mastamike911's Avatar
mastamike911 mastamike911 is offline
Car: 2011 335is vert
Default 01-20-2016, 03:40 PM
Originally Posted by Texsquirrel
I know somewhere in the Houston area that you can get them installed cheaper than you were quoted.
It will be less than you pay for the PR inlets.
Wanna drive down to TX?
Where in Houston? Do they also do turbo installs?
dawhiz's Avatar
dawhiz dawhiz is offline
Car: 09 335xi
Default 01-20-2016, 03:44 PM
I went with the factory airbox and RB inlets. Factory airbox sounds sooooooo much nicer to me, since everything is dampened. DCI was too loud post install. I have Turbosmart Kompact plumbback and they got really loud. Slightest let off and you'd hear a big poof back into the inlets.
Factory airbox however, I'm liking it. RB turbos too so the way I figure it, i'm only going to tune so far anyways and leave stuff on the table... so gains from DCI vs factory won't make too much of a difference in the end. I think DCI matters more before you've thrown everything on including turbos and inlets, unless you're trying to max.
suspenceful's Avatar
Car: 2008 BSM 135i
Default 01-20-2016, 09:39 PM
What is the TurboSmart Kompact thing I've read about? Saw it as an option on VVTs website.
Also, do I need to upgrade my MAP sensor with inlets on stock turbos?
🚀 My 750HP 135i build: my1series.com
🔧 My budget 335i build: bmw335i.com
📷 Follow me on Instagram: instagram.com/jakespence
🎬 Watch me on YouTube: youtube.com/jakespence135
🌟 Support me on Patreon: patreon.com/jake_spence
🏁 Shop BMW merchandise: bimmerstreet.com
dlp3719 dlp3719 is offline
Default 01-20-2016, 10:03 PM
No. My Stock turbos are going to 21-22 psi. Don't need n20 TMAP yet.
The power really comes in high RPMs where you still have good boost
2007 n54 e90 sedan (1/07 date), JB4 G5 ISO - Map 3, BMS DCI, BMS Trunk Tank Meth Kit - two nozzle - CM7/CM10, BMS OCC, MHD Trebilia Flash, e60 (5 gallons of 93 and 11 gallons E85), Stage 2 from Fuel-It, VRSF 7" FMIC, N54tuning.com V1 DP, ER Charge Pipe w/Tial BOV, NGK Iridium (one-step colder) plugs, N20 TMAP Sensor, RB turbo inlets, VTT outlets
GAaaAR GAaaAR is offline
Car: none
Default 01-20-2016, 10:11 PM
For those that did inlets. How does the difference compare to when you did ***? More or less?
Default 01-20-2016, 10:18 PM
I was having my subframe dropped to have the oil pan gasket replaced. I added on inlets for 2 hours of labor.
dawhiz's Avatar
Car: 09 335xi
Default 01-20-2016, 10:55 PM
http://www.topgearsolutions.com/turb...0203-1250.html
Look around on price but that was the best on first page of google. Runs the air back into the inlets (stock-like) so much quieter. Still louder with DCI but with factory airbox it's perfect. Should be less than a atmospheric BOV though.
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 01-21-2016, 07:39 AM
PM sent
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 01-21-2016, 08:08 AM
Originally Posted by rhodesman
I have that exact same intake, the BMS DCI. They fit perfectly w/o any modifications or adaptors. You can even use the stock airbox with the VTT inlets... but at that point, why would you?
how hard was it for you to install...i know it's subjective.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
JM35's Avatar
JM35 JM35 is offline
Oner
Car: 08' 135i
Default 06-10-2017, 01:52 PM
PM sent
Sorry to revive an old thread, but would also love to get the name of the Houston shop you are referencing. Thanks
mcduvall2000 mcduvall2000 is offline
Car: 2008 E92 335i
Default 07-24-2018, 08:22 PM
So the mmp inlets are a pain, but the rb inlets are much easier to install? I'm going to be doing *** and oil pan gasket soon. What makes one more difficult than the other?
beencrashed beencrashed is offline
Car: 2009 535i
Default 07-25-2018, 09:50 AM
I installed my inlets in my driveway in no time. I made sure i had a buddy to help with the rear. I was under the car with a piece of rope tied to the bottom 90 and he pushed from the top. The down ***** took the work not the inlets but I am 535i
WallyY WallyY is offline
Car: 2008 BMW 535i
Default 07-25-2018, 10:35 AM
Terrible experience with MMP, high recommend staying away from them.
Six Pot's Avatar
Six Pot Six Pot is offline
Default 07-25-2018, 11:14 AM
I just did MMP relocation inlets, not terribly hard. I ended up removing the *** and driver side motor mount to ensure the rear inlet was snug and tight as the rear turbo connection is very short. Did mine in 4 hours but had access to a lift.
2011 BMW VO 1M
ViE 3884 GTW 67mm 1.0AR Hot Side T51r Mod | PR Coil Packs
JB4 ISO | MHD | PR Stage 4 Elite | DOC Intake Manifold + TiAL + Pi
Seibon Dome Hood | Spec Twin Disk | PSP 900 IC | Slek Front Lip / Diffuser
Apex EC7 Wheels | KW HAS | N55 Mid + Y Pipe | P3 | ADe Catch Can
Car: 2008 BMW 535i
Default 07-30-2018, 11:04 AM
Sorry, to clarify I was talking about their awful customer service.
rhodesman's Avatar
rhodesman rhodesman is offline
Default 07-30-2018, 11:43 AM
Seriously? I was installing the 1K's this past weekend and was messaging Eugene all through it and he was responding to me within minutes if not seconds of me sending him posts/questions.
Engine/Drivetrain Modifications:
Trebila tune, xHP stg3, BMS OCC, BMS DCI, VSRF ceramic 3", ER Charge Pipe w/ Forge DVs, AMS Intercooler, Fuel-It Stg3+ LPFP, Pheonix Intake W/ PI, MMPe 1k's
Suspension:
Front & Rear 1M/M3 control arms & Subframe Bushings, MFactory YCW coils w/ Swift Springs
Exhaust:
Berk Street Performance Axle-back w/ straight Midpipes
Car: 2008 BMW 535i
Default 07-30-2018, 12:12 PM
Made a thread in relation to what happened, you can be the judge if you wanna read it haha.
http://www.n54tech.com/forums/showth...076#post598076
rhodesman's Avatar
Default 07-31-2018, 01:07 PM
thanks, was a good read.
Suspension:
Exhaust:
Car: 2008 BMW 535i
Default 07-31-2018, 08:32 PM
No problem, good luck if you use them in the future!
