Mikeym40 Mikeym40 is offline
Car: 2022 M40i
Default 2022 X3 M40i - JB4 - 01-01-2022, 03:02 PM
Hello. I have a general question as a start. I currently have a catted DP and MST intake and was looking to install the JB4. I run 93 octane, no plans for E, and still would like a reliable but fast &Fun car. Would I run map 1 or map 2 and that’s it? Like set it and forget it kind of thing or would I need something custom since I have some bolt ons?
Thanks so much.
Hendo741's Avatar
Hendo741 Hendo741 is offline
Car: 21 Supra 3.0 / 18 RS3
Default 01-01-2022, 05:05 PM
The JB4 really like a few gallons of E per tank. Basically acts as an octane booster. You could try map 1 on 93 and it'll probably give it some extra juice, but youre missing out on the full capabilites of the JB4.
Car: 2022 M40i
Default 01-01-2022, 06:44 PM
Meaning every fill up Id have to add E or can just be added whenever?
Hendo741's Avatar
Default 01-01-2022, 08:39 PM
Unless you install a content analyzer it's easier to just get it when you fill up. I usually run my tank down to about 1/8 then 3 gallons of E then top her off with 93. Should make about E20-25.
Default 01-01-2022, 09:22 PM
Just select map2 and enjoy. Nothing else needed. 93 octane is fine for it.
Car: 2022 M40i
Default 01-02-2022, 08:27 AM
Thank you!!! Looking forward to having it installed!!
Car: 2022 M40i
Default 02-24-2022, 05:20 PM
I have a friend that owns a dyno and I wanted to know is it worth dyno tuning with one of the custom maps or should I just stick to map 2. Again, not looking to run E and still want to keep this reliable.
Thanks.
Default 02-25-2022, 11:20 AM
Stick with map 2 as you'll be octane limited if not running ethanol or additional upgrades.
Car: 2022 M40i
Default 02-25-2022, 08:08 PM
Thank you again. What kind of additional upgrades do you mean?
Default 02-28-2022, 07:28 PM
Meth kit would get you more boost and octane. Otherwise, just stick with map 2.
WayneRT WayneRT is offline
Car: BMW N54
Default 03-01-2022, 12:43 AM
My friend is looking to get MET kit for his JB4 project. May we should try map 2 first and see. The car is still in the shop for the installation of new tires from 4Wheelonline plus alignment.
Car: 2022 M40i
Default 03-12-2022, 03:04 PM
Update - JB4 installed and a tuner buddy of mine tuned map 6 on a dynojet yesterday. Would love to get thoughts Steve and Terry on the settings and performance. How would I do that? Would I have to log and do a kick down somewhere safe . The idea is that I’d drive on the custom map and put it on map 1/2 for my wife.
Thanks in advance.
Default 03-12-2022, 05:30 PM
You'd have to post your log for any tuning advice on it.
Car: 2022 M40i
Default 03-30-2022, 07:16 AM
Can do this today. Do I just drive regular or do you recommend anything I do for an appropriate review? Thanks in advance
Default 03-30-2022, 09:40 AM
To properly evaluate the tuning, we'll need a full throttle JB4 log from 40-90mph on a safe private track.
david111jr david111jr is offline
Car: '22 x3m40i LCI
Default 04-02-2022, 09:34 AM
after reading this it makes me want to buy a jb4. I have a 22x3m40i with less then 5,000 miles. and I saw some people say in other forums you need to change the plugs. is this a real thing even with new cars you would thing the new spark plugs could handle it. also looking at throwing a intake as well? any suggestions. what was your progression Mikey ?
Car: Evo VIII
Default 04-04-2022, 02:26 PM
Hi! We definitely recommend changing to NGK plugs and gapping them down to .022 if you plan on just running 91-93 octane pump gas. This aids in preventing spark blowout when you turn up the boost. As far as an intake goes, check out the link below, as well as the JB4 and spark plugs.
https://burgertuning.com/products/bm...41453775028398
https://burgertuning.com/products/b5...nt=14225131651
https://burgertuning.com/products/ng...31001746899059
Please let us know if you have any other questions or concerns!
Default 04-04-2022, 03:38 PM
+1
Car: 2022 M40i
Default Custom map 6 and map 2 run - 04-10-2022, 11:54 AM
Let me know if this works. Would love any feedback. Hope I did it right.
File Type: csv P58_M6_R6_220410_1425 (custom map 6 and map 2).csv (104.5 KB, 63 views)
Default 04-11-2022, 10:38 AM
Map 2 logs are junk map 6 looks okay.
Car: 2022 M40i
Default 04-11-2022, 10:59 AM
Thanks. Yeah I think I messed up on the map 2. Will try it again later this week.
Car: 2022 M40i
Default 04-16-2022, 08:16 AM
Map 2. Hope I did it right again.
Car: 2022 M40i
Default 04-27-2022, 04:01 PM
Bump!
Car: Evo VIII
Default 04-28-2022, 01:45 PM
Log looks great!
Car: 2022 M40i
Default 04-30-2022, 10:30 AM
Thanks! I’ll probably daily map 1 and use map 2 for fun. Can’t find any gas stations with E in NYC, so will wait on that for a bit.
