daniel0909 daniel0909 is offline
Car: 2008 135i
Default Jb4 jumping to map 4 - 07-07-2020, 06:37 AM
Hello everyone , decided to make this post as I'm new to the n54 world looking for some help reading my log , car keeps on jumping into map 4 after dp install and bigger intercooler , I'm thinking is fuel related . I do have wastage rattle but boost and target boost seems to be ok ,also fuel pressure don't look too bad if I'm reading correctly , any help would be appreciated . Attached is are 2 logs .
ToolMaker335xi ToolMaker335xi is offline
Car: E92 335xi manual
Default 07-07-2020, 07:18 AM
Iím definitely no expert here but just a few pointers enable 6cylinder timing. Iíd check for a boost leak too. You donít get close to target boost till around 3500rpm
RB 2ís - inlets - dpís - borla mids - cp/bov- stage2LPFP -Hybrid e85_bef
Car: 2008 135i
Default 07-07-2020, 07:41 AM
Hello , thanks for the reply , how do i enable clylinder 6 timing also , i think the spooling issue is due to my wasgate rattle fix . I have set very low to avoid having all that rattle.But i will for sure check for vacuum leaks . Thank you
Default 07-07-2020, 08:01 AM
Enable 6cyl timing- it’s under user adjustments
What fuel?
Your throwing safety 2 - afr lean
Your LPFP is in the 50s already - likely will need to upgrade
Car: 2008 135i
Default 07-07-2020, 08:23 AM
Hello , im using 93 for the most part , i was mixing for a while with a little of e85 and seemed to have no problems before the ******* dp .Thank you will try enabling cyl 6 timing, planing on going stage 2 lpfp , and a bef ,i really want to start making some power .
Default 07-08-2020, 06:55 AM
Id install the PUMP BEF ASAP- should clean up the AFR / trims
