MSully96 MSully96 is offline
Car: 2013 335is MT
Default 335is Clutch Slipping @ 47k miles - 06-15-2018, 07:23 AM
Well my luck finally struck. After getting the car all tuned up, I am now experiencing clutch slipping in 4 & 5th gear WOT starting around 5k rpms. This is incredibly frustrating given that I was a click away from ordering an FMIC and now I have this to deal with likely to cost over double an FMIC.
Maybe itís my frustration causing me to not think clearly, but is there any possible way this is tune related? The car doesnít stall from a 3rd gear start, Rpms drop immediately when engaging the clutch, and rise when I upshift and let the pedal out immediately. Never smelled burning and fluid looks good.
2013 335is Manual
JB4 G5 ISO - MHD E85 BEF - E45 - Fuel-it Stage 1 LPFP - BMS DCI - ECS Chargepipe & BOV - VRSF 3" d0wnp1pes - Muffler Delete w/ 3.5in Magnaflow Tips
Default 06-15-2018, 08:03 AM
Well with more power / torque - the possibility of a slipping clutch is always going to be there.
The 335is clutch is generally “good” up to around 500 ft/lbs to my knowledge.
To me it doesn’t sound tune related, outside of the larger power.
Car: 2013 335is MT
Default 06-15-2018, 08:22 AM
Should I dial back to map5 to avoid further damage to the clutch or flywheel (since I’ll be using the stock DMFW)?
2013 335is Manual
Default 06-15-2018, 09:05 AM
Have a log? Let's check the calculated torque to ensure it's as high as it should be. That is used by the trans to determine it's clamping force.
Car: 2013 335is MT
Default 06-15-2018, 09:10 AM
I’ll post one after work. I haven’t made any changes to the tuning since my last log a week ago so I’ll post that as well as a new one if needed.
2013 335is Manual
Newguy123's Avatar
Car: 12' 135i
Default 06-15-2018, 09:24 AM
Originally Posted by MSully96
Iíll post one after work. I havenít made any changes to the tuning since my last log a week ago so Iíll post that as well as a new one if needed.
Manual trans?
18í Glacier white RS3
#PURETURBOS
#FUELIT
Car: 2013 335is MT
Default 06-15-2018, 09:55 AM
Originally Posted by Newguy123
Manual trans?
Yes manual.
2013 335is Manual
halik008 halik008 is offline
Default 06-15-2018, 05:29 PM
Clutch, if slipping, would be slipping at WOT in low gears, not just in talk gears.
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 06-15-2018, 08:33 PM
lower gears would spin tires ,same thing happened to me. get a better clutch and remove the clutch delay valve if you havent yet. For the time being i would pull significant power out of it. it only gets worse once the slip begins.
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
