(#376)
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Exclamation 06-27-2018, 05:12 PM
Did you select F series in app before reading codes? They should be 6 digits long on N63.
So, here is the log I can post, nothing much but that's it, car goes numb after that...
I also talked to Donnie and he confirmed that the JB4 app doesn't have a specified revision and engine selection anymore, it's all done automatically when connecting.
So I guess this is out of the question. Will try to do a reinstall tonight (of the app) and reconnect it to see if it's better or same.
Log is in attachment...
Do your magic guys and help me out please.
Also, do you guys have an up to date detail list of the steering wheel controls?
Thank you
BMW 550 M-Sport xDrive 2011
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
SINasTER's Avatar
Car: BMW 335xi E90
Exclamation 06-27-2018, 09:34 PM
Was able to get a few more pulls out of it but still same issues with map 1... the only map that will get me more boost than stock doesn't work. Beginning to think that I received a bad board or something. triple check the installation and everything is 100% (connectors and tmap sensors and the JB4 connect kit).
Now I sometimes get an error saying "Error connecting to JB4, Please check your hardware connection).
I still can't find a way to specify the engine and kit revision, options not available. I am using the JB4 app on iPhone X (latest build) and also tried 3 other beta versions of the app (I am subscribed as a beta tester for Donnie).
I have 3 data logs for you...
3rd gear pulls:
Map 0 - no issues but no boost gain since JB4 is disabled
Map 1 - 4psi over stock with major issues to drivetrain and followed by limp mode
4 gear pull:
Map 4 - no issues but no gain either since it's the stock map with JB4 active
To this point, I see that if I am disabling the JB4 or running a stock map with no boost gain at all, everything works fine, but when there is a minor gain in boost, car goes berserk, displays drivetrain issues and goes on limp mode with engine, transmission and transfer case shaking like it has advance Parkinson disease.
If I don't find a solution soon, I will have to ask for a return and refund since it's clearly not working on my car even though I ordered the right one for the 2011 N63.
I also did a firmware update and it did not change anything. Got the latest firmware for the N63 (JB4_N63_OBDII_2_T4.hex).
And please stop saying to specify the engine and revision kit because the option isn't available on the iPhone app. If you think it is, please show me how to access it because I checked everything on the app and there is no option for this anymore!
Would be nice to have a proper guide for the install, we had to waste almost an hour to find a guide for the Stage 2 but not 100% sure it's just JB stage 2 or JB4 stage 2.
Thanks for the help
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
SINasTER's Avatar
Car: BMW 335xi E90
Default 07-01-2018, 06:58 PM
Is there 2 versions of the JB4 for the N63???
I was told in a forum (since I can’t seem to get answers gere) that there is 2 very different versions of the JB4 for the N63. Basically, ont for électronic waste gates and another for pneumatic waste gates.
How can I tell the difference between what I received from BMS and what I actually need for my car?
My car can’t boost at all when in map 1 and I get drivetrain malfunctions and then limp mode. I guess I just threw 1k$ out the window and got a worst car in the process
Need help in a timely fashion
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
Default 07-02-2018, 08:09 AM
Email me so I can help you. Send me some pics of your engine bay and what you purchased from us.
Payam@burgertuning.com
SINasTER's Avatar
Car: BMW 335xi E90
Thumbs up 07-02-2018, 10:10 AM
Sent a message, pics to come
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
makmilli makmilli is offline
Car: 550 ix
Default 08-01-2018, 11:46 AM
I tried to find the place to specify the engine and revision but seems like it either disappeared or was moved... can’t find it anywhere and read somewhere that with the latest version of the app, this is done automatically.
Where do I change this?
have you found a solution to your problem, im going through the same thing. i have the jb4 connect kit and i've searched the app everywhere but can't find anything related to engine or series.
SINasTER's Avatar
Car: BMW 335xi E90
Thumbs down 08-02-2018, 05:14 AM
Unfortunately no, it seems the only way to do this is to plug directly to the JB4 via usb and I don’t have the usb cable and not planning to buy it either...
It’s suposed to do that automatically but it doesn’t seem to work on our platform.
Can’t do anymore tests either because I am in the process or rebuilding the entire engine with new turbos and everything.
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
atktoy@yahoo.com atktoy@yahoo.com is offline
Freddie
Car: 2013 BMW 650i
Default 09-05-2018, 10:31 AM
Hey Terry I have a 13 650i that I’ve been logging and talking with Payam about. He says logs look really good but you’re the man with the plan for giving the beast a little more! Let me know what you need from me to get the ball rolling!
