(#3276)
Default 06-11-2020, 12:52 PM
First step for any specific tuning advice is a lot of the issue.
Drmalp Drmalp is offline
Car: Elantra GTS 1.6T
Default 06-13-2020, 08:40 AM
Hi all,
Could someone take a look at my log? I drive the 1.6T Elantra GTS with JB4 in Map2/93 octane (no fuel wires).
Mods include:
AFE Intake
BorgWarner ECBS
GFB BOV
AFE Axleback
HKS plugs
Default 06-13-2020, 09:30 AM
Originally Posted by Drmalp
Hi all,
Mods include:
AFE Intake
BorgWarner ECBS
GFB BOV
AFE Axleback
HKS plugs
Looks good to me, but pedal is not 100% down. I'd also set options bit0 on to disable fuel control wires as otherwise AFR in logs won't be 100% accurate.
Default 06-13-2020, 09:57 AM
Thanks Terry, I'll try to find a better spot next time to log. How do I turn bit0 on? I saw it in user adjustment but I can't seem to save the setting?
atr1 atr1 is offline
Car: Stinger GT
Default 06-13-2020, 11:03 AM
Hi Terry
I got a question about map 7.
On what value is the boost additive based on?
I understand that it is a percentage, but a percentage of what value? Is it a fixed value or profile (per gear, rpm) inside JB4 for each platform?
N20_to_VR30 N20_to_VR30 is offline
Car: RS400
Default 06-13-2020, 01:05 PM
JB4 on Map 3, e30, BMS intake. Just installed EWG wires. After a 45 minute drive, tried to accelerate hard and car bogged. JB4 is showing codes 259e and 25a0.
Used this setup minus EWG wires without issues in the past. EWG wires appear to be in the correct pins.
Editing to add that I can’t log right now but anything greater than Map 1 is capping the factory boost gauge at about 6psi. Map 0 is boosting as expected.
Connections appear tight. Any thoughts?
Default 06-13-2020, 03:45 PM
Under options on the user adjustment page. Hit save twice after changing it.
Default 06-13-2020, 03:46 PM
Maybe a setting issue, etc. Log will shed more light on it.
mcdale83 mcdale83 is offline
Car: 14 Veloster Turbo
Default Map 1 Logs for 1.6T - 06-13-2020, 03:50 PM
Good evening Terry. Could you please take a look at these logs for me? I notice a few spikes in AFR but not sure if this is normal. Thanks!
Car: RS400
Default 06-13-2020, 05:20 PM
Traffic is a bit heavy but it looks like the boost is capped.
Default 06-13-2020, 05:29 PM
No runs long enough to evaluate, sorry.
Default 06-13-2020, 05:30 PM
Update to v17 and fill in required EWG settings. Duty bias all 50, FF 50, pid gain 20.
Default 06-13-2020, 05:41 PM
Thanks for the quick reponse. I am new to this kind of stuff. How long of a run do you need?
Default 06-13-2020, 05:55 PM
What do you mean by traffic is a bit heavy?
Default 06-13-2020, 07:22 PM
40-90 or something, on a safe private track of course!
Car: RS400
Default 06-13-2020, 07:48 PM
Thanks! Back in action. The 3.3 is a slug without boost!
kashfg kashfg is offline
Car: KIA Stinger
Default Crackle and Pops - 06-13-2020, 09:37 PM
I purchased system recently wanted to know if its possible to make kia stinger crackle and pop like bmw and f type
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 06-14-2020, 07:02 AM
Remove one or two spark plugs.
JB4 - Denso 5346 - Mishimoto IC - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Car: 2019 STINGER GT2
Default 06-14-2020, 07:14 AM
3 gallons of #2 diesel.
YMMV
reyfdiaz reyfdiaz is offline
Car: 2020 Stinger GT1
Default Limp Mode - 06-14-2020, 08:11 AM
I have been running Map4 with out any issues. Since I installed the EWG wires, when I hit full throttle car is going on limp mode, no boost and through me back to map0. What can I do?
Car: Stinger GT
Default 06-14-2020, 08:12 AM
What is last safety?
Icon1 06-14-2020, 08:24 AM
Hey Terry, heres those logs you asked for. Couple WOT 40-90 pulls on map2. I did notice that the boost was maxing out about 17-18psi which is what I normally got stock.
Default 06-14-2020, 08:26 AM
Last safety was 3 fuel pressure
Car: Stinger GT
Default 06-14-2020, 09:29 AM
Are your fuel trims maxed in the logs?
Do you have WMI?
Default 06-14-2020, 09:35 AM
Grab a log of it, based on your last post appears to be a fuel pressure issue.
