09-04-2021, 02:24 PM
That is if you have an upgraded turbo.
What year is your car?
What fuel are you using?
What mods do you have?
Car: 235i bmw
Back End flash -
09-04-2021, 11:04 PM
Thanks for the feedback
I have :
N55 BMW M 235i F chassis
BMS Charge pipe
Upgraded Intercooler
Performance exhaust
BMS air intake
Jb4 with ver 19 hex file
I am looking for the correct back end flash file?
Car: 235i bmw
95 Oct fuel
Car: 235i bmw
09-04-2021, 11:05 PM
Sorry .. year model is 2016
09-06-2021, 11:35 AM
Start with the EWG Pump flash. Run a bunch of logs on map 1. If clean run map 2. If still clean flash the EWG Race flash. And repeat. If map 2 is still clean try out map 5 for a bit and decide if you prefer it or map 2.
Car: 435i f32 2014
Mhd bef -
01-10-2022, 01:34 AM
Hi... I hawe question...
Is posible to set more agresivne bef map?
Car: 2014 435i
01-10-2022, 03:17 PM
From what I understand, you would need a different vendor/tuner to provide a customer bef beyond what BMS offers. You can create custom Jb4 settings via nap 6.
2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package
Car: 435i f32 2014
01-24-2022, 01:21 PM
Thanks,
I am new here.😊
Where can I send logs to someon suggest me how to set map 6
Car: Evo VIII
01-24-2022, 01:52 PM
You can post in the N55 support and log review or email me directly at cannon@burgertuning.com
Car: 2013 F30 335i
BEF files -
03-07-2022, 01:18 PM
I see the option of PWG3_Race_IGN now when flashing with MHD… what uses is this “IGN” file intended for?
I’ve seen a few people ask this and still have yet to get a reply. Also is there any difference between the PWG1/2/3 races files or all these the same?
I recently flashed this IGN map with the new MHD “brap” and anti lag and my car literally won’t pull. Just bogs down bad when launching then seems to go into limp mode. Taking these ricer settings off asap and taking a log. Also had an open thermostat code after the re flash, thought that was odd, could hear the cooling system going full blast. cleared code and problem went away …
2013 335i 8AT - FBO JB4 + BEF
VRSF **, IC, CP, Injen Short Ram, H&R SuperSports
03-07-2022, 02:04 PM
The IGN BEF runs more timing advance for those on higher octane via WMI, race gas, or E85.
For anti-lag I'd have to see the log myself for advice on that.
Car: 2013 BMW 335i xDrive MSport, JB4, BMS intake, ******* ********, Corsa Exaust
04-13-2022, 02:44 PM
Same issue here... no boost or fluctuating low boost up until 3200RPMs... then eventually will get a "Powertrain Malfunction.... " message...how did you fix it?
2013 BMW 355i xDrive M-SPORT/MPPK, JB4 Flex Fuel, BMS Intake, Corsa Pro Series, C* Less DP.
04-13-2022, 02:54 PM
Post up a log and lets check it out. PWG F chassis are always a bit of a headache.
Car: 2015 335i
04-13-2022, 02:57 PM
I plugged the stock ewg harness back but now I'm wondering if it was the harness or the Wastegate itself is the issue but I haven't had the drive train issue since
04-13-2022, 03:43 PM
I've just flashed the latest F Series N55 PWG1 Race, which is the one I've always used to use, no Turbo Lag option on the MHD... its raining hard here so no chance to log it now. Will so ASAP. Thanks all!
Car: x1 35i
Fuel pump priming after BEF -
04-22-2022, 09:12 AM
I have a n55 35i x1 and flashed the Backend Flash for use with the JB4. This is the pump flash file.
I noticed that my low pressure fuel pump is not priming anymore when I open a door or unlock the car.
Is this normal and suppose to happen with this flash?
05-11-2022, 07:08 AM
Hi Terry
doing that just now.
Thread Tools |
Display Modes |
