(#5101)
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 09-25-2012, 09:13 AM
Terry advises MS109 only.
2008 335i stock
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 09-25-2012, 09:16 AM
OOO im gonna have to go buy a can of Ms109!!! the hell with E85.
I dont think 50% E85 would be enough for Map 7 now.
2014 F10 535i N55 PWG
Default 09-25-2012, 10:21 AM
Originally Posted by Vertigo
Terry, can i achieve 103 octane using 50/50 E85 and 93? Or is this going to be race fuel only map?
I'm not sure the fuel system will support E85 mixtures at these boost levels without our flash. If you know what you are looking at you are welcome to try it. But we've only tested it in house with MS109.
piele_bps's Avatar
piele_bps piele_bps is offline
Car: BMW 335i Sedan
Default 09-25-2012, 10:29 AM
For those who wanted 19 psi there was always Map6. Why this need for Map 7 to be tuned at 19 psi ?
2007 E90 335i.
JB4 G4.
FBO+METH.
Vertigo's Avatar
Car: AW 335i
Default 09-25-2012, 11:09 AM
So if one were to want to try map 7 using e85 one should keep an eye out of the fuel trims and that's it?
2008 335i stock
Default 09-25-2012, 11:13 AM
Those who would use map 6 often would not add in the proper taper to redline resulting in worse performance. There is certainly no need for these map 7 changes, but I do think it will make life easier for those running race gas at the track.
robc1976's Avatar
robc1976 robc1976 is offline
Default 09-25-2012, 11:37 AM
Terry, curious when you think you will have the "isolated boost" stuff will be done....I can't wait for his, when I get my RB's here in a week I will do the 2step and map 7 but that isolated boost sounds just awesome!!
robc1976's Avatar
Default 09-25-2012, 11:39 AM
I would get there flash and put in 60-80% E85 and then try it.
lecsoman lecsoman is offline
Car: 2007 E90 335i A/T
Default 09-25-2012, 11:52 AM
+1,
but i would dare with 50% E85 + 100 octan fuel here (EU), since that also has a few % Methanol and a few % Ethanol here.
Slow, stupid and angry...
2007 E90 335i AT, G5 ISO, FSB, BMS flash, RB's, RB PCV, DP's, ER OC's, Injen DCI, BMS OCC, FMIC, ER CP, Tial Q BOV, Walbro 455 LPFP, Snow meth kit injecting E85, runnung on E40-50, Alpina TCU flash, Wavetrac LSD.
Coming: BT FMIC, bigger better water rad.
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 09-25-2012, 11:53 AM
Wish there was another way for flashing.I'm getting the g5 looks like Thursday.I don't feel like spending 800 for a Cobb just for that.
How about if someone else had a Cobb.could I get it flashed if Cobb is on another car for me?I have e85 here.wonder if it's beneficial.
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
Default 09-25-2012, 11:56 AM
If you want to run the flash you need the AP... We carry them and can beat any price on them if you need but it only works on one car at a time.
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 09-25-2012, 12:04 PM
Ok T, thx.
SOLD
PRESENT RiDE
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 09-25-2012, 03:26 PM
So I understand with Cobb ap flash you can run a higher e85 in car? Without a flash with e85 with jb4 G5 what's the difference? Is there a limit waste of e85 without a flash? Can I run a 30/40% e85 & see same performance as opposed to with a flash?
SOLD
PRESENT RiDE
robc1976's Avatar
Default 09-25-2012, 03:37 PM
With the Cobb flash I would suggest upgraded turbos because with E85 without a flash you are at the limit of the stock turbos (17-18.5) but with upgraded turbos (RB's) you can run higher boost but will need higher octane for higher boost targets and that is where the Cobb comes in to play. The Cobb helps with higher fueling to reduce fuel codes/problems.
BostonBeemah's Avatar
Car: AW 135i
Default 09-25-2012, 03:46 PM
can we buy any accesport like for example one from a subaru or something and make it work or do we need a specific one for a BMW? Im assuming it would work because its just a flashloader through the OBD
RIP 2008 AW/BL 135i
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 09-25-2012, 04:00 PM
Ahh ok so really a flash is beneficial to upgraded turbo not stock turbo then.
SOLD
PRESENT RiDE
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 09-25-2012, 04:02 PM
If a flash is still a big enough improvement with fbo meth e85 & stock turbos then I may do it.just need some more feedback.if this was already explained then can someone post it where i can read up on this thx
SOLD
PRESENT RiDE
robc1976's Avatar
Default 09-25-2012, 04:13 PM
I would say it s a benefit if you are having fuel codes/ fuel problems. I was hoping to do it with my stock turbos but I am getting RB's so I most definetly going to do it.
N54 TuNeR's Avatar
Cool ///Member
Car: E90 SEDAN
Default 09-25-2012, 04:35 PM
found this so it answers my question
The back end flash will likely be worth 0hp on stock turbos + meth.
Where it can benefit is those running E85 with stock turbos, where fuel trims are maxed out holding back performance.
SOLD
PRESENT RiDE
robc1976's Avatar
Default 09-25-2012, 05:01 PM
Yep, and this with larger turbos requiring higher octane.
Vertigo's Avatar
Car: AW 335i
Default 09-25-2012, 06:04 PM
So what octane do the 3.0L 2JZ folks run with those T76's?
2008 335i stock
kkashanchi kkashanchi is offline
Default 09-25-2012, 06:26 PM
depending on how much power theyre pushing... a lot of them are on pump or e85
MathR601's Avatar
MathR601 MathR601 is offline
Default 09-25-2012, 06:53 PM
Octane is not directly related to the size of the turbo... There are too many factors. Those guys run low compression pistons for example.
JB4 G5 ISO, BMS DCI, 3" AR ***, E85, BMS OCC, BMS Spacers, ECS Blackout Kidney Grille.
Stucks Stucks is offline
Default 09-25-2012, 08:35 PM
new firmware bump! cant wait to try it out when i get a chance!
Current: 2008 e92 335i coupe.
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 09-25-2012, 08:48 PM
I aint a expert, but the flash with the JB4 G5 on stock turbos seems like overkill and not needed.
I run 30-40% E85 mix and i first hard problems of hitting limp at WOT 3rd into 4th.. I shut off auto open loop and the car runs great..
So i guess it for guys who want to run crazy amount of E85 on stock turbos?
