(#51)
Mihail Mihail is offline
Car: Bmw M140i xdrive
Default 07-19-2021, 04:55 AM
JB4 Map 2. E20.
TMR's Avatar
TMR TMR is offline
Default 08-02-2021, 09:11 PM
Terry I need a 6 speed JB4.
Donald
Mattssi Mattssi is offline
Car: 2000 Ford Escort
Send a message via AIM to Mattssi
Default 08-03-2021, 11:31 AM
Me too. And when will this be out of "beta"?
Matt
G80 M3
Old 135i 'vert
1st HPFP (881) down @ 1500 miles
2nd HPHF down @ 3000 miles
Fuel Pressure sensor down @ 8000 miles
Tail lamp replaced @ 8500 miles
Lemoned @ 9200 miles
On to the next I guess!
Default 08-09-2021, 01:43 PM
Donald
What is a 6 speed JB4 lol. JB4 is compatible with manual and auto trans, always has been.
Default 08-09-2021, 01:44 PM
It's been pretty stable so we may remove the BETA designation within the next few weeks. Like to get a few hundred units out around the world before we do generally.
circa77 circa77 is offline
Car: 2022 G80
Default 08-14-2021, 01:27 PM
So, 2 quick questions.
1st -
In the map guide, you list some maps like map2 as "4psi peak request over stock".
Since Base 6Mt G80s and the M3C request different amounts of boost at stock, does this map behave differently between the base and competition? Or is it normalized across all versions of the G80/82 (since they are the exact same engine)?
2nd -
I'm seriously happy you list the recommended fuel types for each map, but do you have expected gains for each? The dyno images on the product page are great and all, but they don't indicate which platform or map or fuel in the notes.
I think a lot of 6MT buyers (like myself) are going to look at correcting BMWs absurd downtuning of the base with a piggyback system, so it would be great to better set the expectations for those of us dumb enough to have bought the 3-pedal version of this magnificent car.
Default 08-15-2021, 01:21 PM
1st -
2nd -
+1 I'm curious as well.
Matt
G80 M3
Old 135i 'vert
Default 08-25-2021, 10:04 AM
1st -
2nd -
Additive maps are added on to the factory target while absolute maps run a fixed target. Generally speaking there is no power difference between comp and non-comp vehicles when JB4 tuned. The only difference is what map is required to get to the desired power output.
If you have specific questions on what map to run we'd need to see a JB4 log from your specific car/fuel/situation.
The posted dynos have their details listed...
https://burgertuning.com/products/s5...be67c295&_ss=r
Default 09-23-2021, 10:39 AM
Our G80 S58 intakes are shipping...
https://burgertuning.com/products/bm...77247b50&_ss=r
https://burgertuning.com/products/fr...77247b50&_ss=r
Default 11-10-2021, 02:08 PM
The Fuel-IT kit for the M3/M4 is ready, featuring stainless braided fuel lines! Super clean.
https://burgertuning.com/products/fu...-g80-m3-g82-m4
chris3g chris3g is offline
Car: G80 M3
Default 11-16-2021, 09:12 AM
[img]https://cdn.shopify.com/s/files/1/0890/2048/files/S58-flex-fuel-sensor-m3-m4-g80-g82-g83-bmw_1024x1024.jpg?v=1636573235[/ img]
[img]https://cdn.shopify.com/s/files/1/0890/2048/files/S58-flex-fuel-sensor-m3-m4-g80-g82-g83-bmw-install_6406313e-3fda-467e-8ab2-490487e42c41_1024x1024.jpg?v=1636574340[/ img]
Which wire should be tapped for power?
Default 11-17-2021, 06:40 PM
The G8X flex fuel kit and install location...
Closeup of install location...
Here's the complete installation guide...
Remove the strut brace with a 15mm socket or wrench and then remove the engine cover.
Remove the gray safety clip on each end of the stock fuel line...
To remove the stock fuel line, let the car sit overnight so there is no fuel pressure. Then push the line on as much as possible, depress the black clip, and then pull the line off.
Install the fuel lines, analyzer, and harness on to the ethanol sensor as shown. Connect the ends with the 3/8" fuel fittings to the ethanol sensor as shown.
Here's a video showing how to connect the fittings.
How to install our Cam-Lock! style fitting. - YouTube
Install the new fuel lines with the sensor and analyzer installed...
Connect the analyzer to ground...
Connect the white wire to the JB4 pin 4 of the DB25 connector...
Connect the power wire...
Default 12-05-2021, 09:09 PM
Originally Posted by Superfly_whip
Installed a jb4 and ***-less downs on my g80 canít seem to get this code to go away.
If you need direct support you'll want to email us. I'm already helping you via email I believe.
135iscameron 135iscameron is offline
Car: 2013 135is
Default 12-16-2021, 12:08 AM
Hey!
Just got the R44 titanium exhaust + dwnoipe and a JB4 for my 22 G80 M3 Comp X-drive. Haven’t used a JB4 since I had a 1 series a long time ago. I was hoping someone could suggest which map to run with the exhaust setup on 91 and which map to run on an ethanol blend(and what blend I should target). Thanks!
Default 12-16-2021, 12:28 PM
Map recommendations are on the first page of this thread. E30 would be a good target for you.
X4MCOMPROCKET X4MCOMPROCKET is offline
Car: X4M COMPETITION 2021
Default 12-16-2021, 02:48 PM
Just had my JB4 and the Flex Fuel-It kit plus catted pipes installed in my 2021 X4M Competition, and I wonder if anyone can recommend me a Miami based tuner with a 4x4 Dyno that can do custom work to get my maps with all the mods. Thank you in advance guys!.
JB
Default 12-18-2021, 07:09 PM
Email me some logs to start and I can make sure it's working as expected. Terry@burgertuning.com
corbs09 corbs09 is offline
Default 01-03-2022, 07:55 PM
What spark plugs are recommended with more aggressive JB4 maps on S58 motors? Thank you!
Default 01-04-2022, 09:49 AM
We're running the factory plugs and gap on both of our S58s right now. We've been poking around for upgrades but not found anything worth using, yet.
Default 01-12-2022, 10:48 AM
Hi Terry, using the BC button to change exhaust flaps is not currently working on my jb4. I can connect to the bluetooth but pushing the button quickly changes the dash menus and holding it does nothing. Does the car need to be in a certain mode to make these changes? Thanks!
Default 01-12-2022, 12:36 PM
That is for the X3/X4 only currently. M3/M4 uses different flapper commands and we haven't found them yet.
777300ER 777300ER is offline
Car: 2021 M4
Default Yesterday, 12:58 PM
Any idea when the fuel pump control harness is coming?
