(#6501)
NihonX NihonX is offline
Car: 1M
Default 04-13-2013, 11:26 PM
I searched and googled but couldn't find any results about something I am experiencing.
Am I the only person getting a very slow boost build up when accelerating sometimes? I have checked codes but nothing pops up. I haven't had a chance to log when this has happened but it does happen on long highway trips.
The next time I am going to SoCal, I will have my laptop ready for logs.
I just wanted to see if anyone else had this problem. I don't believe it has ever happened pre-ISO17. (I am currently on ISO18).
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 04-14-2013, 06:41 AM
Guys,
I am doing some troubleshooting...
I forget... when running the G5 board in integrated mode... without having snipped the diodes which drop down do i select from the list that I have here in the interface??
1. G4 N54
2. G4 N54 w/ BMS Flash...
3. N55 135/...
4. N55 F10
5. G5 ISO
6. G5 ISO w/ BMS flash
7. N55 ISO
2008 335i stock
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 04-14-2013, 06:43 AM
use
5. G5 ISO
Time is the best teacher
LuniZ74's Avatar
LuniZ74 LuniZ74 is offline
Car: 335i 2008 AT
Default 04-14-2013, 03:02 PM
You'd have to look at your logs to ensure it's safe. Map 7 won't check for timing drops, etc, so you're on your own for it.
Does Map6 check for drops etc or Map5 only?
Oshusttoley Oshusttoley is offline
Default 04-14-2013, 07:21 PM
im getting this but im not iso but g5 board
jim66 jim66 is offline
Car: 335is
Default 04-15-2013, 03:32 PM
JB4 G5 board going ISO- how long does it take to load the hex file? trying and it just says (loading hex )
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 04-15-2013, 03:34 PM
2 mins at the most
Default 04-15-2013, 03:38 PM
Map 5 and map 3 are the only maps that will adjust themselves as a function of timing advance.
Car: 335is
Default 04-15-2013, 04:23 PM
Finally got the Hex 18 firmware loaded, cut the 2 diodes and took a drive, 2013 335is...man this car likes that tune, car has DCI, DP's and charge tube all of Terry's products.
And from another satisfied customer, Thank you Terry keep up the great work!
Christov89 Christov89 is offline
Default 04-16-2013, 07:59 PM
Any videos of your car? I'm always interested to hear what the IS sounds like with ***. There's just not as many in circulation
abistro abistro is offline
Car: 2009 335xi
Default 04-17-2013, 07:04 AM
Is it just me or Hex 18 is a lot smoother than 17. I feel the shift points are much smoother after loading Hex 18 and on map 5. Great work!
Car: 335is
Default 04-17-2013, 07:47 AM
no video's but I can say it's loud...a good loud.
So I ran map 2 the first day and switched to map 5 last night and seems to pull as well but would like to test once JB4 is adjusted to the car. This morning at startup my car went into limp mode ( 1/2 yellow engine) i turned the car off and restarted and the light was still on. i headed to work anyway and about a mile into the drive the light went out and everything was back to normal...maybe getting adjusted.?? hopefully it will be ok from here.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 04-17-2013, 03:31 PM
Check codes... sounds like 2ABD code perhaps.
Grip&Go Grip&Go is offline
Car: 135
Default 04-17-2013, 03:48 PM
i am getting the 29f3 code after i switched to 3 gallons of E85. should I adjust the open fuel loop to fix this?
Default 04-17-2013, 05:49 PM
Nope. That code means you need a new low pressure fuel sensor, normally.
Car: 135
Default 04-17-2013, 06:24 PM
Ok so it not an effect of the e85 and also should i be running the 18 or 19 ISO? I didnt get the fuel sensor code until i updated my G4 board and ran 50/50 e85 on bad plugs. I just switched to a g5 board today and did new plugs.
Default 04-17-2013, 08:03 PM
If you need tech support email or use the support forum.
Car: 135
Default 04-17-2013, 10:19 PM
will do thanks!
jrsniper12453 jrsniper12453 is offline
Default 04-18-2013, 04:00 PM
Just to be doubly sure... to upgrade from jb4 g4 pin out to g5 it's just a straight switch of the box right? No changing wires?
Kongdom Kongdom is offline
Car: 2007 335i e93
Default 04-18-2013, 05:29 PM
Sorry, how do i know what ISO version my JB4 g5-ISO is running? Just got it a week ago, and put it in car. When i connect to the laptop, it shows firmware Ver "3/16/13//2" and interface Ver "4/11/2013' . Interface date seems like latest one.. is it? I'm new to the Jb4. My G5 board has ISO written on it so i know it's the ISO version, but does it come with ISO firmware?
Default 04-18-2013, 06:20 PM
That is an older ISO version. Latest version is in the first post.
Nope. May need to change around purple/green wires per G5 notes.
desty desty is offline
Car: 135i 08
Default 04-19-2013, 10:35 AM
If i set the map 5, does the lagfix autoset itself?
Car: 135i 08
Default 04-19-2013, 10:38 AM
Heuh, if i come from JB4 PNP G4 i need to change wires around for the G5 Board? I'd like to know since i already put everything back together on my car :\
i remember back then i had a jb3 and when jb4 came out , about 2 years ago i sent my jb3 and harness to burgertuning to modify the harness for the jb4
and is there a way with everything installed to know if i have to change the harness?
Paulito Paulito is offline
Car: 07 AW 335I Coupe
Default 04-19-2013, 10:54 AM
Nvm!!
