elvin123 elvin123 is offline
Default Help with no boost logs attached - 04-11-2022, 02:56 PM
Sup friends,
I recently wired on my DP fix and removed it. After this I got an issue where I'm getting no boost at all. Exhaust sounds louder as if the wastegates are all the way open. I removed my jb4 completely and flashed the dme back to stock and the issue remained. I wired my jb4 back on and took some logs. There's no sound of the turbos even spooling. Any ideas of what this could be? Could it be DME related?
I attached a log. ECU PSI and Boost values pretty much stay at 0 for the whole run.
I don't think it's a boost leak since Im not even getting any spooling noises and it pretty much happened over night. Chargepipe and intercooler connections are tight.
Getting a 2DED and a 30FF code
Mods: DP, relocated inlets, jb4, wagner IC
Default 04-12-2022, 10:02 AM
WGDC is completely maxed out and no boost.
VoIPNerd's Avatar
VoIPNerd VoIPNerd is offline
Car: 2011 335is
Default 04-12-2022, 11:25 AM
Sounds to me like your boost solenoids aren't powered, or the vacuum line to the solenoids got disconnected somewhere.
2011 335is E93 with DCT
JB4 G5 ISO * BMS DCI * VRSF 7.5" Competition FMIC * VRSF dp's * VRSF Chargepipe * VRSF Inlets * Turbosmart Raceport BOV * Fuel-it Stage 2 Bucketless LPFP * Fuel-it Flex fuel kit * Phoenix Racing Port Injection manifold w/ 750 cc Injectors and BMS JB4 PI Controller * RB Turbo External PCV w/ plugged headports and Mishimoto OCC * NGK 2-Step Colder Plugs * MHD Flex-fuel BEF
Default 04-12-2022, 01:00 PM
Thanks for your replies. Iíll double check the solenoids and vacuum lines and report back.
Default 04-20-2022, 03:24 PM
Boost solenoids were it. Thanks for your input gents.
