Newguy123's Avatar
Car: 12' 135i
Default N55 DCT with M4 flywheel - 04-26-2017, 10:57 AM
Low and behold the answer to all of my misfires over the last 2-3 years! Can't thank Pure Turbos enough for continuously working at a soloution to these pesky misfires! To keep this short and sweet I've done everything I possibly could to try and get the intermittent PS2 high boost misfires figured out over the last few years from different spark plug brands and gaps to new coil packs leak down tests boost leak tests flash only with ptf flash only with wedge jb4/stack but nothing would seem to have any positive effect. Happy to say they are goooone! Pure not only took care of the dirty work in getting the flywheel installed but also sourced one for me as well. Thank you Pure for your continued efforts and hard work in getting this figured out I am ecstatic. There has been mention on the forums of this helping the n54 dct platform but I don't believe I've seen anyone try the M4 dct flywheel on an n55. I jut picked my car up this morning and have done about 15 pulls with boost between the 20-24psi range. Before this flywheel my car would misfire on anything more then 19psi at redline pretty consistent. I did a few pulls up to 6th gear from 3rd hitting 22 up top and it's a ****ing missile. Thank you pure turbos much respect
18 Glacier white RS3
#PURETURBOS
#FUELIT
houtan houtan is offline
Default 04-26-2017, 11:54 AM
This is huge! Awesome news. Thanks for sharing and trying this out without knowing the outcome. Also, thanks to Pure! Looking forward to getting my PS2 installed!
Pure Turbos's Avatar
Default 04-26-2017, 12:02 PM
You're welcome! I told you we would eventually figure it out!
and to think all those people claiming it was the turbo... lol
PURE Stg2 + DCT = Rocket!
keyap keyap is offline
Car: N55 135i
Default 04-26-2017, 12:19 PM
Great news.
Was this the OEM M4 DCT flywheel or the MFactory version? Also, how does the car feel under normal driving given the difference in weight?
A bit more info is available here:-
http://www.n54tech.com/forums/showthread.php?t=44226
Newguy123's Avatar
Car: 12' 135i
Default 04-26-2017, 12:22 PM
Hahahaha! I know, I never lost faith
#PURETURBOS
#FUELIT
Newguy123's Avatar
Car: 12' 135i
Default 04-26-2017, 12:23 PM
Originally Posted by keyap
Great news.
This was a oem M4 dct flywheel they swapped in
#PURETURBOS
#FUELIT
Newguy123's Avatar
Car: 12' 135i
Default 04-26-2017, 12:27 PM
Great weight savings too 9.5lbs, the car still drives like stock but rips harder on the upper end of the rpms
#PURETURBOS
#FUELIT
Default 04-26-2017, 12:31 PM
Sweet, this looks promising. Will get one in our 135i soon.
Car: N55 135i
Default 04-26-2017, 12:33 PM
Could be time to start ringing some scrap yards!
Stoolz Stoolz is offline
Car: 11 135i
Default 04-26-2017, 02:08 PM
So Jealous.
Man I'm glad you got your car sorted.
Booya!
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 04-26-2017, 05:34 PM
Does this not have the chatter and noise that the lightweight single mass flywheels for the manual cars have?
Newguy123's Avatar
Car: 12' 135i
Default 04-26-2017, 06:02 PM
It's a stock dct m4 flywheel, so it's still a quiet dual mass.
#PURETURBOS
#FUELIT
Car: 335i 6MT RWD
Default 04-26-2017, 06:19 PM
Ahh ok. Pure's post on page 5 of the thread linked above from the N54 section made me think the M4 flywheel was just a single mass version of a 335 flywheel.
Wonder if something like this would work for us manual trans guys that don't want the downsides of a SMFW.
Anyways, sorry to derail the thread. That's a pretty sweet work around you guys found. Nice job!
Nugs Nugs is offline
Car: 2011 135i
Default 04-26-2017, 08:25 PM
Awesome!
Persistence beats resistance.
Are you still on the stock clutches?
Newguy123's Avatar
Car: 12' 135i
Default 04-26-2017, 09:16 PM
Originally Posted by Nugs
Awesome!
not the same clutch pack but I am Using pretty new oem clutches for now. Didn't want to spend a lot on SSP if I wasn't going to be using them due to misfire issues etc. now I know it's fixed and car is ripping I will upgrade when these start showing signs of slipping.
#PURETURBOS
#FUELIT
Peter @ Pure's Avatar
Car: F20 M135i
Default 04-26-2017, 11:44 PM
About time this got fixed. Time to vbox 60-130 at 24 psi of boost :D Show us some sub 7.5s N55 times!
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: N55 135i
Default 04-27-2017, 12:39 AM
@ Pure / Newguy: Is this the part no you used?
@ Pure: Did you ever try this on a N55 using the MFactory option:
Originally Posted by MFactory
sorry for the delay. We will actually be machining our own flange/hub to use with the flywheel (you won't be re-using the oem). Final confirmed weight of the flywheel is around 7kg
the designs are complete, and we will be making a test sample to test for fitment first, which will take a few weeks. Once confirmed this fits ok, we can start with the production batch.
we will be making both 6-bolt and 8-bolt flywheels
Price will be $499.95 + shipping
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 04-27-2017, 12:57 AM
Hmm what did it cost to install? I might have to get it done to mine maybe do the Dodson clutches at the same time save some labor
2018 Individual Tanzanite Blue Competition M4
Default 04-27-2017, 08:40 AM
Hey JD, long time no see. Hope all is well.
Don't use Dodson, use SSP. Voice of experience. We are appointed Socal dealer. Email us for pricing if needed
Default 04-27-2017, 08:41 AM
Yes, M4 DCT Flywheel.
Rob_BMW_PNW Rob_BMW_PNW is offline
Default 04-27-2017, 11:34 AM
Wonder how much parts and labor is on this
rhm135's Avatar
rhm135 rhm135 is offline
Tech
Car: 335is
Default 04-27-2017, 11:44 AM
Great news OP! This just got added to the list when I go ST. Pure Turbos always killing it!
335is DCT - xHP - JB4 - Fuel-it! - MHD - SSP - DocRace
Newguy123's Avatar
Car: 12' 135i
Default 05-03-2017, 10:38 AM
just an update, car is still ripping! misfire free 22-23 psi to redline. i will be investing in some SSP clutches now that i know my car is able to consistently run high boost.
#PURETURBOS
#FUELIT
Default 05-03-2017, 10:41 AM
Nice!!
VegasJD's Avatar
Car: 2012 bmw 135i
Default 05-03-2017, 11:26 AM
Just emailed you I had thought everyone got away from ssp and Dodson was better, I defer to your experience with it,
