Carlos Di Lauro Carlos Di Lauro is offline
Car: 2021 Toyota Supra
Default 21 Supra DP Logs - 12-02-2021, 08:08 AM
Just installed a ******* DP and did some logs to be revised.
Tried Map 5 with E30 mix and noticed the car dropping power on the top end and you could hear the throttle closing and opening. Next I tried Map3 as it has worked better for me before and it did feel a lot smoother.
Let me know what you think or if I should change or try something else, Thanks!
Car: Evo VIII
Default 12-02-2021, 10:27 AM
Map 5 is giving you quite a bit of timing corrections, and especially in the top end. What sparkplugs do you currently have?
Default 12-02-2021, 10:30 AM
The OEM ones. Haven't touched them since I got the car
Car: Evo VIII
Default 12-02-2021, 10:39 AM
If you upgraded to the NGK laser iridium and gapped them down to .019-.022, map 5's timing corrections would most likely tighten up and feel much better.
Default 12-02-2021, 10:48 AM
Ahh okay thanks, I'll try and get those then.
Also comparing Map3 to Map4 should I try Map4?, is it better/more power as it's meant for E30?
I've seen other people Dyno the cars and found that Map3 tends to run the best but kind of want the opinion on someone more knowledgeable than me.
Default 12-02-2021, 12:26 PM
Your map3 run looks good but load the attached boost and duty bias and log map6 for comparison. Map3 is additive based, this map6 is absolute target based.
Default 12-02-2021, 02:27 PM
Didn't get to drive it too long so I didn't get a good comparison from one to another but here's the log for Map 6.
Thanks for all the help so far!
Default 12-02-2021, 02:44 PM
EWG connector attached right?
Looks good to me. You can stick with whichever you prefer.
Default 12-02-2021, 02:58 PM
I think it is, (Installed the JB4 a month ago) I'll go ahead and double check it after work though.
I'm a try and dyno the car in a couple of weeks so I can better compare both and see where the car is at now.
Thanks for the help!
