MintyM3 MintyM3 is offline
Car: Indv. Mint Green F80
Default No connectivity? - 10-29-2018, 05:59 AM
Hi all,
After reading other threads, I have concluded that the previous owner of my JB4 didn't unpair his bluetooth device, hence it will not allow another connection.
Is there an e-mail for support to undo this?
Cheers, Tommy
Default 10-29-2018, 03:59 PM
When you go to connect if you need to contact anyone it will prompt you what to do.
Default 10-30-2018, 03:56 AM
Thanks for your response, Terry. I sense your frustration with these noob questions, and I don't mean to annoy. Your product is tremendous! :D
When I try and connect bluetooth, it tries to handshake, and then asks for the hardware connections to be checked. These are all okay, power at BT unit.
When using USB, it fails, even with the correct port.
Thanks for your time
Default 10-30-2018, 08:35 AM
If you can't connect with either device then maybe the 2580 chipset is damaged on the board and needs to be replaced.
Default 11-06-2018, 03:38 AM
What's the easiest way to diagnose and repair please?
I have the invoice from the original retailer.
Default 11-06-2018, 05:06 PM
The 2580 chips are on our website if you just want to grab another, they can get static zapped: http://www.burgertuning.com/JB4_upgrades.html
