NEIN NEIN is offline
Car: F10 M5
Default Bank 1 overboost and bank 2boost low problem - 11-26-2018, 12:42 PM
I running GTX3071 ball-bearing hybrid turbo JB4 V2,OCT93,Dual CM10, Performance Intake & Chargepipes ,I feel Bank 1 overboost and bank 2 boost low, What are the suggestions?THKS
Default 11-26-2018, 09:52 PM
Good start would be turning back on WG adaption to see where the JB4 sets FF and FUA. Might be you inverted the BCM plugs and need to set a bit in the JB4 firmware (WMI page, DTML WMI input) to invert the signal.
Car: F10 M5
Default 11-27-2018, 10:12 AM
Terry thank you for your quick reply, I follow your setup BANK1 overboost is very serious and the BANK2 boost value is very low. With the entire target, the remaining 25PSI is left. Thank you.
Default 12-25-2018, 10:05 AM
Let's see a run on map0 to know if the factory wires are mixed up or the JB4 wires are mixed up. If it's just the JB4 wires there is a setting to invert them selecting "DME WMI input" on WMI page.
