018, 11:31 AM
Small connector.
Car: M140i
Default 11-07-2018, 02:29 AM
Small connector.
Perfect, thank you for confirming
Car: M140i
Default 11-13-2018, 07:28 AM
Iíve just installed these along with EWG harness, going to get some logs when I can. Are there only certain maps that these function in ?
Default 11-18-2018, 09:24 PM
Yes, EWG wires help in any of the absolute target maps: 6 and 7. I don't quite know if the FF wires only help in absolute maps, but I would assume it helps all.
The FUA setting should also help with all maps, I believe.
