TwitchingStone TwitchingStone is offline
Arrow Correct BEF for application? - 04-10-2022, 05:42 PM
Hi all! Please let me know if anyone notices anything of concern. My main concerns are of course if anything is immediately out of place, and secondly if Im running the correct BEF in regards to timing. All logs are done at ~10c (50F) running Canadian 93 octane gas. Mods are as follows:
  • JB4 w/ pump gas BEF
  • EBay 7 intercooler
  • DIY DCI
  • Water meth (roughly 80/20) FSB controlled
The car has 145,000KM, or 90,098 miles.
2007 335i
- JB4 w/ BEF
- 7 eBay special intercooler
- no name charge pipe
-DIY DCI
Default 04-11-2022, 10:24 AM
Looks normal thus far.
Default 04-11-2022, 12:35 PM
Thanks Steve! Do you think switching to a race BEF would be appropriate to realize any potential timing improvements?
Im assuming the car will failsafe if it ends up being a bad idea, but asking never hurts.
2007 335i
- JB4 w/ BEF
-DIY DCI
Default 04-12-2022, 10:00 AM
Better logs will help determine that...do one in 3rd from 2k to redline on a safe private track.
Default 04-12-2022, 11:25 AM
Got it, will do. Im sure theres more reading to be done on my end, Ill try and get a better frame of reference for myself as well.
2007 335i
- JB4 w/ BEF
-DIY DCI
Default 05-09-2022, 03:45 PM
Hi Steve. I did some more logging as best I could. Not the full run that you need but it's difficult where I live. Played around with the boost additive to learn about the effect that has on timing. I'm on pump gas and using single nozzle charge pipe injection, so I don't expect the world by any means. Mostly wondering if this looks in line with other people that you've seen.
Of note, an additive of 40 compared to 20 seems to have very little impact on my ignition average if any; my timing curves look very similar at a peak of 16 or a peak of 19. I've read as many posts as I could find relating to my set up, but I'm no professional.
I'm also on stock down pipes, and as I understand EGT's can play a role in this.
what are your thoughts?
File Type: csv P32_M3_R3_220508_1359 - P32_M3_R3_220508_1359.csv (420.7 KB, 34 views)
2007 335i
- JB4 w/ BEF
-DIY DCI
Default 05-09-2022, 11:23 PM
Before anyone responds, I have better logs! one set is at a 40 additive and one at 50. I was hoping to exacerbate any issues, but all I can see is that the stock fuel pumps seem to be slightly above range with the 50 additive.
2007 335i
- JB4 w/ BEF
-DIY DCI
Car: Evo VIII
Default 05-10-2022, 10:47 AM
Logs look great. Let's see some logs with some more boost!
Default 05-10-2022, 11:48 AM
timing is ok? I notice it's not the ign avg of >2 that we should shoot for.
more boost?! I like the way you think. I'll give it a shot, what's the worst that can happen hahaha.
2007 335i
- JB4 w/ BEF
-DIY DCI
Car: Evo VIII
Default 05-11-2022, 10:29 AM
Perfectly fine.
