MaverickCruise MaverickCruise is offline
Car: 328i
Default about Default Wastegate Position - 11-30-2021, 12:49 AM
Is the value meaning Wastegate Position Percentage of opening?
Set 60, Wastegate open 60%? or close 60%
If set 100,Wastegate full open?Or full close?
Because I upgrade big turbo, over 5000RPM can hit target boost near 20
3500rpm 9.4psi
4000rpm 12.3psi
4500rpm 15.9psi
So I want to change Default Wastegate Position Seting to boost fast at low rpm,can you help me
Car: 328i
Default 11-30-2021, 12:54 AM
And my big turbo have original exhaust turbine, upgrade compression turbine from 6+6 blade to 11blade ,and the size from original 42/56 to 49.5/60
Is the turbo collocated reasonable?
Car: Evo VIII
Default 11-30-2021, 11:13 AM
3500rpm 9.4psi
4000rpm 12.3psi
4500rpm 15.9psi
60% Closed
Car: 328i
Default 11-30-2021, 11:59 AM
Originally Posted by Cannon @ BMS
60% Closed
thanks a lot
So,i can set it to 90-100,close more Wastegate to boost fast,right?
Default 11-30-2021, 12:16 PM
It depends on the JB4 firmware version. Some versions like EWG don't use the DWP setting at all. For PWG vehicles its a 0-100 scale based on how aggressive WGDC is during low throttle/low boost.
Car: 328i
Default 11-30-2021, 01:31 PM
My 15 328I is EWG,and the firmware version is OBDII_EWG_T4
Is it can be work?
Car: 328i
Default 11-30-2021, 02:10 PM
Is there any way to make EWG firmware can use DWP setting?
This may be important for users of large turbines
Car: 328i
Default 12-01-2021, 11:56 AM
I tryed set DWP to 100
Then looks like working?
3500rpm 9.4psi ==> looks same
4000rpm 12.3psi ==>13.X
4500rpm 15.9psi ==> 18
