Justinberk335i Justinberk335i is offline
Car: 2007 e92 335i 6MT, 2012 e92 335i 6MT
Default @terry or anyone. Massive overboost after PI install - 09-22-2020, 02:01 PM
Keeps hitting boost cut so its nearly impossible to get a log that lasts more than 3 seconds. please help
Default 09-22-2020, 03:09 PM
Something is wrong with your WG or solenoid plumbing. Map1 is a WG spring map so no boost tuning is done.
Default 09-22-2020, 04:36 PM
Would my FF/Wastegate adaptation have anything to do with it? This pull was on Map2 by the way this was me testing the next map up after installing PI. It reverted to safety map1
ToolMaker335xi ToolMaker335xi is offline
Car: E92 335xi manual
Default 09-23-2020, 04:23 AM
Did you go over your solenoid plumbing? Just had the same issue.
34.5lbs in map1.
RB 2ís - inlets - dpís - borla mids - cp/bov- stage2LPFP -Hybrid e85_bef
Default 10-26-2020, 09:59 AM
34.5lbs in map1.
With a twin turbo setup (vacuum baesd WG) it has to be a physical issue with the WGs here....
Default 10-27-2020, 01:46 AM
It certainly was.
I replaced the solenoids and didnít pay attention to the lines since the solenoids are marked, but I misinterpreted the marks. ( as VAC pulled vac, not ďvacuum inĒ and OUT as vacuum out, not ďoutputĒ ) dumb mistake on my part.
I didnít think to double check a diagram since the car drove fine until going WOT. I figured it out the day I came across this.
I hope the original poster was able to resolve his issue too.