ErinM's Avatar
ErinM ErinM is offline
Car: 2011 550 M-Sport
Default 09-07-2018, 11:38 AM
The App (IOS) was updated about an hour ago to version 2.3.5 to address “engine type detection and engine specific boost limits”. Download/update and see if the resolves issues.
KYtuning:Cayman Islands
Default 10-05-2018, 07:06 PM
Came up with a possible software setting adjustment for those N63s that have large bank to bank boost variances. If you have time to do some logs load and log it!
JB4_N63_OBDII_3_T2:
1) Moved bank2 boost from "timing avg" to "boost2" in interface and logs.
2) Added scaling adjustment to compensate for bank to bank boost variances under "6cyl timing". Setting to 0 disables. Setting to 50 is no compensation. Lower than 50 will raise boost in bank2 relative to bank1, while higher than 50 will lower boost in bank2 relative to bank1.
ErinM's Avatar
Default 10-09-2018, 04:33 AM
JB4_N63_OBDII_3_T2:
Thank you! Will get some logs in by the end of the week.
When increasing or decreasing above or below 50, does it matter how the increments are made? i.e increments of 1s, 5s, 10s or whatever works?
just_dirty just_dirty is offline
Car: E92 Gulf Livery 335
Default 10-11-2018, 04:11 PM
did this update fix the bank to bank boost variances? Also are bank to bank boost variance consistent or constantly variable? ie if bank 1 boosts 3psi higher than bank 2 can we always expect bank 1 to boost that much higher than bank 1 on the same map?
Frozen Black Widebody E92 : VRSF CP, N54Tuning DP, Tial BOV, DCI, MHD Flash, Aquamist HSF-3 Meth kit Dual Nozzle, Megan Racing Toe Arms,Megan Racing Camber Arm, Megan Racing Trailing Arm, IND Delrin Subframe Bushings, M3 Control Arms,Fortune 500 Series Coilovers, Square 18x11 Apex Ec7 w/ 315/30/18 Hoosier R7's
ErinM's Avatar
Default 10-12-2018, 04:44 AM
I haven’t done any testing yet. I’m waiting on Terry or someone to come back on my question regarding “6cyl timing” setting increments.
My experience has been that the variance is not consistent. However it’s not ever going to be perfect or consistent simply because there are many physical and logical variables the contribute to the outputs of each bank. Some N63 platforms have significant variances. I understand that this “fix” is intended to reduce or narrow the gap between boost. By either bringing one bank up or the other down. This is why I asked about increments, as I assume tweaking should be done so that the variance is reduced without creating a variance in the opposite direction.
I note though that on the N63, (my experience) one contributor to variance was faulty or weak CCVs. The oil going into the intake impacts output and output readings.. After installing a custom catch can setup my large variance reduced significantly. This along with ensure meth flow is balance as possible.
I still have some variance that ranges between 2 - 4psi.
Do you have a N63 platform? Your bio says “e92”.
Default 10-12-2018, 09:04 AM
What is your exact question? I'm not understanding what increments you need specified.
Default 10-15-2018, 11:31 AM
Gotcha. Tuning support for this platform is pretty weak but that is understandable from a demand stand point.
Yes, I have a 550I as a daily driver. It's stock for now but I might consider tuning in the future. I really like the JB4 but without a back end flash option I don't really see myself using it on my f10.
Have you noticed any odd behavior with your transmission after the tune?
ErinM's Avatar
Default 10-17-2018, 05:41 AM
Support is like pulling teeth sometimes but it has forced me to learn more by doing my own research. It has been better recently. @Payam is pretty responsive and helpful.
Terry just came out with a firmware update which tells me that they are still improving their N63 tune.
At the risk of sounding like a salesman.... although a piggyback, JB4 is a solid option that will give you moderate to considerable pep. It is also from my research and experience the only tested option that is reliable and provides real power increase.
Of course you can go all out like I have but my car is a weekend warrior.
To date, (knock on wood) my car has performed solidly on my setup. I’ve had the set up in for just over 1 year. I have not experienced any Transmission issues nor anything beyond normal wear and tear and typical BMW issues.
I’m still tweaking here and there to try and squeeze as much safe torque and power out of the setup possible. The only limitation for this platform is fueling capability necessary to support increased boost.
