(#626)
Car: B46 F56S
Default 11-30-2019, 01:53 PM
Terry.
BM3 supports B46/B48.
You think we can get some MINI Support and BEF for our cars?
j4mes-c j4mes-c is offline
Car: Mini F56 JCW
Default 01-25-2020, 08:52 AM
Afternoon all. I've just (this minute) picked up a JB4 to use on my B48 Mini. I've done some reading and still a bit unsure on some things. The jb4 came off a B58 BMW M140i and although it has the bluetooth adaptor, does not have the computer attachment. So to install the correct firmware, I plug the JB4 in, link the app to my phone and install the firmware that way? I ask as I've seen some mention of the JB4 auto detects if it is connected to a B38/48/58 and sets the firmware automatically.
If I'm using the bluetooth does the OBD plug need to be in use or can I leave it disconnected? I'll be running map 1 initially until I'm sure all is ok then try map 2.
Car: B46 F56S
Default 02-05-2020, 11:05 PM
OBD is not needed. Yes install proper firmware on the first page of this thread with JB4 app and Bluetooth.
shawntrex shawntrex is offline
Car: 2017 Mini Countryman All4
Default BC No response / CEL on - 02-09-2020, 08:39 AM
What am I missing?
I installed a JB4 on my 2013 335i 2+ years ago and LOVE IT!
I attempted to install on my 2017 Mini Countryman S All 4... Attempted being the key word.
Has anyone else ran into this:
Problem: Installed and no response from BC button and the CEL comes on?
I contacted support (Ando replied) and after some diagnosis, I found that only one of the pins from the OBD connector was actually being fed into the 2 pins of the JB4. I provided pictures, explained the issue and was told to ship the cable and unit back ($14 no big deal).
Ando replied that a new unit was on its way. I asked what the issue was he said "replaced cable". I was skeptical because he also said that regardless of the cable, the unit should be defaulted to Map 1 and no CEL.
Received it this weekend, tested the new cable and confirmed that indeed 2 pins were now active from the OBD connector to JB4, so I installed it, started the car..... CEL and no BC button response!
It is the most simple thing to install, 2 connections at the engine, and one to the OBD... I am not an idiot and it really is fool proof...
I am patient because this is a performance upgrade, not a required part (luckily I have the tool to reset CEL). I really want this thing to work.
So what am I doing wrong? Am I the only one who ever encountered this?
Default 02-10-2020, 10:21 AM
Originally Posted by shawntrex
What am I missing?
If you're already working with Ando, best to keep the support in one place.
R'Sup'T R'Sup'T is offline
Car: 2014 Mini Cooper 1.5
Default 02-14-2020, 08:27 AM
What is the current status of B38 engine support for Minis?
I guess a compression ration of 11:1 is one of the main limiting factors in tuning this engine (with temperature at 11:1 CR being about 40 degrees C/100 Fahrenheit higher than at 9.5:1)? Will it be better to install 1-step colder spark plugs? Will RON 98 fuel be enough for ~180 hp map?
Anyway, 170-180 hp is good enough, but there is not much info about JB4 and B38 engine. Is it still actively supported by JB4 (seems to be, as listed here https://burgertuning.com/collections...ni-b38-b48-jb4 , but some posts in this thread made me fell uncertain)?
What factors other then boost pressure are modified by JB4 in a B38 engine?
Also what is the difference in gains and what are limitations when using JB+ box and is it suitable for B38 engine (Here https://burgertuning.com/collections...-install-tuner it is listed in "Applications", but not in a heading)
Default 02-14-2020, 04:37 PM
Both JB+ and JB4 tuning is supported for the B38! Gains vary based on fuel but around 15%. The JB4 provides a lot more features and tuning options than JB+ but at a higher cost with a little more install effort.
