06-11-2020, 12:52 PM
First step for any specific tuning advice is a lot of the issue.
Car: Elantra GTS 1.6T
06-13-2020, 08:40 AM
Hi all,
Could someone take a look at my log? I drive the 1.6T Elantra GTS with JB4 in Map2/93 octane (no fuel wires).
Mods include:
AFE Intake
BorgWarner ECBS
GFB BOV
AFE Axleback
HKS plugs
06-13-2020, 09:30 AM
Originally Posted by Drmalp
Hi all,
Mods include:
AFE Intake
BorgWarner ECBS
GFB BOV
AFE Axleback
HKS plugs
Looks good to me, but pedal is not 100% down.  I'd also set options bit0 on to disable fuel control wires as otherwise AFR in logs won't be 100% accurate.
06-13-2020, 09:57 AM
Thanks Terry, I'll try to find a better spot next time to log. How do I turn bit0 on? I saw it in user adjustment but I can't seem to save the setting?
Car: Stinger GT
06-13-2020, 11:03 AM
Hi Terry
I got a question about map 7.
On what value is the boost additive based on?
I understand that it is a percentage, but a percentage of what value? Is it a fixed value or profile (per gear, rpm) inside JB4 for each platform?
Car: RS400
06-13-2020, 01:05 PM
JB4 on Map 3, e30, BMS intake. Just installed EWG wires. After a 45 minute drive, tried to accelerate hard and car bogged. JB4 is showing codes 259e and 25a0.
Used this setup minus EWG wires without issues in the past. EWG wires appear to be in the correct pins.
Editing to add that I can’t log right now but anything greater than Map 1 is capping the factory boost gauge at about 6psi. Map 0 is boosting as expected.
Connections appear tight. Any thoughts?
Reason: Add boost gauge info
06-13-2020, 03:45 PM
Under options on the user adjustment page. Hit save twice after changing it.
06-13-2020, 03:46 PM
Maybe a setting issue, etc. Log will shed more light on it.
Car: 14 Veloster Turbo
Map 1 Logs for 1.6T -
06-13-2020, 03:50 PM
Good evening Terry. Could you please take a look at these logs for me? I notice a few spikes in AFR but not sure if this is normal. Thanks!
Car: RS400
06-13-2020, 05:20 PM
Traffic is a bit heavy but it looks like the boost is capped.
06-13-2020, 05:29 PM
No runs long enough to evaluate, sorry.
06-13-2020, 05:30 PM
Update to v17 and fill in required EWG settings. Duty bias all 50, FF 50, pid gain 20.
06-13-2020, 05:41 PM
Thanks for the quick reponse. I am new to this kind of stuff. How long of a run do you need?
06-13-2020, 05:55 PM
What do you mean by traffic is a bit heavy?
06-13-2020, 07:22 PM
40-90 or something, on a safe private track of course!
Car: RS400
06-13-2020, 07:48 PM
Thanks! Back in action. The 3.3 is a slug without boost!
Car: KIA Stinger
Crackle and Pops -
06-13-2020, 09:37 PM
I purchased system recently wanted to know if its possible to make kia stinger crackle and pop like bmw and f type
Car: Stinger 3.3T
06-14-2020, 07:02 AM
Remove one or two spark plugs.
JB4 - Denso 5346 - Mishimoto IC - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Car: 2019 STINGER GT2
06-14-2020, 07:14 AM
3 gallons of #2 diesel.
YMMV
Car: 2020 Stinger GT1
Limp Mode -
06-14-2020, 08:11 AM
I have been running Map4 with out any issues. Since I installed the EWG wires, when I hit full throttle car is going on limp mode, no boost and through me back to map0. What can I do?
Car: Stinger GT
06-14-2020, 08:12 AM
What is last safety?
06-14-2020, 08:24 AM
Hey Terry, heres those logs you asked for. Couple WOT 40-90 pulls on map2. I did notice that the boost was maxing out about 17-18psi which is what I normally got stock.
06-14-2020, 08:26 AM
Last safety was 3 fuel pressure
Car: Stinger GT
06-14-2020, 09:29 AM
Are your fuel trims maxed in the logs?
Do you have WMI?
06-14-2020, 09:35 AM
Grab a log of it, based on your last post appears to be a fuel pressure issue.