My engine performance setup:
JB4 w/ BCM
3.5 Tmap sensors
Rev 3
WMI (CM7 nozzles) (custom charge pipe)
Pure Turbo Stage 1
Full custom exhaust
Dual Custom catch can setup (this was a pain in the ass to design and install)
Fuel: 93 mixed with 104 race (not ideal for a daily driver)
Default 10-20-2018, 11:06 AM
We try to give the N63 a little attention. Still waiting for customer logs on the new firmware that was posted a couple weeks ago.
ErinM's Avatar
Default 10-20-2018, 03:08 PM
Hi Terry,
Thanks for the attention. Here are two logs I sent last week.
Default 10-20-2018, 04:19 PM
Thanks... See the bank to bank variance here? Try 6cyl = 40, and 6cyl = 60, for example, to see if either gets it closer. So we know which way to adjust it.
ErinM's Avatar
Default 10-20-2018, 05:12 PM
Thanks! Will do... as soon as I can figure this issues out. Posted a lil while ago:
https://www.n54tech.com/forums/showthread.php?t=55564
Rhodius Rhodius is offline
Car: 2012 550i
Default 2012 550i with CCP JB4 potential tuning option - 10-25-2018, 07:12 AM
Hello folks,
long time lurker, first time poster. I’ve been reading most of the postings on this thread, some I remember better than others.
I live in PA and have a 2012 550i with CCP which has the N63, this is my daily driver. I’m considering JB4 tune with the mobile connect kit for on the fly map change. From reading the Install pdf, it looks pretty straight forward if I don’t do the BCM. I don’t have the instruction for BCM install, but from reading comments it doesn’t sound easy. However I have some questions. I plan to be running octane 91 or 93 (premium gas), my intention is to run as normal as possible with greater acceleration and better response, as I understand the stock turbos are much more capable. I will not be driving super hard but occasional “fun” drive as I want as reliable as possible car. As of now I don’t want additional intake or anything else, unless barring something, this would be my only upgrade.
1. If I need to go through PA annual inspection, should I just set the JB4 to map 0 to pass the inspection? This is my biggest concern.
2. How easy to do the BCM myself? I'm not very handy at all, I've only done oil change on this car
3. Anybody in Philadelphia or South Jersey who can recommend an installer? In case I ran into issues, I’d rather have a professional install it.
I’m dyno-ing this week to establish some baseline. Anything else I need to know?
Thanks.
Rhodius
ErinM's Avatar
Default 10-30-2018, 07:34 PM
Originally Posted by Rhodius
Hello folks,
Thanks.
Rhodius
Hi Rhodius,
The first page of this thread will answer 99.99% of your questions.
BCM instructions are also on the first page of this thread.
To be helpful though (I was once a newbie too):
Generally, you have four main installation options (not including Water Meth Injection):
"Stage1: Connection to both TMAP sensors only. This allows performance equivalent to the current Stage1 system for someone looking for a quick and simple install.
Stage2: Adds in OBDII CANbus cable providing in dash map changing, boost gauge, boost by gear, stronger and smoother mapping, etc.
Stage3: Adds in two pairs of wires to the DME for fueling support allowing the use of E85 fuel mixtures.
Stage3+BCM: Adds in a BCM module that connects to two additional pairs of wires in the DME for direct wastegate control. With sufficient octane this allows the system to fully maximize power."
While installing the BCM is not too hard, having a basic understanding of electronic wiring and a reasonable bit of technical savvy is strongly recommended. You will be fiddling with your cars computer and as such you would hate to make a costly mistake. If you have no idea of what you are doing, don't mess with it.
As you say you will only be running 93, want to keep car as "normal" as possible and just want better response; in my experience nothing beyond Stage 2 above is necessary for your stated desires.
Map 0 disables the JB4. (Installed but technically not functioning)
Stage 2 allows you to only have remove TMAP connections and unplug OBDII CANbus cable to return to stock. A 5 minute process. This is not the case with Fuel Control wires or BCM.
xDrive750 xDrive750 is offline
Car: 2011 F02 xDrive
Default 11-03-2018, 10:36 AM
Looking for HEX file for firmware update. Looking to update JB4 with bluetooth kit via smartphone app...if it's possible. Message in app tells me to find hex file on this board, but i can't see to locate.
ErinM's Avatar
Default 11-03-2018, 06:26 PM
It is possible.
The firmware file is in the first post of this thread.
There are two files, so choose the correct one.
Ive attached a screenshot of the exact location.
Default 11-04-2018, 09:40 AM
It is possible.
JB4_N63_OBDII_3_T2:
I'm missing something then..I see what your talking about, the file is above but shows no file on mouse over or link to a download...
