snowfree52 snowfree52 is offline
Car: SQ5 354 / Golf R 310
Default 07-31-2020, 01:11 AM
on man, I want to sell my SQ5 so bad... around 700hp at the crank ?
Default 08-25-2020, 12:47 PM
Nice shot of our new in house S58 development car. Won't need to keep borrowing the Fuel-IT X4 now.
Working on version 5 of the firmware as I type!
Default 11-06-2020, 09:45 AM
Few dragy runs the other day from our JB4 only X3M (non-comp) on E30. Overall pretty solid! JB4 runs were on map4 at around 22-23psi. When time permits will crank it up further to get in the 10s.
ZTJ53 ZTJ53 is offline
Car: G82 M4
Default 02-19-2021, 01:15 AM
Terry, for the G82 M4 are you able to confirm whether the JB4 is able to permanently delete the fault codes generated if the OPFs were to be removed on the Euro spec car.
Default 02-19-2021, 11:28 AM
We don't do anything with emissions related codes. All codes can be deleted but will not be prevented from re-appearing.
Default 03-29-2021, 04:11 PM
Making good process on S58 fuel pressure control. This will allow us to safely run higher E85 mixtures JB4 only. Once the changes are finalized will provide hardware free of charge to any of our S58 BETA customers.
Default 03-30-2021, 11:34 AM
Going to have some G80 M3 JB4 dynos to post later today, testing being done by Tony@Vargas...
Kingmonkey Kingmonkey is offline
Car: F90 M5
Default 04-03-2021, 04:40 PM
Sweet can’t wait !
Default 04-04-2021, 09:13 AM
Pretty good start. E30 fuel, 100% factory M3.
Erikb Erikb is offline
Default 04-04-2021, 01:50 PM
Terry, what would you expect on 93 octane?
Default 04-04-2021, 08:01 PM
I think 560-575whp should be safe on good 93. We're still in the early days of figuring out what tuning works best for what fuels on the platforms in a way.
Default 04-05-2021, 01:10 AM
Thanks, so around 50 hp more standard and tuned compared to the f80.
luchocamp's Avatar
Default 04-05-2021, 07:53 AM
but F8x over 5 years development .. G8x only a few days
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW M2LPower
Default 04-05-2021, 02:27 PM
It will be interesting to see some track runs against the two.
Just going off some numbers from Shift Sector this weekend I think Vargas ran 155mph 1/2 mile in his JB4 G80 AT vs. Payam who ran 149mph in his FBO F80 MT.
zerix's Avatar
zerix zerix is offline
Car: 99 M3
Default 04-21-2021, 06:06 PM
Terry do these G8x's have charcoal filters? Also was watching the RKTUNES video about comfort/sport throttle problems, is that something you can work out on your end?
ibu11et ibu11et is offline
Car: G82 M4 '21
Default Install Instructions - 04-22-2021, 04:14 PM
I just want to make sure the installation instructions are the same for the M3/M4. The link on the website takes you to the X4M instructions which has a totally different cover and intake system.
Not sure about the pulling the wheel part
Is this where you’re talking about? Many of the hoses are routed differently and I just want to make sure.
Car: G82 M4 '21
Default 04-23-2021, 05:24 AM
So I ended up finding IMAP sensor. On the G832 platform, the best way to get to the sensor is from the top. It is completely inaccessible through the method listed in the X4 instructions linked to the product on the website.
This is what it looks like after removing the driver's side wheel.
If you remove the drivers side air filter box and loosen this nut, you can move this housing out of the way. You can use the hands of a nine year old and a small screw driver to pop the connector off. The tricky bit is getting the male connector from the JB4 connected to the factory female connector. Since the connector is very long and the connecting wires are relatively short, I had to use my extended needle nose pliers to hold the male connector and my hand to get the female on. After cursing whoever at BMS told me the instructions were exactly the same. I got the unit on.
After removing the airbox.
After loosening this nut and pushing the housing out of the way.
While you're in there, you might as well get rid of the air silencer crap.
chris3g chris3g is offline
Car: G80 M3
Default 04-29-2021, 08:42 AM
[ IMG]https://share.icloud.com/photos/0TE3J83z6Qg2VCwdiiMZL_kyQ[/IMG]
[ IMG]https://share.icloud.com/photos/0E8JGBC-1uIGEWdJznyEQiF7Q[/IMG]
[ IMG]https://share.icloud.com/photos/0Fpkj2tlbxsOVNqgcdW61TvoQ[/IMG]
[ IMG]https://share.icloud.com/photos/0sJ0UNbp_KPx7EOgwKBA9A3_g[/IMG]
[ IMG]https://share.icloud.com/photos/0e6QdQsXP9PpFl4QWgt1rdPeg[/IMG]
thanks for the photos, was really helpful for me to find all the connections. How did you run the OBD Cable?
Default 04-29-2021, 10:32 AM
Keep those photos rolling! As well as install tips. We'll use them all to remake a G80 specific install guide.
Default 05-10-2021, 11:33 AM
Any update?
Does BMS have its own G80/G82 for testing?
Sdt777 Sdt777 is offline
Car: BMW M4
Default 06-02-2021, 02:01 PM
If Manhart MH3 600 with their tuning box can do 635 HP then the JB4 should be able to do it also?
Default 06-03-2021, 08:22 AM
Any update?
What sort of updates are you looking for? We've tuned maybe 100 G80s now with the JB4, solid results across the board!
Default 06-03-2021, 08:23 AM
With the JB4 you can push the tuning as aggressively as you want! We've seen some crazy numbers reported running E85 mixtures for example.
chinh_us chinh_us is offline
Car: 2021 G82 M4
Default 06-09-2021, 04:17 PM
Just installed today, thanks for the great product.
On the G82 you can drill out the firewall rubber indent for the OBD cable. Looks slightly different from the instructions but in the same general vicinity.
Default 06-10-2021, 07:57 AM
Awesome, thanks!
