(#4026)
Angel67's Avatar
Angel67 Angel67 is offline
Car: 335xi
Default 08-22-2021, 02:42 PM
Terry, just downloaded most recent BEF files. Two questions: 1. There's no Hybrid Pump BEF - are you planning to do one? 2. There's a Pump and a Pump USA - what's the difference - which one would be better if I'm running Canadian 94 (basically 91 with E10 mixture)?
E92 335xi
ScottRAus ScottRAus is offline
Car: BMW 335i E92 N54
Default DTML Shadow Code - 08-22-2021, 08:15 PM
Originally Posted by ScottRAus
I also have a DMTL shadow code showing up when scanning codes with MHD. It's an Australian model which is closer to the European models so wondering if anyone knows if this could be related?
Thanks in advance.
Quick update, this is a code for US cars, the Australian delivered models don't have the heater, so the tuner disabled the shadow code in the BEF.
BMW 335i E92 N54 6AT
JB4 Custom BEF / xHP
19t FBO Pump98 with WMI
bekloptupus bekloptupus is offline
Car: Alpina B3 BiTurbo N54
Default Alpina B3 N54 + JB4 - 09-08-2021, 04:24 PM
… moved to a different thread for more visibility and relevance.
wmtodd wmtodd is offline
Default RB hybrid map? - 09-21-2021, 01:52 PM
So I purchased a car- with RB hybrid setup about a month ago. Then I had a break issue and they needed to reset the whole thing to finally get the break light off.
At any rate now I realized (just got the car back today) I am only using the stock JB4 tunes and the backend tune is gone.
RB Hybrid turbos TD04 17T w/billet wastegate upgrade are on the car, along with highflow inlet/outlets
Do I start with the PUMP file? or the Hybrid file? I don't really desire to run e85.
Any help would be appreciated.
Angel67's Avatar
Car: 335xi
Default 09-21-2021, 02:16 PM
See my questions above. There doesn't seem to be a hybrid specific pump BEF.
E92 335xi
Hokie135 Hokie135 is offline
Car: 2009 135i
Default 09-22-2021, 06:37 AM
I'm dialing in my Pure Hi-Flows now and testing the different maps so I had the same questions.
In short, if you are only using 93 Octane or up to E30 mixture, you'll want to start with PUMP. You are correct there are no specific PUMP Hybrid maps. Which is confusing but it does make sense once you understand Bit6 and the other settings.
The next map you may want to experiment with once you have PUMP dialed in is RACE. This will give you more aggressive timing or allow you to work with some lower E85 mixtures. If you will never try E85 mixtures, I don't think you'll need the E85 maps.
I am personally experimenting with RACE now.
I hope this helps!
pormitsu917 pormitsu917 is offline
Car: 2011 bmw e90
Default 09-28-2021, 08:29 AM
With bef pump i need to plug the flex fuel wires to run e25 or e30?
Thanks in advance
Dmack Dmack is offline
Car: 2008 BMW 135i
Default 11-16-2021, 01:28 PM
Is the Bimmerboost flash software no longer available?
Default 11-17-2021, 10:09 AM
Yes that was discontinued, MHD is the only N54 option now, as far as I know.
Car: 2008 BMW 135i
Default 11-17-2021, 10:13 AM
Hmm. I still have BB Flash on an older laptop that works fine. I guess there would be no issue using that to load the newer BEF flash revisions, right?
dee_mm_cee dee_mm_cee is offline
Car: ‘08 335xi E92, ‘04 325Ci E46
Default 11-26-2021, 05:15 PM
Hello,
I am running some 17T TD04 eBay hybrids. I am confused which map to flash. Fresh install on a JB4 purchased new in October.
First post here! Just got a 335 and did FBO. Going to flash cad tomorrow at mechanics and drive it home. Super pumped! This forum is a wealth of knowledge!
ChrisCC ChrisCC is offline
Car: 135i N54
Default 11-28-2021, 12:14 PM
Originally Posted by dee_mm_cee
Hello,
At a guess Id say PUMP BEF would be the one to run but could be HYBRID RACE, its hard as im in similar boat so would be good to see what Terry/BMS recommend.
IM also on 17T's and looking to do this also. Run 99RON here in UK just from the pump.
Default 11-28-2021, 01:16 PM
My confusion was mostly on the software version - I get that I will read that from the ECU when I connect now.
I am thinking I should be running PUMP USA but would love to know the difference between PUMP and PUMP USA. My car is a Canadian car with a KM/H only gauge cluster but says USA for the region of the car when I run the VIN on realoem.
Default 11-28-2021, 04:51 PM
IMO, I would enlist the services of a tuner at this point to guide you through the setup of the JB4 and provide you a custom BEF for your car.There are so many different settings with JB4 that even small changes can have a big impact and getting it dialled in can be a challenge if you're new to the platform. Don't want to sound like a shill but JSRTuning has a Black Friday sale on now and he's super affordable even at full price.
Default 11-28-2021, 08:08 PM
Hello,
That depends on the fuel being used, but there is a hybrid turbo thread that covers the basics: JB4 N54 Hybrid Turbo Setup Directions - N54Tech.com - International Turbo Racing Discussion
Car: 135i N54
Default 11-29-2021, 05:35 AM
Hi Terry,
What JB4 BEF would you recommend running on 17T Hybrids on pump fuel - super unleaded 99RON UK?
Would it be PUMP or HYBRID RACE? As not a HYBRID PUMP option.
Default 11-29-2021, 09:40 AM
Thanks Terry,
Just read through the hybrid thread again. I am planning on running 91 for the winter. Will play around blending e85 in the spring.
I can’t seem to find what the difference is between PUMP and PUMP USA - what’s the difference between those two?
Thanks,
DC
Default 11-29-2021, 01:54 PM
Thanks Terry,
Thanks,
DC
Emissions are different between the 2. If you run the US version in Europe you'll get DTML codes as European cars don't have that equipment.
Car: 135i N54
Default 12-13-2021, 01:50 PM
BMS, just a quick one.
Just scrolled through and seems to be a question that pops up a lot recently.
Most probably as Hybrids are more readily available!
If your running Hybrids but on Pump Fuel (UK 99/US 93 - Super/Premium Unleaded) NO E85 as not available.
Do you run the PUMP BEF?
Or HYBRID RACE BEF?
As there is no HYBRID PUMP BEF. under the BEF file download.
Be good to know and sticky this as seems a few have asked recently and not been an answer.
Many Thanks
Car: 135i N54
Default 12-13-2021, 03:49 PM
Or HYBRID RACE BEF?
Many Thanks
Just thought id add to thread. For anyone in future,
Just confirmed from Cannon @ BMS in another thread. (thanks again)
If in this situation best to run the PUMP BEF not the HYBRID RACE one.
If you run Hybrids and no E85. Just Pump US 93/UK- Euro 97-99 etc (E5/E10)
ac_schnitzel ac_schnitzel is offline
Car: 2010 535i
Default 12-28-2021, 11:04 AM
waiting to load my first write/BEF and set to 4/2. I noticed that map0 is not available anymore? will OBD2 devices be usable once flashed, or will we still need to put things in map 0 before plugging things in?
Willtrout30 Willtrout30 is offline
Car: 2008 BMW 335xi
Default Overboosting after repairs - 12-28-2021, 01:06 PM
I just put new OEM turbos with updated wastegates on. While in there I did silicone inlets, super high flow ***, upgraded outlet and a BEF. Now I get over boost on anything over map 0. Did i free up too much air flow?
Default 12-28-2021, 02:22 PM
post a current log in the support section + a screenshot of your settings.
