ToolMaker335xi ToolMaker335xi is offline
Car: E92 335xi manual
Default log review - 07-07-2020, 06:56 PM
E40 mix.
It's been a while since posting a log, been trying to find the cause of why i'm smoking constantly coming to idle. Don't know if I could have internal problems? Or just PCV related.
car is running great, just did a compression test recently results were 180->175 on all six. just have in the back of my mind something is up with the car, its smoking more than ever.
never seen avg ign at 0.0 either in any logs.
or afr hit 20 drop and hit 20? about 500miles on new primary o2's. Is this misfires or something else?
Would like know if I should push it any more or just settle where it is at?
RB 2’s - inlets - dp’s - borla mids - cp/bov- stage2LPFP -Hybrid e85_bef
Default 07-08-2020, 07:04 AM
Originally Posted by ToolMaker335xi
E40 mix.
To me this looks cleans
How many miles on Turbos? Any oil consumption?
Default 07-08-2020, 07:55 AM
About 7k on the turbos. Recently oil consumption dropped 2 bars in about 550 miles.
Been smoking since day one of installing turbos and new exhaust. Don’t think it’s the turbos, but I have yet to pull the ***** and check for axial play. Leaning towards PCV related. But just haven’t solved it yet. Hoping it’s not something worse.
Ready to push it a little more until a weakness shows if it is something internal. Spoke with Rob the last two days and he seems confident the Turbos are still healthy.
Default 07-08-2020, 04:21 PM
Interesting, smoking seems to be increasing and oil consumption seems to be up. I’d check the Turbos, to be safe.
What is your current PCV setup?
Default 07-08-2020, 05:06 PM
Right on, I should.
PCV still has the flapper on the high side to BMS OCC. just switched vac side to the BMS vac side OCC. that’s when it got really smokey.
Looking back at smoking increased when I did an oil change and put in 0w40 for summer. Assumed it was coming thru the holes to the intake ports so got the vac side occ. it smoked a lot. So plugged the holes in the head to the intake ports. Got a little better then. Just yesterday I decided to see if putting 5w30 back in would make a difference and it did help. Only get an occasional puff of smoke when coming to a stop now so that’s why I decided to run a log last night.
Default 07-09-2020, 06:20 AM
Right on, I should.
No oil reaching the exhaust tips?
Default 07-09-2020, 06:31 AM
Nope... well not yet..
Took the flapper off this morning and discovered the o ring was missing. Put one one it. Got excited I thought figured it out, until I took for a spin and smoked like crazy again, even smoked during idle at the first stop I made.
Default 07-10-2020, 06:26 AM
I know a lot of guys blame smoking on PCV- which is possible, however if the smoke is excessive, I generally tell people, start looking elsewhere.
Default 07-17-2020, 06:46 AM
Issue resolved. PCV valve was pretty much non functional. Glad that’s all it was.
Ready to start trying a little more boost. Let me know what you want to see in my next log.
Default 07-17-2020, 11:37 AM
Let’s see a current log.
Default 07-18-2020, 02:38 PM
should be around E42-E43 mix,
blew the fuel tank vent valve hose off the throttle body adapter. I think it happened right after the pull.
Default 07-18-2020, 08:42 PM
Let’s see map 7
Default 07-19-2020, 04:32 AM
Let’s see map 7
Same fuel
Default 07-19-2020, 07:56 AM
Okay, I don’t like what the hpfp is doing
Few options- we drop down to say e30-35 to see if we can keep the hpfp happy & hopeflly hold timing or we can keep thing where they were?
Default 07-19-2020, 09:07 AM
I hear You. I was a little surprised it dipped to 8.
I’m going to leave it where it’s at for now and plan on upgrading HPFP soon.
It’s a shame I wasted the money on the first PCV setup that ended up being junk right out of the box or I’d be ordering the pump right now. Will always want more power. Oh well, I’m finally satisfied with the car for now.
Thank you!
Default 07-20-2020, 07:19 AM
Thank you!
Enjoy & be safe
