(#11501)
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 08-10-2019, 12:07 PM
Originally Posted by Rule77
I would say you should update your firmware.
Also enable 6cyl timing
08 E90 335i
Montego Blue
JB4/MHD E85 BEF
BMS DCI
BMS OCC
BMS Cowl Filters
VRSF ⬇️ Pís
BMS Chargepipe
TIAL BOV
BMS Pedal Tuner
BMS PCV VALVE
NGK 97506 @ .022
STAGE 2 LPFP
H&R Springs
19' 666m Wheels
Rule77's Avatar
Car: 08 E90 335i
Default 08-10-2019, 06:26 PM
Originally Posted by GotPwned
I noticed that my JB4 mobile is detecting an E85 level in my car. It does say that my car is around 53% e85 and fluctuates around +-2% e85 when driving. From what I know I dont think I have a flex fuel sensor in my car. Is this normal?
I would like to know about this since I just recently started running e30 and noticed the numbers under e85 in the cvs file are different.
08 E90 335i
Montego Blue
JB4/MHD E85 BEF
BMS DCI
BMS OCC
BMS Cowl Filters
VRSF ⬇️ Pís
BMS Chargepipe
TIAL BOV
BMS Pedal Tuner
BMS PCV VALVE
NGK 97506 @ .022
STAGE 2 LPFP
H&R Springs
19' 666m Wheels
ym12ad ym12ad is offline
Default 08-14-2019, 12:49 AM
hello,can i get some help,i have a 335i running with meth in map 3,at WOP,it switches to map 4 and flashes 4 times hazard lights,i never saw anything about 4 times hazard lights in any other post
Haynpunch's Avatar
Car: 07 E90 335i
Default 08-14-2019, 01:44 AM
post a log with it switching to map 4 in the Support section
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
x99percent x99percent is offline
Car: 2008 135i
Default 08-14-2019, 11:02 AM
4 flashes = low meth flow
Default 08-14-2019, 03:05 PM
when I did the logs is not switching anymore to map 4 but now I can hear a very strange noise from under the car,any idea what it can be?
attached the video and the logs
thank you
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 08-14-2019, 08:40 PM
thank you
Post in the SUPPORT section.
VinnyD VinnyD is offline
Car: 2008 Bmw 335xi
Default Need help maybe injectors - 08-17-2019, 08:42 AM
I have attached a log, I have changed spark plugs and coils. I can not do a full pull without going into limp mode. I have a 335xi n54 upgraded pure stage 2 turbos with full bolt ons with upgraded inlets this pull I was running 6 gallons of E85. I have xhp stage 3 trans flash and use jb4 custom hybrid turbo E85 backend flash.
Im thinking it might be the injectors because I get a check engine light for misfire in cylinder 6 often and 4 sometimes. I have index 9 and I know index 12 is suggested for tuned cars.
Any other ideas or is it bad injectors?
Thanks,
Default 08-18-2019, 11:43 PM
People, if you need help with your car, post in the SUPPORT section. This is for generic JB4 talk.
BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 08-19-2019, 04:33 AM
Relax dude, before you have a heart attack over a stupid ass reason.
Moderators will take care of it.
2009 E92 335i AT
Engine
Rev9 Hybrid 16t twins, Injen cyborg intake, CP-e charge pipe with HKS SSqv BOV, RB external PCV catch can, BMS catch can, Cobb intercooler, HKS Legamax exhaust, RB inlets, VTT single barrel hpfp, fuel-it! stage 2 lpfp, MOTiV Flex fuel flash only w/ trans tune by Cedar Performance
558rwhp and 523rwtq on e60 110* ambient air
Default 08-19-2019, 08:33 AM
Just pointing people in the right direction. Why do you sound mad? Sounds like you need to relax..lol.
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
