florida2002m3 florida2002m3 is offline
Car: E60 535i
Default Quick question for meth users - 02-15-2017, 09:56 AM
N54
DCI
E30
CP/BOV
Peak at about 18psi on map 5
Looking at a used BMS kit, comes with CM12, I believe that is too much flow for my setup. I dont believe BMS allows us to change the PWM (yet) to allow an actual progressive flow?
What problems will I have running a CM12 instead of a CM10 on my car?
Default 02-15-2017, 10:11 AM
There is BETA firmware posted that lets you adjust meth PWM. But, I'd go with a single CM10 kit. I'd also avoid used meth kits unless you're really experienced with it. So often parts are broken, incomplete, worn out, etc. And new kits are pretty inexpensive.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 02-15-2017, 10:43 AM
With a big CM12 nozzle, you might be able to lower the flow rate to an acceptable level but still the atomization will probably not be as ideal as a smaller or multiple smaller nozzles.
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
Car: E60 535i
Default 02-15-2017, 10:50 AM
You guys said kinda what I was thinking. Terry, I saw the new BETA FW already posted, but since it is BETA i didnt want to rely on that to manage flow.
I was thinking the same thing about the atomization. Larger orifice coupled with less pressure will not allow the nozzle to function as designed.
