DongHyup DongHyup is offline
Car: 530i xd
Default Problems after installing jb4 - 12-03-2021, 12:16 AM
After installing jb4 on b46 engine, if EWG connector is installed, warning light is generated. electrical wastegate, position sensor, electric: short circuit to plus
Reduced power mode
If I remove the EWG connector, it's OK.
What could be the problem?
Car: Evo VIII
Default 12-03-2021, 10:50 AM
Ensure your installation follows the guide found on https://burgertuning.com/products/n5...nt=18543513219
Default 12-03-2021, 12:20 PM
Not all B48 models support the EWG connection, and it's usually not needed for B48 unless you're running a larger turbo, so I'd just leave it disconnected if you're having an issue with it.
Car: 530i xd
Default 12-04-2021, 04:31 AM
They said that the B48 engine does not support EWG connection, but my car is a b46 engine. Are B46 and B48 engines the same?
akayya akayya is offline
Car: BMW 330XI
Default 12-20-2021, 07:41 AM
My car has B48 engine (2018 330 ixdrive) And I just installed two days ago, I installed ewq. But I did not have any problem. your problem is interesting
