(#2501)
IBND335i's Avatar
IBND335i IBND335i is offline
Car: 2007 BMW 335i coupe
Default 05-17-2016, 04:17 AM
^this
2007 e92 auto
Jb4/dci/e85blend/e85flash/fuel-it stage2
12.53 @ 114
after ***: 11.92 @ 117.98
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-18-2016, 12:28 AM
Originally Posted by Zubz335
Hi guys, new on this forum, but have been running Mhd for a while now and just simply loving it, quick question, which alpina b3 flash would be best with the OTS stage 1 and 2 maps? The older #7603537 or the newer #7615835?
Let us know your findings. Shop car is not alpina flashable.
Originally Posted by morning wood
Awesome! Very useful!
Thank you! I just flashed stage 1 since I'm waiting for the parts. Car runs so much smoother. What is the difference between the beta maps and the OTS maps? As for the Options menu, what exactly does each option do? I left them unchecked as I'm unsure exactly what each one does.
I'll write a description one of these days in the Twisted tuning guide.
Originally Posted by ShocknAwe
I'm sure this has been covered but want to be clear. If I have over 30% blend, but under 40%, should I use the Race BEF and map5?
Yes.
Jeffman's Avatar
Jeffman Jeffman is offline
Default 05-18-2016, 03:04 AM
Does anybody know where to find a guide somewhere on how to select and deselect the various toggles in TunerPro?
For example, what values should I enter in TunerPro to DISABLE the various Nannies like "Torque Reduction By Ignition", etc.
Poppowisch's Avatar
Poppowisch Poppowisch is offline
Car: BMW e93 335i
Default 05-18-2016, 03:32 AM
is it okay to mix in some e85 when running BMS Pump flash, or is it designed for pure gasoline only?
BMW 335i e93 M-sport 2007 AT Alpina B3 TCU, JB4 G5 whit MHD BMS backend flash pump
Default 05-18-2016, 07:28 AM
Just getting started with e85 but i believe pump flash is ok for mixtures up to 30%
N54 | Build Thread
Jimmy90 Jimmy90 is offline
Car: 2008 335i e90
Default 05-18-2016, 11:32 AM
So I tried to do a backend flash on my 2008 335i and forgot to turn my jb4 to map 0. Now my car won't start and I can't access the jb4 menu via steering controls. I'd appreciate any advice. I'm sorry if this is a bad section to post this in. I'm completely new to forums
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 05-18-2016, 03:15 PM
You wouldn't ask your dentist to do a filling whilst you're whistling!
Mistakes happen. Start a support thread, be sure to include details about your DME version & flashing method. In general flashing back to stock would be your best move.
| U.K. 2007 E93 335i| JB4 G5 I8A0S Pump Flash| Scoops | BMS DCI | CKS Performance 3" *** | MMP Silicone Inlets | Active Autowerke 5" FMIC | CDV delete |Fob Roof Controls | JB4 Connect rev. 3|
baja2700 baja2700 is offline
Default 05-18-2016, 03:24 PM
what ever happened to the hybrid specific maps?
Default 05-18-2016, 05:16 PM
Just wanted to hop in here and say, flashed the Race BEF for the first time an hour ago and ran out to drive. Oh. My. God. Now I get the obsession over E85. I have no idea why I've been content with the Pump BEF for so long. I'm going to have to get some ethanol rated gas cans for my garage. Like, yesterday.
Thanks for answering the %E question earlier Martial!
N54 | Build Thread
Jeffman's Avatar
Default TunerPro Help - 05-18-2016, 09:18 PM
Anybody?
CLTEURO CLTEURO is offline
Car: 08 335i 6MT Coupe
Default 05-19-2016, 04:58 PM
Anybody?
If you hover over the item in the parameter tree, it will tell you what values to set to disable it.
Ex. Disable Tq Reduction by Ign: Enable: set to 00 Disable: set to 02.
In this case, you would want to set that value to 00 to Enable the Disable, if that makes sense.
2008 E92 335i Coupe 6MT | Apex Arc-8 18x9.5 | MHD: Stage 2 93oct | CP-e Charge Pipe | Active Autowerke BOV | DCI | VRSF C*****S D*******S | VRSF 5" FMIC | Cyba Air Scoops | BMW PE Mod
Jeffman's Avatar
Default 05-19-2016, 05:05 PM
^Hey, thanks @CLTEURO !
"Enable the disable." Sounds like an entitlement program.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-20-2016, 02:23 AM
Unplug the jb4 power pin, and restart the flash process.
See above. Honest question, why would flashing back to stock be better than directly flashing the needed map?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD 1.35 - 05-20-2016, 02:29 AM
Today's official update introduces:
- Automated logging: in this mode, no button is required to start logging. Just press the pedal above 50% to start recording. The log will be stopped and saved after 3 seconds with less than 50% pedal.
- Shift light: the background of the MHD gauges gets illuminated at at user selectable RPM. Go to monitor > options to adjust the rpm.
- Flash option : Desensitize the knock tables. If checked, overrides any map with partially desensitized knock tables settings. Not recommended for general use.
- Flash option : ADV O2 sensors kit. Support for the aftermarket lamda sensors sold by Chris.
Default 05-20-2016, 02:45 AM
Honest answer, I thought my advice would get Jimmy's car up and running.
I stand corrected, I now see the error in my comment, and will be more mindful in the future.
Default 05-20-2016, 09:24 AM
Glad to hear on the KR maps! I'll test it out soon and next release of JB4 MHD maps we can delete the KR specific maps since it's a flash-time option now.
omarmarji's Avatar
Car: n54 335
Default 05-20-2016, 09:31 AM
when will there be an option for single post turbo o2? specifically on the back end flash
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
Default 05-20-2016, 09:32 AM
I haven't looked at that yet but will when our single turbo development car gets back. Sounds great to me though.
omarmarji's Avatar
Car: n54 335
Default 05-20-2016, 09:43 AM
a buddy of mine locally might have figured that out already.
http://www.bimmerboost.com/showthrea...678#post704678
post #21
751WHP 688WTQ
JP Works Kit Record
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 05-20-2016, 10:00 AM
On the desensitized BEF, or even this new KR flash time option.. Is there a percentage that we can relate it to? or is it only an initial timing retard threshold is 0?
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
ryanm8 ryanm8 is offline
Car: 07 335I
Default 05-20-2016, 06:48 PM
How does the new shift light feature work along side the JB4 blinker shift light?
quattr0 quattr0 is offline
Default 05-21-2016, 03:23 PM
Gents
I still have jb4 mhd 091315 pump (93) installed. Question: Should i get the latest pump or kr map in light of what Terry posted in the JB4 BEF new features and testing post that stage 2 mhd target is high?
Many thanks!
Rsoxs19's Avatar
Rsoxs19 Rsoxs19 is offline
Car: 2007 335i e92
Default 05-21-2016, 04:04 PM
how much hp gain can you expect from the latest pump MHD flash? Thanks!
Default 05-22-2016, 06:10 AM
Well, dyno your car before you flash, and then dyno it again after you flash, and then you'll know your answer! My butt dyno says I've gained >100hp.
Either set them both to the same RPM you want, or use one or the other? I don't think it's rocket science, I could be wrong.
Rsoxs19's Avatar
Car: 2007 335i e92
Default 05-23-2016, 05:56 PM
How often does the flash fail because I'm really scared it will mess something up. If it does fail why could I do to get it back to normal? Thanks!
