GAaaAR GAaaAR is offline
Car: none
Default BMS Flash? - 09-02-2013, 07:51 PM
Haven't been following forums for awhile so just want to do some quick catch up. Sorry in advance as I'm sure this has been discussed but just couldn't find anything definitive.
I understand the BMS flash allows the ECU to control fueling and the JB4 be focused on boost. If you are only lightly modded with just a tune or Tune + DCI would the flash help at all?
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 09-02-2013, 08:18 PM
It's still of benefit. Makes the car smoother cause the ECU is better at the fueling/timing and JB4 is better at boost.
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
aoschadlin's Avatar
Car: 535i
Default 09-02-2013, 08:19 PM
Nope.
It's really to help adjust the DME settings for big turbo cars, those running higher concentrations of E85 etc.
coolbho3k's Avatar
Car: BMW 335xi
Default 09-02-2013, 10:30 PM
Originally Posted by aoschadlin
Nope.
You also get built-in speed limit defeat and a raised rev limiter to 7200 in addition to the fact that the JB4 doesn't have to hack the DME for timing/fuel anymore. And I read somewhere also improved transmission line pressure for AT cars?
I've had the BMS flash on my lightly modded car and it's been a blast.
Car: none
Default 09-03-2013, 03:39 AM
Thanks so the consensus is that the BMS flash would help regardless of what my mods are as long as I am tuned correct? What is I took out my tune, will i have to reflash to stock or I can still use the BMS flash?
pj_rage pj_rage is offline
Car: 08 335i
Default 09-03-2013, 11:32 AM
I actually have the same question. Currently running the JB4 G5 ISO with only DCI and I've been happy with it. It's the only thing I've tried so I have no basis of comparison. It does feel pretty smooth already, but curious if the backend flash would make it even smoother.
Ultimately, I'm curious if I should pony up $179 to buy the BT cable and try it out or not. I don't have any near term plans to run any E85 or meth, nor bigger turbos, pretty much just DCI and eventual intercooler and *********. If it's noticeably smoother (or faster for that matter), to me that would totally be worth it. But if there is no noticeable difference, then I wouldn't consider it worth it at this time. Anyone tried it out with just DCI and pump gas (93oct)? How is G5 ISO only vs with backend flash?
