Gordy0079 Gordy0079 is offline
Car: 2022 M340i Xdrive
Default New to BMW and JB4 - 12-31-2021, 10:45 AM
Hello all,
I bought my first BMW and have never tuned a car before so I am looking for a little help.
First: How do I add my JB4 logs to this post? I am doing this from my phone so maybe it isn’t possible from the phone.
Second: I am using 93 octane and map 3. Nothing seems out of the ordinary when driving it hard but I am not an expert so I am sure that is what the logs are for. The question is will changing the spark plugs to the set that Burger sells have any negative affects if I don’t need them?
Thanks in advance and Happy New Year!
2022 BMW M340i Xdrive
Logos Engineering High flow DP
13mm Burger Spacers all around
JB4
AC Schnitzer lowering springs
Default 12-31-2021, 10:53 AM
So I finally figured out how to get a couple of them on here I think. The other 2 were to large so I will need to keep the logs smaller for future posts.
Hopefully there is some usable data in the two I am attempting to post.
JB4
Car: Evo VIII
Default 12-31-2021, 12:30 PM
Quite a bit of timing corrections coming out of map 3. I would recommend to upload a log in map 1. The NGK Laser Iridiums gapped down will help with the timing corrections as you continue to add more boost from stock.
Default 12-31-2021, 05:53 PM
Thank you for the feedback. Going to go put tomorrow and will upload my logs from Map 1. I appreciate how quickly you guys respond.
JB4
Default Been a while - 04-02-2022, 11:12 AM
Here are couple of Map 1 logs for analysis. I sure wish I knew how to read these things. Let me know how they look when you get time. Thanks a bunch!
JB4
Car: Evo VIII
Default 04-04-2022, 02:28 PM
Logs look great!
Default 04-08-2022, 04:16 PM
Thank you. Does this mean I should move up to map 2? I did order the NGK Laser Iridiums because I would like to be able to run Map 3 eventually. Is the gap down a standard gap or is it based on the amount of timing correction?
JB4
Default 04-11-2022, 10:34 AM
Looks like you were already running map 2. You're likely going to need more octane for map 3 as it's not as clean.
Default 04-12-2022, 12:13 PM
I thought the “M1” in the title of the log meant it was a Map 1 log? If not then how can you tell what map the log is from?
I am using 95 octane gas her in Germany so I am not sure I can get any more octane. Will the lower gapped spark plugs make a difference in Map 3?
By the way, before buying the JB4 I read a lot of posts on different forums about how people didn’t think the JB4 was working that well on the new B58s.I was hesitant at first but glad I bought it. I am not sure what experience they had but I am very pleased with the responsiveness and extra power of the JB4. I wish I could get this thing to a dyno to see the HP/TQ gains because my dragy times improved significantly. I also appreciate the support you guys provide on these forums and since we are unable to chip tune this best option with a great price. You guys are awesome!
JB4
Car: Evo VIII
Default 04-28-2022, 01:13 PM
Hi! Generally the files "title" starts with displaying the map that the log was stared in. So if a log was started in map 1 but then was switched to map 2 mid log, the title of the file will maintain "M1". Please fell free to let us know if you have any more questions!
ayyrabmoney93 ayyrabmoney93 is offline
Car: 2021 M440i xDrive
Default 06-03-2022, 07:41 PM
out of curiosity will the jb4 still take logs in map 0?
