Kolbe's Avatar
Kolbe Kolbe is offline
Car: BMW F10 M5
Default Advice needed: F10M5 with JB4 with BCM plus BM3 Stage 2, 91 octane logs - 09-30-2018, 10:42 PM
Hi, Am running my F10M5 with BM3 Stage 2, 91 octane (95RON) as a BEF together with my JB4 + BCM. Have done logs in Map 0, 2, 1 and 4. Logs attached. Maps 0 and 2 look similar, map 1 is scary (trims maxed and AFR lean) with clutch slippage. Map 4 is just low boost and feels soooo slow.
Can you please advise if map 0 or 2 should be used? Any else that I could try? Thanks.
Default 10-01-2018, 07:34 AM
Do you have any additional fueling mods? Map 2 looks good, it will need more runs to get adjusted.
Kolbe's Avatar
Car: BMW F10 M5
Default 10-01-2018, 08:04 AM
Other than a can of octane booster I have no additional fueling mods. Glad to hear that a couple of runs will get it adjusted even better.
Map2 definitely feels stronger than map0 although the logs are similar - or am I seeing that incorrectly?
Regarding the Trims (hits 44 briefly) and AFR (hits 15 briefly) at around 4300rpm on log2 - are they ok (don't want to risk any damage)?
