(#301)
m5james's Avatar
m5james m5james is offline
Default 08-18-2017, 08:29 AM
That I don't know, I'm tuned and was told to raise it to 80. You can keep raising it but eventually you'll supposedly get a simple drivetrain error from what I was told by Steve at Fuel It on my logs thread.
What codes are you getting and what are you using to read them? I was getting unknown codes from the JB4, Carista was giving me misfire codes, all after I started pushing more boost. Going two step colder plugs and a .22 gap solved my misfire issue.
'08 BMW 535xiT - MHD 1+, BMS DCI, RB/Mishimoto, VRSF 7"
Hazard Hazard is offline
Car: 2011 BMW 550i
Default 08-18-2017, 09:41 AM
I can try the plugs. Which Tune do you have? and any chance you have the part number for the plugs?
I'll check the code today again, I dont remember at the moment.
m5james's Avatar
Default 08-18-2017, 10:01 AM
I've got an S63, got the info from S63TU guys, so I'm not sure if the plugs are still applicable to you. I'm running an Halim/HCPerformance stage 2+ tune...alll mods are listed signature. I've gotten codes from vacuum leaks to misfires toand overboost, but each had a different fix so the codes will help.
BCK2BLN BCK2BLN is offline
Car: 550i
Default 08-24-2017, 12:56 PM
@Terry
Does this automatically clear CEL related to catles **'s?
Kendall993 Kendall993 is offline
Car: 2013 F10 550i
Default 09-08-2017, 04:36 PM
Just Installed the upgrade JB4 Beta from the old Stage 2. Do I need to update my firmware? If so where do i find it?
Im getting a few warning lights/messages now when the ignition is on and my software on my laptop wont connect after the install.
Thanks for you help
Car: 2010 535
Default 09-11-2017, 09:45 AM
Any writeups on installing the N63 BCM?
335socal 335socal is offline
Default 09-12-2017, 10:28 PM
@Terry,
Any update on f10 550i intake?
Default 09-18-2017, 02:47 PM
Originally Posted by BCK2BLN
@Terry
No.
Default 09-18-2017, 02:48 PM
Originally Posted by 335socal
@Terry,
No update, still a work in progress. Our machine shop has been tied up with higher volume projects so this got thrown on the back burner.
Thanks for you help
It ships with the latest firmware and should not be updated.
If you need installation help you can make a thread in the support area with photos and details.
m5james's Avatar
Default 09-18-2017, 03:07 PM
@Terry
New firmwares don't auto clear anymore since BMS is trying to gain emissions compliance. You can flash older firmwares (I don't know what other downsides come with older firmwares and/or options we'd specifically be losing as well) but I've been clearing them manually by doing option 1/2 from the steering wheel, which will take about 5 seconds before things react. It'll clear my reduced power warning light but boost still comes on slower than normal, so ultimately I still have to cycle the engine off and back on again.
Antonio91 Antonio91 is offline
Default 09-19-2017, 10:02 PM
hey terry is it possible to get this JB4 for an f15 x5 50i I'm thinking about picking one up as a daily. or is the 50i still limited to the BMS stage 1
Car: 2010 535
Default 09-26-2017, 09:21 AM
Terry, Are you still selling the N63 JB4 BETA upgrade? I dont see them on your website?
BMRDude BMRDude is offline
Car: 2012 550ix
Default 09-26-2017, 10:04 PM
The JB4 upgrade is mighty hard to find on the site but finally found it
Here... http://www.burgertuning.com/N63_JB4_upgrades.html
Car: 2010 535
Default 09-27-2017, 08:22 AM
Default 11-01-2017, 09:51 PM
On the N63 platform a huge hold up in performance is the lack of twin bank wastegate control on the JB4. At higher boost levels the banks go out of sync, and there is no mechanism to bring them back in sync. We may develop another N63 board to accommodate this issue if there is sufficient demand. But, it seems to be the N63 is fast approaching a dead platform.
Anyway open to persuasion.
Also, I'm no longer going to provide N63 tuning advice via email. We'll use this thread instead. So feel free to post your logs, info, and questions here, so they are all one spot.
N63_Swiss N63_Swiss is offline
Car: BMW 650i F13
Default 11-02-2017, 02:43 AM
hello @Terry, here is 2 log of my car, with the same adjustments. once the throotle is "ok", the other time it closes. What do you think? I also notice that my car does not reach the requested boost. car configuration: jb4 beta kit + bms, E30, down_pipe. Racelogic 100-200 Korr. time: 8.26
mikekilpatrick mikekilpatrick is offline
Car: 2013 BMW F10 550XI Msport
Default Continued support - 11-02-2017, 05:18 AM
Personally, I would like to see continued development on the N63 platform. WIth 4 years on this model, and the model coming down in price in the used at market, I would think there would be more and more purchases of the car due to its large performance potential. Too bad there cant be a mass mailer via snail mail or email to all owners of N63 to advertise the ease of install and performance gains as there really isnít another choice for performance gains on our cars. Or would existing owners of the chip be willing to pay for upgrade/developement?
Mike
Default 11-02-2017, 05:23 AM
Question in here as you are no longer responding to emails. If taking a car on a long trip with Stage 2 beta installed, what is best? Unplugging unit from OBDII or setting it to map 0? NOt sure how much MPG increase can be obtained if not on the pedal versus lower map level or being disconnected.
BeGooD69 BeGooD69 is offline
Car: 2007 335i
Default 11-02-2017, 09:01 AM
I am still interested on a good solution.
Hilly's Avatar
Hilly Hilly is offline
Car: 2008 BMW 335i
Default 11-02-2017, 12:50 PM
Further the developments! We need more power...reading over bimmerpost there seem to be quite a few N63 owners
"I am the Master of my fate, I am the Captain of my soul" ~ William Henley
Car: 2012 550ix
Default 11-02-2017, 07:02 PM
I am having a great time with my 550. Probably another 5 years worth of fun!
Bit of a holdup for this platform is the difficulty of doing injection. There are no chargepipe options at all so every owner that wants to do injection has to kludge up their own solution. Makes it slow going.
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 11-02-2017, 08:20 PM
Just do this
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
kokoN63TU kokoN63TU is offline
Car: 2013 bmw 750i
Default Did you checked your time 100-200? - 11-03-2017, 01:52 AM
Originally Posted by M335
Just do this
Looks that you have a good chance to do good Time 100-200
Or 62-124
I have a flash tune and I wanna add jb4 on it
Car: 2012 550ix
Default 11-03-2017, 09:41 PM
M335, hahaha, yup. I have thought about this mod, but put it into the category of “kludge” mainly cause it’s not too user friendly. Not a lot of owners are going to be keen on this mod and if Terry, or any other supplier, were dependent on this mod to sell a product, they wouldn't sell more than a half dozen or so.
Nevertheless, I like it and I bet it works mighty fine!
