(#5051)
BostonBeemah's Avatar
Car: AW 135i
Default 09-20-2012, 07:57 PM
Originally Posted by Maximum996
Hey terry, can you post up the different settings and what they do ...for example all the future use settings (a,b,c,d)...fua2 disable auto learning open loop...fud10 afr bank 1 &2 in hfp and oil temp log fields...fud11 oil temp instead of lfp...fud99 rattle fix......those are the only additional settings i know of.
I also think this would be useful if your up to it Terry...
RIP 2008 AW/BL 135i
Default 09-20-2012, 09:55 PM
Most of them are for diagnostics only and not for general public use. Ones we want people to know about we put in the firmware notes.
Milwaukee135's Avatar
Milwaukee135 Milwaukee135 is offline
Car: 2008 135i
Default 09-21-2012, 09:07 AM
Just got my G5 installed. Wow that was 30 minutes happily spent.
The power is smoother and my PWM is much lower now to achieve the same boost. it seems like it's just better managed.
So far everytime I've tried to log a long WOT to get a good looking curve to show everyone, I get wheel spin as boost hits 17 psi in 3rd (roughly 3500 rpm). This is on 8.4" wide V12 Hankooks on dry concrete (35/65 E85/93).
Also, no codes after a couple days and so far no serious wastegate rattle!
Tuning Obsessed Central Oregon Engineer
08 E82 N54 (bimmerboost flash tuned by me)
Car: 2008 135i
Default Interface Feature Request: Linux - 09-21-2012, 09:13 AM
Terry et al,
Any chance you'll make linux and mac executable versions of your JB4 interface?
All the cool people use linux or mac (freeBSD) these days.
Last edited by Milwaukee135; 09-21-2012 at 09:14 AM.. Reason: added 'mac' to first sentence. Also, I need a secretary
Default 09-21-2012, 09:27 AM
Glad to hear! Just wait until we post the ALPHA isolated boost software.
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 09-21-2012, 10:27 AM
Still wondering when the world is going to realize that the once cheap hankook ventus Evo v12s are terrible for a high hp car.... Lol
With a g5 you should get a pair a proper set of rubber!
e92
Car: 2008 135i
Default 09-21-2012, 10:32 AM
Fair enough. You can blame TireRack. They gave them high marks for dry traction.
Still though, they are better than stock run-craps. And yes, they were cheap.
I am looking to get nice and wide 19's someday (when my wife isn't looking). Then I'll rethink my 'rubber'.
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 09-21-2012, 12:11 PM
Running Michelin pilot super sports, and they seem to almost be just a little better then the stock run flat in terms of straightline traction. I spin em either way in second. A little more grip i guess but i was expecting more.
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 09-21-2012, 12:23 PM
Yes, PS2's & PSS's are awesome on the twisties, but a bit disappointing for straight line.
I still wouldn't mention them in the same sentence w/ run flats.
enrita's Avatar
enrita enrita is offline
Default 09-21-2012, 01:24 PM
Lol ! Do you expect traction in 2nd gear on street tyres?
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
bimmer305's Avatar
bimmer305 bimmer305 is offline
Car: 2007 335i E92
Default 09-21-2012, 06:05 PM
Waiting for my G5 board to test this new map, damn USPS
After paying $9 a gallon for race gas, I think I'm in love with E85...
JB4 G5 / DCI / CDP's / VRSF 7" Intercooler / E85
Kollegga's Avatar
Kollegga Kollegga is offline
Default 09-22-2012, 03:13 AM
OT:
Which Tyres will be great for straight line and Autobahn ?
Car: 2008 135i
Default A Log - 09-22-2012, 11:37 AM
This was done on a rather steep uphill with some slight rolling bumps. Just enough to make sure I never got much traction for too long.
I turned off traction control, so this is the e-diff. I like the e-diff personally.
This is 3rd gear.
Some meaningful numbers from the csv:
time = 112.5 sec :: 2500 rpm = 40 mph (78 percent pedal, 7.4 psi boost, 11 psi target)
time = 112.8 sec :: 2650 rpm WOT and 9.4 psi boost (target == 15)
time = 113.3 sec :: 3075 rpm target 15.3 psi hit
time = 117.0 sec :: 5563 rpm == 89 mph lift pedal
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 09-22-2012, 12:14 PM
I've been told leaded race gas will tear up O2 sensors pretty quickly. I've ran a mixture of it a couple times. No O2 issues. I'm sure it'll be fast though. LOL
2011 335is DCT, FBO
bnk bnk is offline
Default 09-22-2012, 12:23 PM
That's why unleaded race gas should be used rather than leaded race gas.
Vroom's Avatar
Car: 335i 318ti
Default 09-22-2012, 12:51 PM
Originally Posted by Kollegga
OT:
Don't know any tires great at both.
After all you have a bimmer so you should have seperate wheels & tires for the street, track & winter plus a set of drag radials for the strip.
bimmer305's Avatar
Car: 2007 335i E92
Default 09-22-2012, 02:56 PM
Yeah I was just told the same thing
I dint know if I should run it pure or mix it with regular gas. I dont think it will damage anything it is just 5 gal.
Car: 2008 135i
Default 09-22-2012, 08:41 PM
Maybe this is a dumb question, but what exactly is isolated boost?
Last edited by Milwaukee135; 09-22-2012 at 08:42 PM.. Reason: I seriously can't type
kkashanchi kkashanchi is offline
Default 09-22-2012, 11:12 PM
what do you guys think of using the 2step with ********* *** but still retaining secondary cats?
think this will cause any problems?
lecsoman lecsoman is offline
Car: 2007 E90 335i A/T
Default 09-23-2012, 01:50 AM
I would say that isolated boost means that the G5 will be able to set any boost totally independet from the DME's requrements. I think this will allow the G5 to set high boost even if the DME thinks its not possible.
Slow, stupid and angry...
2007 E90 335i AT, G5 ISO, FSB, BMS flash, RB's, RB PCV, DP's, ER OC's, Injen DCI, BMS OCC, FMIC, ER CP, Tial Q BOV, Walbro 455 LPFP, Snow meth kit injecting E85, runnung on E40-50, Alpina TCU flash, Wavetrac LSD.
Coming: BT FMIC, bigger better water rad.
Default 09-23-2012, 01:51 AM
I'm sure it won't cause any problems on short term, i guess you don't use it every morning.
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 09-23-2012, 07:17 AM
Yes i did! lol I thought for the ratings, and price i paid they would be a better in straight line grip then the damn runflats.
Car: 2008 135i
Default 09-23-2012, 07:22 AM
I can't push the pedal past 60 percent in 2nd for more than a second anywhere above 3000 rpm without seeing the nagging yellow light.
It's a good way to test the e-diff though when you turn off traction control!
Eleventeen Eleventeen is offline
Default 09-23-2012, 10:43 AM
The price should be the least of your worries. You shouldn't be running that gas in your car even if it's $.01 per gallon. With leaded gas, you will end up paying for 4 new O2 sensors and having to go through the hassle of replacing them all.
Ferrari Red F80
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 09-23-2012, 03:47 PM
Does the G5 firmware have the same small update to reduce 29F2 codes with E85 mixtures as the G4?
