MNmaverick MNmaverick is offline
Car: 2022 X5 m50i
Default 2022 X5 M50i - recommend map - 12-02-2021, 06:43 AM
Hey all,
Short time lurker - first time poster. Sounds like the M50i is a n63r engine type? Anyways, it appears folks are recommending the map 1 vs 2 presently for a daily driver? Does that sound correct? I saw one map6 someone had custom built but unsure if anyone else has any more refined map 1 or map 2 like tunes they are running.
Thanks again!
Car: Evo VIII
Default 12-02-2021, 10:42 AM
Map 1 is less boost so naturally it will be easier on your mpg's. Although, it really only applies if you have a led foot. Map 2 also requires 93 octane or better.
Car: 2022 X5 m50i
Default 12-02-2021, 10:48 AM
In your opinion is map 2 stable enough to run as a daily driver?
phaser's Avatar
phaser phaser is offline
Car: X5 M50i
Default 12-02-2021, 03:10 PM
Originally Posted by MNmaverick
Hey all,
Thanks again!
I have a 2021 M50i and am condidering a JB4. Are you happy with it? Can you feel the torque increase, is the additional power linear? Very interested to hear.
Car: 2022 X5 m50i
Default 12-02-2021, 03:13 PM
Installing on the 13th so I guess we will find out! Not much feedback on custom maps or even if straying from map 1 for our engine is advisableÖ
Car: 2022 X5 m50i
Default 12-02-2021, 03:36 PM
Thank you for that insight - from my research on here that’s what I’ve been suspecting. I’m ok with Map 1, I assume further tuning and research will improve down the road. Jb4 still the way to go here over a racechip if I’m just doing stage 1 stuff?
phaser's Avatar
Car: X5 M50i
Default 12-04-2021, 01:13 PM
Map 1 is +4 lbs.?
phaser's Avatar
Car: X5 M50i
Default 12-05-2021, 07:40 AM
Originally Posted by Mike_L
You have an N63B or TU3. I wouldn't run Map 2. I tried and it was significantly slower than Map 1, even with E30 in the tank. I think what has been said before is true, the Maps were designed around the N63R (TU2) engine, that only made 456hp and less boost. For the newer N63B, the turbos are bigger and make more boost, so adding 6psi to it puts us over 20psi, which the Maps weren't designed for. Causes them to lean out too much on the top end and hurts power.
Your M550i has the same engine as my '21 M50i.
How would evaluate the improvement with the JB4 in place on Map1. Is the increase in torque noticeable etc.? Thanks in advance for insights here as they seem difficult to find.
Boosted_8 Boosted_8 is offline
Car: M550i
Default 12-05-2021, 02:13 PM
Map 2 on the 523hp motor is a bit wacky. Asking for 17-18psi at redline is just too much for these turbos.
phaser's Avatar
Car: X5 M50i
Default 12-05-2021, 04:30 PM
Thanks Mike, a noticeable bump over stock which I think is very strong will be mighty fine.
Car: 2022 X5 m50i
Default 12-06-2021, 02:54 PM
Thanks for the insight mike, much appreciated!
Antec800 Antec800 is offline
Car: 340ix
Default 12-12-2021, 07:45 PM
Any insight to this terry or anyone from bms? Seems quite worrying losing power on anything other then map 1 on newer n63s
Car: Evo VIII
Default 12-13-2021, 11:15 AM
Start uploading logs.
Car: 2022 X5 m50i
Default 12-13-2021, 11:20 AM
Any additional context on how to do that or what youíre looking for exactly? I think we were looking for more detail then one sentenceÖ
Car: 2022 X5 m50i
Default 12-13-2021, 02:28 PM
Agreed with Mike
phaser's Avatar
Car: X5 M50i
Default 12-13-2021, 04:33 PM
Nah, thatís not the answer. You guys gotta get one in house and actually tune it instead of relying on data from the older motor. Carbahn is making 640hp and nearly 700ft/lbs with their piggyback, using just MAP tuning on 93 octane. You guys are using obd2 as well, so thereís zero reason you shouldnít be making that or more. Somebody actually has to give a damn though, and it kinda feels like nobody does and weíre an afterthought.
Very good point you make Mike and well stated.
+3.
phaser's Avatar
Car: X5 M50i
Default 12-13-2021, 04:37 PM
Most interesting about Carbahn.
zse8h zse8h is offline
Car: M5501
Default 12-19-2021, 12:02 PM
Mike exactly. This reason alone is why I dumped JB4 and went with racechip. Racechip has actually had the 2020 + cars on a dyno. Map 7 on racechip blows map 1 or 2 jb4 out of the water. It nice to have a product that is designed and tested rather than the other option.
2021 M550i
Bernina Grey Amber Effect
GPower High Flow Air Filters / Charcoal removed
GPower Axel Back High Flow Sport Silencer
HardRace rear sway bar and Dinan lowering springs
Barracuda Racing Wheels (Inferno)
Race chip Map 7
Retired:
2009 335xi
Completely Moded out
Beat corvettes - they were pissed
Car: 2022 X5 m50i
Default 12-20-2021, 11:00 AM
Update: uninstalling jb4 and on to the CarBahn piggyback. Jb4 kept throwing codes and response time to my shop installers was bad...needless to say this tune isn’t ready for the 2022s.
Car: M5501
Default Drive train loss - 12-21-2021, 08:18 AM
Anyone know the loss between the flywheel and pavement?
Example: if I am making 698 hp at the flywheel what will the car put down after drivetrain loss? Realistically?
2021 M550i
Race chip Map 7
Retired:
2009 335xi
Car: 2022 X5 m50i
Default 12-21-2021, 04:25 PM
Yes, itís the m550i piggyback just not sold on retail yet because the instructions havenít been formally updated. However if you call Chris at Carbahn he will work with your local dealer to ensure everything is seamless.
phaser's Avatar
Car: X5 M50i
Default 12-21-2021, 05:25 PM
Thanks for the info Man, I will call him.
phaser's Avatar
Car: X5 M50i
Default 12-21-2021, 06:39 PM
Thanks for the link Mike, sure looks easy enough. Amazing how Carbahn gets +114 HP while the JB4 claims +59, big difference. No OBD connection with the Carbahn either.
Car: M5501
Default 12-22-2021, 03:46 AM
I would think that JB4 Stage 2 (If working properly) could do this, and so does Racechip (Map7). Remember, this is at the flywheel, not the pavement/wheels. Racechip promotes 60+ at the wheels, so a total of 593 HP and JB4 Map 2 should be somewhere around this. I wouldn’t get too excited about CarBahn. Carbahn interchanges flywheel with what Racechip and Jb4 promote at the wheels.
Carbahn shows almost 600hp at the wheels on 100oct. This is where I am most likely using 102oct from Aral here in Germany.
CarBahn = $1250
JB4 = $599
RaceChip = $799
Don’t be fooled; you get the same performance from all 3; however, JB4 doesn't seem to have put in the Dyno/development time to see decent results from their Map 2.
Therefore it’s Race chip or Carbahn for me.
Just a few thoughts.
Merry Christmas (Frohe Weihnachten)
2021 M550i
Race chip Map 7
Retired:
2009 335xi
phaser's Avatar
Car: X5 M50i
Default 12-22-2021, 06:22 AM
CarBahn = $1250
JB4 = $599
RaceChip = $799
Merry Christmas to you also from the US!
I looked again and it is Racechip that claims 60 HP and JB4 100, sorry.
I guess the Racechip on map 7 makes more than the 60whp(around 75flywheel) on one of their lower power maps. This sure is confusing.
A good flash tune sure would be nice.
