(#51)
drfrink24 drfrink24 is offline
Car: FBO 335xi w/FSB 50/50 meth
Default 08-20-2012, 12:05 PM
Ballpark on potential WHP gains when running FBO + Meth + e85?
e85 flows like wine here in MN...
enrita's Avatar
enrita enrita is offline
Default 08-20-2012, 12:21 PM
+ upgraded turbos? 50% E85?
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 08-20-2012, 12:31 PM
If your JB4 settings are dialed in as good as they can be, and your car reacts well to it with proper AFR and good timing this wont do you much good other than the ability to log more parameters...
But if your trims are maxxed, timing is inconsistant, AFR isnt where you want it, getting cobb and a custom tune will help... overall I think it will be more consistant
For whatever reason my new auto 335i n54 when I have the FP mapping set any higher than 75 I get rich spikes at shift and timing takes a shlt after shifts leading to the car having an odd and sudden stop in accel completely than regains some pull. but timing will flatline terribly... I can lower FP mapping to help it but this perticular car just doesnt react well to JB4 or g5 at all.. Not really sure why and terry says mine is a pretty rare case... A flash of the ECU should do me well in my situation...
I ordered this from terry and will try out his tune. PTF is another option for a Etune but if terry's works that is where i will stop because he will have it tuned to work with meth and once you are running a good timing curve , with good afr, and trims not maxed thats all you need on stock turbos+meth...
As far as tuning for e85 im sure terry can add some advance over the standard flash to help with making extra power... From car to car will be very different I dont think anyone can say what HP you will gain from this..
e92
Default 08-20-2012, 12:47 PM
Man, I am full of fail today.
I already run:
15 ohm JB4 + FBO + Meth + e45
vs.
Flash + same setup, with perhaps stronger e85 mix?
Just trying to see if this is worth it if I don't plan on RBs or an upgraded single.
Default 08-20-2012, 12:55 PM
With OEM turbos no real need unless you have a car that is finicky with fuel trims, 29F2 codes, etc.
enrita's Avatar
Default 08-20-2012, 01:05 PM
I already run:
vs.
not worth it than...
Default 08-20-2012, 01:15 PM
Don't think so, at least, haven't seen anything in logs and haven't seen flashers going off before rev limit hits.
I've bumped things upto 55 additive, with AMS FMIC and 52 degree ambient, lets just say it pulls pretty hard.
My goal this winter is to break the IAT record (whatever that is) or just set it, (safely, of course), hoping for some -30F ambient + meth.
Boost target will probably be like, 12 psi in those temps.
enrita's Avatar
Default 08-20-2012, 01:30 PM
jb4 will always boost the same.... with that low temp i doubt you can even get traction in 4th.
Default 08-20-2012, 02:00 PM
AWD + snow tires
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 08-20-2012, 08:15 PM
It's all about the tires. I dead hooked in 22 degree F weather in 2nd gear FBO + meth @ 18 psi with my Continental DWS
E90 LCI N54 6AT
imageautodetail's Avatar
imageautodetail imageautodetail is offline
Car: 335 e90 spt pack 6mt
Default 08-21-2012, 03:51 AM
mines been doing the same thing, 08 335 at...ill get running about 90-95% for one good pull, then the next run is doo doo, been going thru it for a few weeks and cant figure it out, I hope this flash will help
enrita's Avatar
Default 08-21-2012, 05:46 AM
those are All weather tyres, not winter tyres. if i put those on during winter i cant even drive the car
enrita's Avatar
Default 08-22-2012, 07:30 AM
Originally Posted by Ramjet
Noob question sorry - new to flashing, but how do I tell my ECU version???
you know when you connect the cobb ap
Ramjet's Avatar
Ramjet Ramjet is offline
Car: Z4 s35i 7DCT
Default 08-23-2012, 04:00 AM
Thanks enrita - that really does sound obvious now you have said it
E89 N54 / Wedge / RB Turbos / AFE DCI / HPF FMIC / Stett CP / Forge DV's / AR Cattless DP's / BMS OCC / RB PCV2 / BMS Spacers
Ramjet's Avatar
Car: Z4 s35i 7DCT
Default 08-24-2012, 05:15 PM
Well after getting past a bit of noobiness (new to flashing) I successfully installed the BMS flash. I must say Terry, it feels great! Silky smooth power application and very solid feeling on the bum dyno. If this just the beginning, I can't wait to see this in a developed stage!
I'm off to the track tomorrow (circuit not drags) to stretch the cars legs
Default 08-24-2012, 05:35 PM
We have updates often so once you get a log done send it in and we'll go from there.
Kollegga's Avatar
Kollegga Kollegga is offline
Default 08-29-2012, 01:05 PM
I own normal JB4 without 15 ohm mod.
Installing RB Turbos in a month.
will driving 30-60 % E85 and maybe install meth.
Should i update to G5 and buy Cobb from Terry?
Or should i buy just COBB from Terry?
Or should i just update to G5
TY :-)
Default 08-29-2012, 01:14 PM
Probably best to get both. The G5 upgrade is only $50 if you had bought the JB4 from us.
Kollegga's Avatar
Default 08-29-2012, 01:18 PM
TY
But will be 150$ for me because i am living in germany and parcel to and from US is expensive so it doesnt matter sending or not. ^^
i will buy both
Even at $150 it's sort of a drop in the bucket compared to the cost of RB, labor, Cobb, etc.
Kollegga's Avatar
Default 08-29-2012, 01:22 PM
i know so i do it ^^
CPS also nessecary?!
Car allready has a programmed SLD in ecu
Default 08-29-2012, 07:28 PM
Nope, with the BMS flash you don't need the CPS or SLD wires. Just get the 2STEP relay if you are a manual trans. Otherwise just the G5 board.
temperamental's Avatar
temperamental temperamental is offline
Default 09-12-2012, 11:18 AM
What about using the BMS cantool to download the backend flash? No Alternatives? There must be cheaper options than having to pay for a Cobb that is restricted to one VIN...?
JB4 //MMP Stage 3 turbos//Custom Exhaust/BMS DCI//FMIC/KW suspension//Pi & Fuel it stage 4/MHD
BEF /CP&TIAL/ OCC.
lecsoman lecsoman is offline
Car: 2007 E90 335i A/T
Default 09-12-2012, 11:21 AM
One Cobb AP is restricted to one VIN?
I imagined that one flash is restricted to one VIN...
Slow, stupid and angry...
2007 E90 335i AT, G5 ISO, FSB, BMS flash, RB's, RB PCV, DP's, ER OC's, Injen DCI, BMS OCC, FMIC, ER CP, Tial Q BOV, Walbro 455 LPFP, Snow meth kit injecting E85, runnung on E40-50, Alpina TCU flash, Wavetrac LSD.
Coming: BT FMIC, bigger better water rad.
Default 09-12-2012, 11:24 AM
I understand so unless one goes for the Cobb professional which is unlimited but its way outside my budget.
BEF /CP&TIAL/ OCC.
